VWVortex.com - Recipe for low to high 12 second 1/4 mile with the 2.0 turbo
    Results 1 to 4 of 4
    Thread: Recipe for low to high 12 second 1/4 mile with the 2.0 turbo
    1. Junior Member
      Nov 18th, 2018
      Miami, FL
      2014 Beetle R-line DSG; 2004 GTO 6spd; 2004 Rav4
      01-18-2019 06:07 PM #1
      If you have gotten there, what were your mods?
    2. Remove Advertisements
      Advertisements
    3. Member Superfrankie's Avatar
      May 17th, 2014
      Hilliard, Ohio
      2014 gli 30th, 1991 3000gt Vr4, 2001 Camaro, 2001 Eclipse
      02-25-2019 02:19 PM #2
      Mod list
      With this set up I’m consistently around 25psi it has peaked at 27psi and I’m sure I’m forgetting some mods this is just all I can think of right off
      Apr stage 2 tune
      Apr tcu tune ( dsg)
      Jb4 stacked piggyback
      Apr stage 1 and 2 carbon intake
      Forge blow off valve
      Cts turbo muffler delete
      Cts Catless 3” downpipe
      Magnaflow exhaust system
      Custom front mount intercooler 28x8x3.5
      Custom intercooler pipe 2.5” from turbo to throttle body
      Golf r injectors
      034 Motorsport engine mounts
      034 Motorsport dogbone
      034 Motorsport billet dogbone insert
      Volkswagen drive gear springs by eibach
      Bilstein b6 shocks and struts
      Ecs tuning 23mm rear sway bar
      Ecs tuning rear subframe brace
      Custom meth kit is finished waiting till spring to install
      2014 Edition 30 GLI. [email protected]
      APR stage 2 | APR tcu | JB4 stack | CTS turbo catless downpipe | Apr intake stage 1&2| Forge bov | ECS turbo outlet pipe | Neuspeed throttle pipe | VW DG Springs | Bilstein b6 HD Struts and Shocks | ECS Strut mounts | ECS dogbone insert | Neuspeed intercooler delete | 28x8x3.5” FMIC | Magnaflow exhaust | ecs stainless brake lines |
    4. 06-21-2019 04:12 PM #3
      12 second quarter mile? Just get out of the car and run.
      The stock golf r turns in a quarter mile at 13.1 seconds. You could be a 11.9 second car with stage1 and you wont need all that fancy crap that other guy has.
    5. Remove Advertisements
      Advertisements
    6. Junior Member
      Nov 18th, 2018
      Miami, FL
      06-23-2019 04:27 PM #4
      Quote Originally Posted by xkeyscore View Post
      A Golf R is 288 hp, 280 ft-ls tq
      2.0 TSI is 210hp, 207 ft-lbs
