VWVortex.com - Ace of Base: The Cayman Chase
    The Car Lounge
    Page 3 of 7 FirstFirst 1234567 LastLast
    Results 51 to 75 of 152
    Thread: Ace of Base: The Cayman Chase
    1. Member Tommietank's Avatar
      Mar 6th, 2009
      Burlington, VT
      2017 BMW i3, 2018 Clarity, 2001 Honda S2000 (sold)
      02-02-2019 12:22 AM #51
      Is it possible to over rev a PDK version of this?
      Slow Car Fast
    2. Remove Advertisements
      Advertisements
    3. You can't look at my avatar for just a second, can you? Just another GTI's Avatar
      Aug 11th, 2002
      Southwest Ohio
      GTI Sport 6M
      02-02-2019 12:40 AM #52
      Quote Originally Posted by Tommietank View Post
      I can't speak for a Porsche but VWs will not let the driver over rev with DSG with factory software.
      A VW will automatically upshift at predetermined limits. I have never bought aftermarket DSG software. I assume that aftermarket software would just bounce on the rev limiter in manual mode and not allow an over rev event. The DSG will not downshift to the next gear until it determines it is safe to do so. Click all you want and downshift happen until it's safe.
      An over rev event could be a concern with Kiznash's car since it's a manual. PDK not so much.
    4. Don't be me. Don't be a 'Rick' Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      2004 E46, 2018 SQ5
      02-02-2019 12:44 AM #53
      Quote Originally Posted by Just another GTI View Post
      Fun fact -
      The GMT800 trucks 1999-2006 GM trucks will upshift as well.
      Even if you put the column shifter in 1 or 2, if you floor it and hold RPM’s for a few seconds it’ll start shifting through the gears like you’ve got it in drive.
      Makes sense, especially when they were under warranty.
      Instagram - efrie004
    5. Member CaleDeRoo's Avatar
      Jul 30th, 2011
      Rochester, NY
      2005 Corvette Z71, 1998 Corvette
      02-02-2019 10:46 AM #54
      Quote Originally Posted by Cabin Pics View Post
      Fun fact -
      Will it? I had my truck in 2nd and I let off at 5500-5600rpm because it seemed like it definitely wasn't going to
      Instagram: calederoo
      #FREEPATRIKMAN
    6. Member OrdinaryGirl's Avatar
      Mar 16th, 2005
      Victoria, BC
      2003 Jetta TDI Wagon
      02-02-2019 12:08 PM #55
      Am I the only one who's *not* disappointed you didn't buy the amg? I definitely think you made the better choice. Even if it wasn't that much of a choice...
      If I were a supermarket lobster, I wouldn't wish for anything less than nuclear Armageddon.
      Oct 22nd, 2007
      Syracuse, NY
      '17 GTI, '18 F22, '13 E88, etc.
      02-02-2019 01:23 PM #56
      Sure, it's possible, but it's unlikely. My understanding is that it will bounce off the rev limiter without up-shifting, but won't let you downshift if there aren't enough revs to do so.
      I would think the wheels would need to be off the ground for an over-rev situation.
    8. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-02-2019 11:51 PM #57
      Quote Originally Posted by OrdinaryGirl View Post
      Oh I'm pretty sure no one was disappointed. Well, except maybe the dealer GM.
    9. Member OrdinaryGirl's Avatar
      Mar 16th, 2005
      Victoria, BC
      02-03-2019 01:22 AM #58
      Quote Originally Posted by kiznarsh View Post
      Lol tough titties to his bonus check! I'm pretty sure you got the superior automobile. Good choice I'd be lying if I said I wasn't even a tiny bit jealous - I don't commute anymore so driving is a treat for me these days, and that tdi.... She's a slug.
    10. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-04-2019 03:15 AM #59
      Now that the introduction is over, let's get to it.
      I was told the bumper holes were "already there" but the line item on the invoice indicating 4 screws makes me wanna throw the flag.
      Even though there are some rock chips on the bumper cover, it's nowhere near bad enough to make me want to fill in the holes and respray it, especially since this is my daily so I ordered plugs.
      Drilled out the holes to 9/32nd...
      ...and there ya go.
      Next item was the clutch and how stiff it is. A friend told me how his buddy's 986 clutch spring broke and it became really tight, so I got in everyone's favorite awkward position to look up and nope, no issues with the spring (wrapped around a white piece). Doing more research revealed this is just how it is, unless the clutch is near the end (unlikely at only 7k miles old). Of course as I type all this, I'm totally used to it now.
