VWVortex.com - Jeep Gladiator Pickup for 2020
    The Car Lounge
    Page 3 of 28 FirstFirst 123456713 ... LastLast
    Results 51 to 75 of 699
    Thread: Jeep Gladiator Pickup for 2020
    1. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      11-15-2018 12:53 PM #51
      Quote Originally Posted by 1x1 View Post
      For those complaining about the name, remember that this new Jeep is similar in size to the original Gladiator, and not the Scrambler. I don't have a preference as to what they call it, but based purely on size, this is a Gladiator sized truck.
      Yes and no, I mean by this logic the civic should now be the accord and the ranger should be an F150. Just because all modern vehicles are larger doesn't mean they changed class. Oh it's the same size as this thing from 50 years ago when every vehicle has gotten larger just seems like a weird justification.
      the wheel base ranged from 120-165, this is I"m going to guess about 132? but it is a 4 door giving it that jump vs the 2 door J series which then also had a full size bed vs this 5ft bed. Make it a 2 door and I bet its sub 120. So by that it is about the same size but "size" isn't the only thing that defines a truck.
      Width is close, at about 1" less on the new one, but a CJ to a JL has grown by about 6" in width so had a J series continued to today it would have likely grown by at least that much.
      The J series had a ~2 ton payload limit depending on version vs this under 1 ton (still good but not even close to the same) So its kind of a wimp in that department and not up to the "size" of the gladiator.
      The J series Gladiator was meant to compete with other full size trucks, this is not. It is still an S10 (colorado)/ranger sized truck. A modern J series would have been much larger than what this is. The name is the name clearly, nothing we say is going to change that, this just doesn't seem to really fill the shoes of the original one.
    2. Remove Advertisements
      Advertisements
    3. Member Engineer90's Avatar
      Feb 14th, 2016
      northern NJ
      11-15-2018 01:44 PM #52
      Quote Originally Posted by chris86vw View Post
      We are also outdoorsy and don't have kids.. also have wrangler.. the wagons make more sense for that life style weirdly enough.
      Chris, I tend to like the 2-door better because of the shorter wheelbase (which is arguably better for some angles), but the pic I posted look awesome though. If I do get a JL in a few years, I would get the 4-door and just get rid of the body components and customize it exactly like the one I posted. Although I would paint it either a matte black or matte dark gray similar to the carbon steel on my GTI.
      How are you stretching your TJ? Are you physically cutting the frame and extending it?
      2016 GTI S 6MT 2door
    4. Member The_Real_Stack's Avatar
      Oct 18th, 2016
      Arlington Heights, the center of the universe
      AP1 and JLU
      11-15-2018 02:19 PM #53
      It's cool and all, but I hope it steals a crapload of sales from the JLU so my beloved JLU is rarer.
      My Jeep is currently packed to the gills ready in the parking lot to set off for my hunting trip this afternoon
    5. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      11-15-2018 02:41 PM #54
      Quote Originally Posted by Engineer90 View Post
      Same I love the look of the 2 door but at the length of the LJ or JkU/JLU. I'm normally not even a 2 door guy just like the look better on these. The JK8 kit I noted above basically did what that green one does, wonder if they just used some of those parts and modified for the JL??
      If you google TJ6 or TJ-6 you can find some builds to better describe it. But yeah you cut it right after the doors and extend the frame ~12" plus patch in the body or use an LJ tub with modified wheel wells. The LJ was like 12" longer but they split it in wheel base and body. So you keep the TJ departure angle but have a worse break over than the LJ, for me I want the wheel base and can deal with that as it is still under the JK/JL Unlimited wheel base. Just can't justify the cost yet as the top I want is 4grand... Doing a pickup kind of appeals to me but I like the idea of it all being enclosed as one.
      But now that this exists the gladiator probably just makes more sense. We'll see how I feel in a 2 years when the diesel is out and whether i've cut mine in half yet
    6. Member The_Real_Stack's Avatar
      Oct 18th, 2016
      AP1 and JLU
      11-15-2018 02:51 PM #55
      I originally only wanted a 2DR JL, because agreed, they look way better.
      That said, you can haul 4 people OR their luggage in a 2 door, not both, so I had to go 4DR and it's just fine as a consolation prize. If you dont have 2 kids and a wife though, totally 2DR all the way.
    7. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      11-15-2018 03:01 PM #56
      Quote Originally Posted by The_Real_Stack View Post
      yup I don't even have my rear seat anymore and even the belts are removed, only living things ever back there are the dogs. LJ was a good compromise of 2 door look with more cargo space and still room to keep the back seat.
