VWVortex.com - Used oil reports and oil recommendations
    Results 1 to 16 of 16
    Thread: Used oil reports and oil recommendations
    1. 05-20-2018 08:07 PM #1
      Ok, I've seriously tried to look through lots of oil recommendations. I find lots of statements from folks about whats good and bad but very little in the way of actual lab reports or other data to back it up.
      Is there some place that collects lab reports for various oils for Volkswagen cars?
      Is there an FAQ or summation of the available lab reports to indicate what oils are good in what circumstances.
      In my case, I'm looking for the best oil to get 10k oil change interval with a 2017 Golf (MK7) Wolfsburg.
      I know 502 is the requirement.
      I'm trying to find comparative information regarding, Mobil 1 0w-40, Castrol Edge 5w-30 or 0w-40, any of many LiquiMoly 5w-30 or 5w-40 oils.
      Thanks
    2. Remove Advertisements
      Advertisements
    3. Member Ichabod0525's Avatar
      Feb 11th, 2018
      Sonoran Desert
      Gen VI VW
      05-21-2018 07:06 PM #2
      I believe 505.1 is the spec for extended intervals. If I am wrong someone here will surely point that out. THIS covers both specs according to the TSB. Happy shopping.
    4. 05-22-2018 09:25 AM #3
      Quote Originally Posted by Ichabod0525 View Post
      505.01 is specifically intended for Diesel engines. I'm looking for oil for US gasoline engine. There are some extended OCI standards apply only to low sulfur gasoline, which the US does NOT have consistently.
    5. Remove Advertisements
      Advertisements
    6. Member nutsofast1.8T's Avatar
      Feb 3rd, 2004
      Perris CA
      MKV Jetta, '00 CBR 929, 64 Pontiac Lemans
      05-23-2018 12:57 PM #4
      I can partially help you out in a direction that can better help you reach your end goal. I get my oil analysis done through www.blackstone-labs.com. Go on their website and request a free test kit. They charge you only when they test the oil for $28. The test results show the quantity of medals in your oil along with where they should be and national average. They do charge extra for TBN, but dont remember how much. Good luck!
      "If no one has been offended by what you have done, you need a larger audience."
      May 10th, 2010
      Parts Unknown
      2016 Tiguan SE 4Motion
      05-23-2018 01:28 PM #5
      503 standards is for flexible service intervals, up to 30,000 km.
      505 series is TDI and that's a fixed 10,000 mile interval. 505.01 is specific for Pumpe-Duse TDI engines, where the injector are individual pumps and driven off of the camshaft, so it would need extra wear protection. Effectiveness of 505.01 is debatable.
      Certain gas FSI applications though, did call for 505.01, such as the RS4 4.2L V8 FSI engine
      APR Stage 1/DDM Tuning Ultra HID 5500K/Neuspeed P-flo/AEM Dryflow BruteForce filter
      May 10th, 2010
      Parts Unknown
      05-23-2018 01:28 PM #6
      Quote Originally Posted by nutsofast1.8T View Post
      iirc, $10 extra
      May 10th, 2010
      Parts Unknown
      05-23-2018 01:42 PM #7
      Back in the day, the top oil was Renewable Lubes Biosyn HD 5w40, as it produced better wear numbers. There was a plot of various Iron wear (but the original plot has site hosting issues)
      https://www.bobistheoilguy.com/forum...topics/1173372
      And... not a 502.00 certified oil
    10. 02-25-2019 11:22 AM #8
      Here's a report from Castrol Edge 0w-30 A3/B4 502 00 approved oil run for 5600 miles. Lots of life left.
      '17 GTI
    11. 03-27-2019 07:25 AM #9
      I have 2015 Passat 1,8 TSI. And I know that it is recommended to use 1,8 VAG SPECIAL PLUS SW40 but how about Castrol EDGE Professional Longlife III 5W30?
    12. 09-30-2019 02:51 AM #10
      MB 229.5 is the spec to look for. 502 is fine for an old 2.Slo or maybe a VR6, Basically an antiquated and obsolete spec.
      https://online.lubrizol.com/relperftool/pc.html
    13. 09-30-2019 02:52 AM #11
    14. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      2018 VW Atlas SEL 4Motion 2018, VW Golf Sportwagen S 4Motion DSG
      10-07-2019 04:17 AM #12
      Pheww... glad my LM/Kool Aid has 229.5.
      Sent from my SM-G973U using Tapatalk
      2018 Atlas SEL VR6 4Motion - K&N drop-in, deAuto interior, fog, and full tail LEDs
      2018 Golf Sportwagen S 4Motion DSG - Unitronic St2 IS20 ECU/St2 TCU/downpipe/K&N drop-in+air box/duct mods+block off/CTS TIP+TIH+TMD/034 dogbone insert/Golf R RSB
    15. 10-14-2019 02:31 AM #13
      Yeah, but you paid double for it.
    16. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      10-17-2019 06:38 AM #14
      Quote Originally Posted by A.Junkie View Post
      Accurate. I chose to spend my money as I see fit and tossing support to my favorite online Euro retailer for a $60 kit vs. $40 is money well spent.
    17. 10-17-2019 07:15 PM #15
      2017 1.4 Jetta TSI
      Penzoil Platinum Euro 0w40 VW 502 and MB 229.5 spec.
      4,445 Mile oil change.
      Lots of short trips. Harsh ohio winters.
      Since the oil thinned down to a 30 weight, I plan on keeping my oil change intervals at no more than 5,000 miles or one year.
      I would say determining the type of daily commute you have is more important than trying to split hairs and figure out which oil will get you to 10k miles. If you do mostly easy highway mileage in a mild climate, then 10k oil changes may work fine on any 502 spec oil.
      If you have a more severe duty commute with short trips and harsh winters like I do, you will want to stick to the 5k oil changes.
      2017 VW Jetta SE
      1987 Chevy R10 Custom Deluxe
    18. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      10-18-2019 03:03 PM #16
      My latest. 6k in Liquimoly Leichtlauf 5W40. Usually go to 7.5ish. Changed early for Stage 2 IS20.