      I was getting the "service due" reminder but wanted to clear it since they had just done an oil change. This aspect of the Durametric software doesn't work on the 987s so I had to do it the old-fashioned way: pull the instrument cluster fuse for a bit.
      Then I decided to change out the air filters and replace the serpentine belt since it wasn't documented anywhere.
      Carpet removed.
      Engine cover gone. 'tis dusty but I'm gonna hold off on cleaning the bay for now.
      OK fine I did clean the air filter cover.
      Getting the new filter to seat on the flange was tricky, until it wasn't, nomsayin'?
      Now to the frunk and the cabin air filter.
      While there, I used a coax cable to clear out the drain holes.
      Now shifting gears to the belt. Aluminum handle bar removed (2 T45 screws).
      Then one T20 screw for the plastic cover, which then snaps off.
      Carpet removed revealing the other engine cover.
      Of course they're 10mm bolts.
      Access is...tight.
      However, either the belt is super resilient or it's already been replaced once, and fairly recently too. Just look at it.
      So it looks like I'll be returning the belt I got but while I was in there, I pulled on the tensioner to see how it feels. Felt good, man.
      Inspected the power steering fluid. Hard to see but it looked tired and didn't smell very sweet. I'll have to look into it but guessing sucking out the old fluid is my best option. I did see a little seepage at the PS pump connection but I don't know yet how easily addressing that is going to be.
      Applied a little silicone to the rubber gasket on the engine cover to keep it fresh.
      Not sure how this cap got lost, but it's back now.
      Last week I got the "refill washer fluid" message and without paying attention to its capacity, I added a mixture comprised of distilled water and the concentrated Porsche washer fluid that I kept. I stopped when it started to overflow from the filler neck and some poured through the fender liner down to the ground. Whoops. But then I noticed puddles for the next 2 days underneath where the reservoir sits and remembered that I accidentally bottomed out on a dip when going a bit too fast on an unfamiliar street. So I thought maybe I had cracked the reservoir or jarred something loose.
      Took off the wheel and fender liner for an inspection.
      Bump stop's tired of bumpin'.
      Here's the reservoir. Everything looked fine, there's still fluid in there and I didn't see any leaks from the pump gasket.
      Then I noticed this overflow hose at the top, which is below the level of the filler neck, so driving around must've caused all the excess to overflow. I guess I'll find out. Capacity is only 0.66 gal/2.5 liters in case it comes up on Jeopardy.
      Also realized the filler hose comes out which makes positioning the reservoir a lot easier. Nice.
    11. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      West Coast, not that west coast. Bay area, not that bay area.
      16 Cayman GTS, 16 Colorado Crew, 17 Escape, 09 Versys, 2017 Barracuda
      02-04-2019 10:16 AM #60
      Lower it!
      I would like to hear what you think about this 987.2 Cayman compared to your 981 Cayman S. When I bought my 981 GTS, I was also considering a 987.2 Cayman S but couldn't find anything decent at a fair price. I think the recession really put a damper on sales of them over the years.
      Dec 3rd, 2011
      The NATO garage: 3 British, 2 German, 2 American.
      02-04-2019 10:45 AM #61
      I had this same issue with my "Enthusiast" Durametric, but I hadn't thought of the fuse-pull hack. Thanks for that tip!
      Looks like you're getting her all squared away, well done!
      As for the power steering pump, I blew up a couple of mine (track use) before the addition of an under drive pulley and an inline power steering cooler from LN engineering. I assume you're not hearing any whine from the system when turning hard at this point?
    13. Member 2000JettaGLXVR6's Avatar
      Oct 17th, 2002
      Southern California
      2016 A6 2.0T Quattro
      02-04-2019 11:27 AM #62
      This is the exact same spec as my old Cayman. If it weren't for the front plate, I'd swear that's my old car.
      FOR SALE: 2015 eGolf SEL Premium, 52,000 miles, $11,500
    14. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      02-04-2019 11:39 AM #63
      Quote Originally Posted by spockcat View Post
      Lower it!
      It absolutely did. The .2 987/997 cars are rare as hen's teeth thanks to that.
    15. 02-04-2019 11:45 AM #64
      Not a fan of the Pioneer unit or the aftermarket Fogs. Also not a fan of base model Caymans. Oh well.
    16. 02-04-2019 12:00 PM #65
      I've come to the same conclusion as the OP- when it came to the 987.2, even the base model has more power (265) than the 986S. They're light enough (3000 lbs.) that the power is plenty to have a real sweet driving package without feeling underpowered.
      It seems like most of the 2009-12 Porsches are pretty hard to come by, sales numbers must be very low for the 987.2/997.2 cars.
