VWVortex.com - Golf R RPM dependent cold engine noise
    Results 1 to 3 of 3
    Thread: Golf R RPM dependent cold engine noise
    1. 01-30-2018 11:40 AM #1
      Hopefully y’all can help me figure this out. Whenever the car is cold it makes a whizzing/rattling noise that seems to be RPM dependent. It goes away once the oil temp starts to register on the MFD. there’s absolutely no other sounds or issues once warm. Car has APR stage 1 ECU/TCU flash.
      I’ve searched the forums and found stuff about the wastegate rattle and the Soundaktor, both of which I don’t think are my problems.
      https://youtu.be/kkUlknKSDrE
      https://youtu.be/Mm8ieBDZhnc
    2. Remove Advertisements
      Advertisements
    3. 10-28-2019 10:03 PM #2
      I hear more of a whining sound on mine...sounds like a bad/going pump or bearing in an accessory but does seem to quiet down once warmed up. I do also smell coolant every now and then. New car...just 3k miles.
    4. Member
      Dec 1st, 2009
      2017 Audi SQ5, 2017 Corvette Grand Sport 7MT, 2010 Audi S4 6MT. 2015 Audi Q3 Quattro
      11-22-2019 07:56 PM #3
      timing chain?
