VWVortex.com - about to install a CTS turbo kit, anything i should know?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 31
    Thread: about to install a CTS turbo kit, anything i should know?
    1. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      90 Jetta Coupe 1.8BT, 18 GSW 4motion, 01 b5a4
      12-21-2018 05:47 PM #1
      So i went and picked up a CTS turbo kit with upgraded gtx3071r last week. just wondering if there is anything to look out for when it comes to install. it will be fitted in my mk2 coupe with stand alone management. ill try and make this a build thread to follow if i remember to take pictures.
      I have had this jetta for over 10 years, most of it was already 1.8t swapped and daily driven.
      Vehicle: 90 Jetta Coupe
      cx racing coils
      autotech front and rear swaybars, 25mm and 28mm
      poly and derlin bushings every where it seems
      corrado 11inch front brakes and rear disc, SS lines
      other braces i dont remember what brand.
      autopower bolt it/ welded roll cage
      Engine: 1.8t
      IE Drop in rods
      supertech valve springs and seat
      autotech intake cam
      supertect inconel exhaust valves
      arp head bolts
      gtx3071r turbo with CTS kit
      034/grams intake manifold
      grams 70mm TB
      39mm precision WG
      3 in. custom straight pipe back
      some decent FMIC (might need something bigger)
      EMU black stand alone
      o2j trans with 3.9 R&P, (might swap out fifth gear with diesel ratio)
      o2j shifter
      quaife lsd
      clutch masters fx300 clutch with g60 LWF
      other parts looking to get:
      better catch can system
      watermeth and or bigger IC
      here are a couple pictures i snagged the other night mocking up the turbo and manifold.
      old frankenturbo
      just a few with turbo mounted before my phone died
      ........... \_________
      ..... ,___/ /___l ___\\_____
      ...... l________l____/_____l
      .......\__( o )_______( o )__/
    2. Remove Advertisements
      Advertisements
    3. Junior Member THEWIDOWSON's Avatar
      Nov 6th, 2018
      EMPIRE STATE
      MK4 GTI 1.8T 2DR Manual / B4 Audi Quattro
      12-21-2018 06:06 PM #2
      Pictures did someone say pictures
      Some people get a mortgage. I buy gti parts.
    4. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '17 R
      12-26-2018 03:51 PM #3
      Buy pagparts
      Sent from my SM-N950U using Tapatalk
      :HOMEGROWN MOTORSPORTS..SingerVehicleDesign...1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    5. Remove Advertisements
      Advertisements
    6. Member
      Jan 23rd, 2008
      Toledo, OH
      2004 AWP Jetta; 1996 AAA Passat; 2003 S-10
      12-26-2018 05:21 PM #4
      Connecting rods? And pictures! Lol
      NefMoto
    7. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      12-26-2018 07:19 PM #5
      gonna start putting some together tonight and see how they fit, and will take pictures. Rods, valve springs and intake cam are installed already. On a side note, anyone in the market for a frankenturbo kit?
      Jan 23rd, 2008
      Toledo, OH
      12-26-2018 08:36 PM #6
      Nice!
      NefMoto
    9. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      12-27-2018 01:19 AM #7
      little tease while i figure how to build a "build thread"
      cheers [IMG][/IMG]
    10. Member
      Jan 23rd, 2008
      Toledo, OH
      12-27-2018 06:46 PM #8
      Quote Originally Posted by vee_dubb_gti View Post
      cheers [IMG][/IMG]
      There’s really no how to on the build thread. I would suggest maybe talking about your previous “version”, what you’ve done so far, what your plans are and tons of pictures lol.
      NefMoto
    11. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      12-29-2018 07:54 AM #9
      updated with just a few pics
    12. 01-01-2019 01:54 AM #10
      I would be happy with a used franken turbo depending on the price. What company is it from and how much were you thinking? Please PM me.
    13. Member
      Jan 23rd, 2008
      Toledo, OH
      01-01-2019 06:57 PM #11
      Looks sweet!!!
      NefMoto
    14. Member
      Jan 30th, 2012
      WA
      '05 GTI
      01-01-2019 09:25 PM #12
      Your oil return looks like it might be backwards. Maybe a little long, too.
      3071/rods/ppt.. and still just a gti.
    15. Member
      Jan 4th, 2007
      MA
      2004 Jetta GLS 1.8T
      01-02-2019 12:44 PM #13
      Check this out too. it might help. https://forums.vwvortex.com/showthre...-my-Turbo-k03s
      I noticed your rubber line next to the turbo is not a good idea. It will melt or crack quickly when it gets too hot in there.
    16. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      01-04-2019 01:37 PM #14
      Quote Originally Posted by radlynx View Post
      yea im not a fan of that coolant line. kit only had one line anyways. im gonna get some high temp hose and wrap it in thermal sleeve. im also thinking of hard line for a portion around turbo to combat heat.
      for the oil line i think it will be ok routed around the axle. i was able to put the sub frame together and wanna mount it all in the bay and check clearances.
    17. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      03-30-2019 12:54 AM #15
      progress has been a bit slow. was farting around the the EMU harness tonight. other than that i had mounted the clutch and pinion brace. i just cant wait for body work to get done and start putting the coupe back together.
    18. Member
      Jan 23rd, 2008
      Toledo, OH
      04-24-2019 08:08 AM #16
      Just go take some random pics of your progress. People love photos
      NefMoto
    19. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      05-05-2019 08:58 AM #17
      got a round to taking some pictures of the progress. body work is under way and ive removed the rest of the dash last night. more parts on order and got the almost all of the ecu harness pinned. not sure if ive posted it but i also got around to getting the voomeran flares in. fitment looks great.
      enjoy some of the update pictures
    20. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      05-06-2019 09:08 PM #18
      starting to regret not installing exhaust valves when i had the thing apart. i guess its still not too late. might as well to arp hardware while at it.
    21. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      05-08-2019 09:41 PM #19
      went ahead and ordered exhaust valves tonight. got some iconel valves and arp head bolts. figured why not before the engine goes back in. still working on body work tonight (as i wipe dust off the keyboard). cant wait till after paint to start putting it back together.
    22. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      05-09-2019 01:08 PM #20
      Stainless are smarter.
      What management?
      What vegeta said.
    23. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      05-09-2019 02:10 PM #21
      Quote Originally Posted by Vegeta Gti View Post
      What management?
      ecumaster emu black
    24. Member
      Jan 23rd, 2008
      Toledo, OH
      05-09-2019 03:56 PM #22
      I think he has EMU Black management. (pictured in the 4th photo from the top, behind the pabst)
      NefMoto
    25. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      05-11-2019 09:45 AM #23
      Little progress last night, more to come this weekend. took both front fenders off and started de-greasing all the road grime from over the years and will over all work on getting ready for primer in the weeks to come.
      I wanted to ask hear while im still researching what fuel injectors to get. i had planned on running an old set of siemens deka 630cc that ive had for a couple years. now im looking into other options for e85/flexfuel. so far the genesis 2 1000cc, injector dynamics id1050x and maybe ev14. (leaning toward id1050x) Ive used some injector calculators and given the setup, 1000cc injectors are needed. if any one has some info that i may not come across speak up.
    26. Member vee_dubb_gti's Avatar
      Nov 17th, 2004
      Wauconda
      05-29-2019 05:10 PM #24
      Some pictures i forgot to post of the clutch and pinion brace. i hope to find time this weekend to pull the head again and install valves.
    27. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      05-30-2019 02:37 PM #25
      the genesis 2 are superior to everything else on the market for the 20v. spray pattern, their consistency in quality and performance. because of that, they're a dream to tune and they deliver.
      What vegeta said.