    17. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-04-2019 01:20 PM #66
      Lower it!
      It will be lowered eventually and likely just with springs.
      I'd give the 981 the advantages of styling (esp the interior), handling (though mine had the sport suspension so not a fair comparison), & exhaust tone.
      987.2 wins in the steering & engagement categories. It also seems more DIY-friendly.
      I can see myself becoming more attached to it as I slowly make it mine. And with no sport/sport plus buttons, it feels more like a traditional sports car with an engine that seems more comfortable at high revs.
      Quote Originally Posted by Dave_Car_Guy View Post
      Pulling the fuse is now mentioned in the software in one of those "information" windows...they've given up.
      No whine from the pump right now. There's a very slight vibration at full lock which is considered normal according to the manual.
    18. Member
      Dec 3rd, 2011
      02-04-2019 01:28 PM #67
      Personally, I love the sound of my 987.1 with the Tubi exhaust. Check the video out at this website that sells the Tubi for your car:
      https://flat6motorsports.com/product...cayman-boxster
    19. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      02-04-2019 01:55 PM #68
      Quote Originally Posted by JustPassingBy View Post
      Good thing it's not your money, then. And you can move on from this thread.
    20. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-04-2019 02:33 PM #69
      Yeah I remember watching some of your other videos with the Tubi...sounds pretty solid.
      I've noticed some aftermarket options completely change the sound character to the point where it doesn't sound like a Porsche anymore. The AWE is another option I've looked at, but realistically won't be doing this mod for a while unless I find a really good deal on a used one.
    21. Senior Member 6cylVWguy's Avatar
      Jun 14th, 2000
      PA
      Blog Entries
      4
      '18 Jeep SRT; '11 M3 ZCP; '94 SLC
      02-04-2019 06:10 PM #70
      Quote Originally Posted by Numbersix View Post
      Don't mind him, he's just passing by.
      This thread is really starting to deliver! Love the photos of the internal workings of the 987. And bumper plugs---I didn't know these even existed. I book marked these as I have the same issue on the M3.
    22. Member SLVRon's Avatar
      Dec 19th, 2014
      Santa Cruz Mountains, CA
      2019 Jeep Cherokee Trailhawk, 2015 GTI SE LP (gone), 2011 987.2 Cayman, 2006 911 997 C2S (sold)
      02-04-2019 06:37 PM #71
      How many miles on the water pump? My mechanic recommends changing them out on P-Cars at 60k, though he said mine looked healthy when he did a post-purchase inspection on mine at about that mark.
      No Sport button?
      Sent from my Pixel 2 using Tapatalk
    23. Member SLVRon's Avatar
      Dec 19th, 2014
      02-04-2019 06:39 PM #72
      +1 for Dave's exhaust, and whatever witchcraft has been applied to the suspension on his...
    24. Member NailsInOurBacks's Avatar
      Jan 26th, 2005
      Corona, CA
      '17 Volt, '16 RDX, '07 911
      02-04-2019 07:03 PM #73
      I bought a Foxwell NT520 Pro for the oil reset, but it doesn't do it. Now it's an expense DME report reader.
      Can you elaborate on the fuse trick?
    25. Member
      Dec 3rd, 2011
      02-04-2019 07:09 PM #74
      Quote Originally Posted by SLVRon View Post
      As for the witchcraft, unfortunately, TPC Racing no longer sells the suspension for the 987.1. It was their highest level upgrade (prior owner put in on there) and it was called the "Stage 4 Suspension" and it included JRZ RS Pro Adjustable Dampers, TPC Racing Adjustable Sway Bars, TPC Racing Adjustable Toe Links, and TPC Racing Adjustable Drop Links.
      For kiznarsh, I think the PSS9 Billstein coilover setup would be great! Adjustable height, better dampers, etc. Add GT3 adjustable sway bar with drop links and adjustable toe links, then GT3 lower control arms (to shim for more negative camber), get a good alignment specialist to dial it in and the Cayman handles as well as anything on the road at 5x the price
    26. Planters (fasciitis) peanuts. Dang dogg Sold Over Sticker's Avatar
      Nov 28th, 2009
      02-04-2019 07:15 PM #75
      We still gotta swap keys Dave, and find an empty road. The only time I drove your Cayman I felt like I was driving through the Tour De France.
      Driving While Awesome Podcast. Give it a listen.
      Quote Originally Posted by Phillie Phanatic
      SoS - please shoot a message when Brendan & His Retarded Sycophants has another gig. I’ll be there, front row.