      I do think the length of the unlimited from the side with a hartop looks a little tougher, not that it looks like a hummer but more hummer like, its the length to boxiness ratio. Soft top or topless the 2 door wins in the looks department. Stock height 4 door with the doors removed and no top looks like an airport tram with a roll bar. Sadly I don't think this gladiator with no doors will look great.
    8. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      '94 Miata - '16 RAV4 - '10 Prius
      11-15-2018 03:04 PM #57
      This thread had me wondering if anyone made a half-cab kit for the previous "Unlimited" LJ's... of course they do.
    9. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      11-15-2018 03:16 PM #58
      Quote Originally Posted by Sporin View Post
      Red one in the back has the safari top I want badly
      concept based on the Alaskan CJ-8 Scrambler tops with a LR series 2 safari theme for the windows. The creator of them has like a dozen versions including a hard top with soft sides.. it's a amazing. He also created the Dinoot trailers... which has then used to make pickups beds.
      inspiration
      images don't seem to be showing so.. http://classicvehicleslist.com/pics/...hard-top-5.JPG
      One of the versions of his top.. and a CJ front clip he made to fit his LJ
      http://www.street2mud.com/albums/alb..._Black_Pic.jpg
      Just google "jscherb jeep" to see all his nutty versions he has created.
    10. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      11-15-2018 04:14 PM #59
      Yeah, GR8TOPS has one of those, too.
    11. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      11-15-2018 04:26 PM #60
      That's all the Jscherb stuff, he licenses it to gr8tops for manufacturing/sale. Like Dinoot with the trailers and I think he has a few other things out there.
      What would be cool is how with the JL soft top you can pull out all the windows.. but if they made a bump/safari style hard top that you can leave the top in place and swap between the stock soft sides and the aftermarket hard panels.
      there is a smitybuilt JKU safari top, not quite as awesome looking as the gr8tops TJ/LJ ones and not modular but still cool and much cheaper, bet they make a JL one.
      ETA.. also this is how thought out the Jscherb stuff is if I remember correctly the two trailer tub sizes are the same size as the safari hard tops for the TJ and LJ I don't think gr8tops will sell you just the top (maybe) but in theory you could remove it and bolt it to your dinoot trailer.
    12. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      11-15-2018 04:53 PM #61
      Quote Originally Posted by Iroczgirl View Post
      What they're proposing now is more like a Scrambler.
      As I said before, if they weren't going to call it Scrambler they should call it "Over Easy". You could also outfit a hunting version and call it the Jeep Poacher. The hard core off-roaders could have a Hard Boiled edition and mall crawlers would be soft boiled. Soft top versions would have the "Sunny Side Up" option.
      Okay, I'm done. That's all I got.
    13. Member The_Real_Stack's Avatar
      Oct 18th, 2016
      AP1 and JLU
      11-15-2018 04:58 PM #62
      Quote Originally Posted by Air and water do mix View Post
      Are they going to rename the Compass the Omelette? Or maybe the Egg Salad? Maybe a special Military version sold only in CT called the Benedict?
    14. Senior Member VWVan's Avatar
      Feb 17th, 2000
      Langley, B.C.
      2005 Jetta Wagon TDI manuel 1.5 Malone, 2014 Tiguan 4MO
      11-15-2018 05:08 PM #63
      It should have a slide out bed for camping.
    15. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      11-15-2018 05:15 PM #64
      Quote Originally Posted by VWVan View Post
      Urban camping, suburban camping, suburban but kind of urban like since someone walking to dinner might see you pooping in a bucket camping and if people can walk to dinner its urban? or actual camping?
    16. Member
      Mar 30th, 2015
      Out of Warranty BMWs
      11-15-2018 05:56 PM #65
      It blows me away how long this has taken. They have been talking about it for so long.
    17. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      Hot hatchback coupé heaven
      11-15-2018 09:38 PM #66
      Quote Originally Posted by andlf View Post
      I vote for Comanche!
      Great choice.
      Lots of VW stuff|Rare Scirocco parts!
      The family: 1955 Customline 351C | 1970 TR6 262Olds | 1977 Capri Cologne | 1980 Rabbit AAZ | 1984 C30 350 | 1988 Scirocco 9A | 1988 Scirocco LP7Y | 1992 Pickup 22RE | 1997 D21 KA24E | 2000 Grand Marquis Modular
      Quote Originally Posted by Crimping Is Easy View Post
      You're always better off with a Citroën.™
    18. Member Vettes, Volvos and VWs's Avatar
      Mar 5th, 2006
      Sudbury, ON
      Four Germans and a Japanese Misfit
      11-15-2018 10:20 PM #67
      Can I haz?!?!?!
