VWVortex.com - Ace of Base: The Cayman Chase
    The Car Lounge
    Page 4 of 7 FirstFirst 1234567 LastLast
    Results 76 to 100 of 152
    Thread: Ace of Base: The Cayman Chase
    1. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-04-2019 09:58 PM #76
      Quote Originally Posted by SLVRon View Post
      How many miles on the water pump? My mechanic recommends changing them out on P-Cars at 60k, though he said mine looked healthy when he did a post-purchase inspection on mine at about that mark.
      No Sport button?
      It's the OG water pump as far as documentation goes. Knowing me, I'll probably replace it for peace of mind and try to flush as much of the coolant as possible as no documentation on when (or if) that was done.
      Hey...no sport button only means 1 thing: it's always in sport mode.
      Quote Originally Posted by NailsInOurBacks View Post
      I bought a Foxwell NT520 Pro for the oil reset, but it doesn't do it. Now it's an expense DME report reader.
      Can you elaborate on the fuse trick?
      Pretty simple really: pull out the fuse for the instrument cluster per the schematic, sing the following: "the humpty dance, is your chance, to do the hump," then reinsert the fuse and you're done. You'll have to reset your clock but you can eliminate that step by performing this at midnight.
      Quote Originally Posted by Dave_Car_Guy View Post
      For kiznarsh, I think the PSS9 Billstein coilover setup would be great! Adjustable height, better dampers, etc. Add GT3 adjustable sway bar with drop links and adjustable toe links, then GT3 lower control arms (to shim for more negative camber), get a good alignment specialist to dial it in and the Cayman handles as well as anything on the road at 5x the price
      Oh is that all? Is that it?
      Appreciate the input. Can't go wrong with the PSS9s...just a question of saving up for them compared to springs which admittedly is more for looks than performance. Which is OK because the car already handles well, but I know it can be improved.
    2. Remove Advertisements
      Advertisements
    3. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      Hot hatchback coupé heaven
      02-04-2019 09:59 PM #77
      Congrats!
      Lots of VW stuff|Rare Scirocco parts!
      The family: 1955 Customline 351C | 1970 TR6 262Olds | 1977 Capri Cologne | 1980 Rabbit AAZ | 1984 C30 350 | 1988 Scirocco 9A | 1988 Scirocco LP7Y | 1992 Pickup 22RE | 1997 D21 KA24E | 2000 Grand Marquis Modular
      Quote Originally Posted by Crimping Is Easy View Post
      You're always better off with a Citroën.™
    4. Member
      Dec 3rd, 2011
      The NATO garage: 3 British, 2 German, 2 American.
      02-04-2019 10:06 PM #78
      Quote Originally Posted by kiznarsh View Post
      Yeah, I was just speaking to Ron's suspension comment. BUT the reality is that you really should do NOTHING to it other than maybe sticky tires. Enjoy it as-is. It is a fantastic car just the way it sits. Personally, I think Toyo R88s and some Pagid pads are the best bang-for-buck simple upgrade you can make to really make the car feel different. But that is just one man's opinion, and a man whose opinion is worth every penny he has charged you for it.
      You know these cars well - so you know the only accessory you really need is the ignition key.
    5. Member mike in SC's Avatar
      Apr 29th, 2004
      The South
      2013 5.0 F-150 1966 MGB 1988 VW Fox Wagon
      02-04-2019 10:20 PM #79
      It seems these Caymen are much more affordable than other Porsche models. Out of my price range, but nice to know they're out there!
      (sheriff)Early, I though you said this was a drug possum.
      (Early) Sure, I drug him from the ditch.
      (sheriff) I wish you told me that before you sold him to me.
    6. Member
      Dec 9th, 2014
      Corning, NY
      2011 Lincoln MKZ AWD
      02-04-2019 10:22 PM #80
      It's not cool because apparently slammed cars on dubs is the way to go, but I'd also leave the springs and shocks alone - and go with front camber plates, a big front sway bar, and a square wheel+tire setup. 17x9 with 245/40 PS4S.
    7. Don't be me. Don't be a 'Rick' Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      2004 E46, 2018 SQ5
      02-04-2019 10:22 PM #81
      I’m rocking Pagid pads on my poor man’s bimmer. Does that make it a true racecar?
      Instagram - efrie004
    8. Member NailsInOurBacks's Avatar
      Jan 26th, 2005
      Corona, CA
      '17 Volt, '16 RDX, '07 911
      02-05-2019 02:20 PM #82
      If that's fuse B1 Electronic Ignition Lock, Instrument Cluster TRM30, Ts Weight Dectection, Connector TRM30 it hasn't worked on the 997. Still comes back with the service reminder.
    9. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      '94 Miata - '16 RAV4 - '10 Prius
      02-05-2019 03:26 PM #83
      Thanks, thanks for that.
    10. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      02-05-2019 03:27 PM #84
      So for Cayman's, 09-12 is the shiz, right?
    11. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-05-2019 03:29 PM #85
      Yeah it was the B1 fuse for me too. How long did you have it removed? I think I left mine out for 20 seconds but someone else did it for a minute.
      This has to be done with the key out of the ignition by the way.
      Oct 18th, 2017
      Saskatchewan
      2012 Cayman, 2018 Alltrack
      02-05-2019 03:57 PM #86
      Quote Originally Posted by Sporin View Post
      Yup! Bombproof engine, 6MT on the base, some hope of playing music from your phone, buttons that don't look like garbage after a couple of years, cool looking head/tail lights and no chunky/angular 981 styling.
    13. Member SLVRon's Avatar
      Dec 19th, 2014
      Santa Cruz Mountains, CA
      2019 Jeep Cherokee Trailhawk, 2015 GTI SE LP (gone), 2011 987.2 Cayman, 2006 911 997 C2S (sold)
      02-05-2019 05:45 PM #87
      PCA - we should all be shopping for a 2009 base Cayman
      https://www.pca.org/news/2019-02-04/...ll-be-shopping
      But we knew that already...
