VWVortex.com - Feeler 1994 Vw Jetta Glx 1500 OBO
    Results 1 to 3 of 3
    Thread: Feeler 1994 Vw Jetta Glx 1500 OBO
    1. Member VR6 GLX Man's Avatar
      May 19th, 2008
      Silverdale, WA
      1994/VW/JETTA/GLX 2014/Ford/FIESTA ST
      01-20-2019 03:39 PM #1
      Posting on the fly will edit and add more later. 215k miles. Runs strong, has been my daily untill recently due to having to fix a seized cv axle. I replaced the drives side unfortunately, a screw made a tiny hole in the transmission housing. I did a temporary fix a JB welded the tiny hole, and have been able to drive the car without anymore transmission gear oil coming out, but will need to drain and refill tranny oil. I know it's not a correct fix, but I dont have the cash or time to remove the tranny. The car does drive as it is right now and hasn't leaked since I patched up the hole twice and have let it sit over night, the area is completely dry, I know it's a ghetto fix that worked, so price verynegotiable, but I'm looking for a daily that has more creature comforts and dont want to have the car taken to a junkyard, want it to go to an enthusiast. The car pulls pretty hard and it's a lot of fun, but it's an ongoing project I was working on slowly due not having a lot of time. Also the 94's where the first year German built Jetta Vr6's VIN WVW.Call or text 619-386-1055. Comes with many extra parts, will add later. Come test drive it.
      PROS
      Vf engineering front motor mount
      GIAC chip
      Rear strut bar
      Lowered on blistien shocks
      New fuel pump
      New fuel filter Bosch
      New 4 bar FPR
      Power steering installed not long ago
      Custom 2.5 aluminum exhaust new magnaflow cat resonated, sounds perfect not too loud.
      1.8t iat sensor
      New drivers side wheel bearing and hub
      New drivers side axel
      Manual crank windows all four work, new drivers side regulator "less weight than power"
      Cons
      No AC
      Needs a paint job due to oxidation
      Transmission has jb welded hole
      Engines burns a little bit of oil doesent smoke at all though.
      Coolant needs to be refilled every so often
      Mismatched interior, trek front seats, gt rear seats
      No radio
      Heater core is bypassed, blower works
      Coolant gauge doesent read, no overheating issues, both radiator fans kick on.
      Sent from my SM-G950U using Tapatalk
      VRSociety #293
    2. Remove Advertisements
      Advertisements
    3. Member Rapid Decompression's Avatar
      Dec 5th, 2004
      Spokandyland
      ...stopped keeping track
      05-06-2019 10:24 PM #2
      THis thing still around and available?
      Quote Originally Posted by skin1488760
      i am a ****ing racist!
      SCAMMER skin1488760 Christopher Heiser Escondido Ca951-756-5977 .https://forums.vwvortex.com/showthrea...4-looks-SO-CALhttps://forums.vwvortex.com/showthrea...e-intake-socal
    4. Member VR6 GLX Man's Avatar
      May 19th, 2008
      Silverdale, WA
      06-04-2019 08:30 PM #3
      Quote Originally Posted by Rapid Decompression View Post
      Decided to keep her.
      VRSociety #293