      Quote Originally Posted by Baconator14 View Post
      vettes, volvos, and vws for president
      Quote Originally Posted by UAlvarez View Post
      you're a boss. your sig is appropriate
      My Weak Shiz l Milk █Bg█ Mafia GLI Aluminum trim for Sale Click here and PM me for Speed-Tech Hood Extensions!
    19. I need new ones NeverEnoughCars's Avatar
      Aug 2nd, 2013
      Below the glide path to KAUS
      Dodge, Toyota, VW, Ford
      11-15-2018 10:29 PM #68
      Quote Originally Posted by Vettes, Volvos and VWs View Post
      Can I haz?!?!?!
      I would rather have a Suzuki Jimmy with the defender body kit.
      Pedantry: winning arguments through exasperation since 1651. An Old World Tradition!
      "Now i am become death the destroyer of worlds."-bhagavad gita
      “Only those who will risk going too far can possibly find out how far one can go.” -T.S. Eliot
    20. Member
      Oct 7th, 2006
      CT
      Evo VIII, BMW e12, XTerra
      11-16-2018 08:54 AM #69
      Quote Originally Posted by dan of montana View Post
      x2 The first modern Gladiator concept was back in 2005!
      2005!!!
    21. 11-16-2018 09:22 AM #70
      Quote Originally Posted by Quinn1.8t View Post
      2005!!!
      How many billions in revenue did Jeep leave on the table in the last 14 years? A **** ton.
    22. Senior Member AZGolf's Avatar
      Jun 6th, 2000
      Phoenix area
      11-16-2018 09:36 AM #71
      Quote Originally Posted by Rob View Post
      Midsize trucks were assumed to be dead. The S-10, Ranger, and Dakota were America's midsize trucks, all were discontinued. Why would Jeep sell a midsize truck in an environment all the big players had left for dead? They made a business decision that was probably well justified in the mid 2000's and after the recession hit in 2008 along with record high gas prices it probably looked very smart to have not devoted resources to a niche midsize Jeep truck. The Chrysler part of what is now FCA has had money problems for years, they did what they had to do to keep the business low risk and alive. It's only in the recent years we've seen the Colorado introduced and find success, the Ranger be stated as returning to the US, and now FCAs entry into midsize trucks is the Gladiator. Timing matters, and between Chrysler's ownership & financial problems and the global recession, they did what was most sensible.
    23. Moderator Oliver@triplezoom's Avatar
      Nov 30th, 1999
      Fredericton NB Canada
      2017 MINI Clubman JCW, 2015 VW GTI Autobahn, 2017 MINI Cooper
      11-16-2018 11:24 AM #72
      I dunno. Wrangler sales have been increasing for years, and a pickup definitely cannibalizes sales of the normal model.
      The real question is, how much of a premium can Jeep charge for the pickup? Usually pickups are cheaper than their SUV equivalents.
    24. Senior Member chucchinchilla's Avatar
      Dec 25th, 2004
      Los Gatos, CA
      2016 A6, 2014 X3, 1967 Bus, 1963 356
      11-16-2018 11:36 AM #73
      I'd buy it.
      Quote Originally Posted by [email protected] View Post
      This forum is more and more of an embarrassment every day...
    25. Member davewg's Avatar
      Jul 30th, 2001
      NJ near Philly - for the steaks!
      7 Speed RGASM
      11-16-2018 01:20 PM #74
      Quote Originally Posted by mx5er View Post
      So is there going to be a porn version? Glad-He-Ate-Her???
      Quote Originally Posted by 2 doors View Post
      Will this be coming out before or after the new-for-never coming Jeep Grand Wagoneer?
      FTFY
      Or, before/after the also oft delayed WK3 Jeep Grand Cherokee. And the BOF Durango.
      Nah. You need an old van for that.
      2018 Golf R - mine, mine, all mine.
      2017 Golf Alltrack SEL+Tech - Son #1. In a galaxy far, far away
      2014 Dodge Durango Limited AWD - Wife's
      2004 Acura TSX - Son #2. The sax-mobile
      1967 Chevrolet Corvette - I promise to get this car back on the road in 2018....
    26. Member Engineer90's Avatar
      Feb 14th, 2016
      northern NJ
      11-16-2018 03:16 PM #75
      Quote Originally Posted by NeverEnoughCars View Post
      S**t... I'd rock either tbh
      Sucks we can't get Jimny's here tho I'd buy one