      Sent from my Pixel 2 using Tapatalk
    14. Chili Bigot Seabird's Avatar
      Feb 8th, 2002
      Secret underground lair with machine gun turrets
      392+485=LOL
      02-05-2019 05:59 PM #88
      Wow, you guys weren't kidding. That model year range is nearly impossible to find, especially in Manuel. Sheesh!
      Quote Originally Posted by Col. David Crockett
      I told the people of my district, that, if they saw fit to re-elect me, I would serve them as faithfully as I had done; but, if not, they might go to Hell, and I would go to Texas.
    15. Member Tommietank's Avatar
      Mar 6th, 2009
      Burlington, VT
      2017 BMW i3, 2018 Clarity, 2001 Honda S2000 (sold)
      02-05-2019 09:47 PM #89
      And what is wrong with the 2013-2016 Cayman? Less reliable?
      Slow Car Fast
    16. Member
      Oct 22nd, 2007
      Syracuse, NY
      '17 GTI, '18 F22, '13 E88, etc.
      02-05-2019 09:57 PM #90
      Quote Originally Posted by Tommietank View Post
      Nothing is wrong with the newer one, but the older car is a little smaller and has hydro steering so some prefer it.
      Quote Originally Posted by Seabird
      Due to recession, used cars in general from that period are harder to find as fewer new ones were sold. Given the discretionary nature of luxury sports cars, they were hit even harder.
    17. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-06-2019 12:25 AM #91
      Yesterday's sunset was looking to be pretty epic but I couldn't get to a good place in time.
      Edit: wow, Tapatalk really compressed the hell out of the gif.
    18. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-26-2019 01:54 AM #92
      Got the car tinted a couple weeks ago with my standard choice: 3M Color Stable @ 20%.
      I kept my US Mill Works license plate bracket from my 981, assuming I could re-use it at some point in the future. Turns out the 981 uses a different thread so I had to get a new threaded bolt. Why the change? And why isn't this an international standard for a given class of vehicle?
      Then did some recon underneath the car prior to order cooling system parts. The supply & return coolant hoses looked and felt good, but I still ordered new O-rings since they'll be accessible anyway.
      Not sure what this white residue is...almost looks like dried up soap from an engine bay wash at some point?
      Shifter cables are still in tact! Upgraded ones arrive tomorrow and will likely get installed this weekend.
      Also ordered a bunch of LEDs to modernize the lighting, although I forgot to get ones for the footwells. Natural white for the interior, cool white for the frunk/trunk/license plate.
      Measured the license plate ones just in case prior to ordering. Sometimes the dimensions are off.
      Speaking of which, they were a little too long for the frunk/trunk. They still fit but not neatly.
      For those wondering about the dome/map lights, the tabs are in the front of the housing (towards the frunk) and the plastic cover just pops off to replace the bulbs.
      Glove box light was more complicated with this aluminum cover.
      The ones for the license plate are the most satisfying and really modernize the look.
      Then gave it a quick wash for the first time since I got it. Cleans up nicely.
      I'm starting to warm up to the wheels. I know it'll look a lot better with a drop and eventually I may just get them refinished to go along with new bolts. Or maybe I'll get something else. I don't know, bigger priorities for now.
    19. Planters (fasciitis) peanuts. Dang dogg Sold Over Sticker's Avatar
      Nov 28th, 2009
      02-26-2019 02:41 AM #93
      Looks good! Loving the updates.
      Driving While Awesome Podcast. Give it a listen.
      Quote Originally Posted by Phillie Phanatic
      SoS - please shoot a message when Brendan & His Retarded Sycophants has another gig. I’ll be there, front row.
    20. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      02-26-2019 06:13 AM #94
      The wheels cleaned up nicely!
    21. Member Xanderips's Avatar
      Aug 28th, 2002
      Buffalo, NY
      '12 CC 6mt , ‘07 997tt, ‘16 Yukon, '16 XC90
      02-26-2019 08:00 AM #95
      I can never get enough of seeing other people’s love for Porsches. Thanks for sharing it with us!
      I think I might try out the LED license plate bulbs on mine. Thanks for the extra info on that.
      X...
    22. Member KingUnderpants's Avatar
      Sep 8th, 2004
      Ontario, Canada
      1996 Porsche 911, 2006 Acura CSX
      02-26-2019 09:29 AM #96
      Looks great... I'm really getting the itch to buy a 987.2 base for a track car.
    23. Member
      Oct 18th, 2017
      Saskatchewan
      02-26-2019 09:35 AM #97
      Quote Originally Posted by KingUnderpants View Post
      There's one on BAT right now...
    24. Member Smooremin's Avatar
      Jan 10th, 2006
      Chicago, Il
      16v I4, Supercharged V6, Gas drinking V8, High revving V10
      02-26-2019 10:17 AM #98
      Asking OT for relationship advice makes about as much sense as asking TCL what car to buy.
      Quote Originally Posted by ChillOutPossum View Post
      About 5 oclock I realized I needed to go to Costco for some white people stuff.
    25. Don't be me. Don't be a 'Rick' Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      2004 E46, 2018 SQ5
      02-26-2019 10:59 AM #99
      This.
      What do you use to clean them? Regular soap and water, or do you have a wheel cleaner you like? The front wheels on my car get caked within a few days of washing them, and it's incredibly difficult to get it all off with regular soap and water.
    26. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2
      02-26-2019 11:42 AM #100
      Quote Originally Posted by Xanderips View Post
      X...
      It's a great upgrade and you don't get any errors in the dash since these are CAN Bus bulbs.
      Quote Originally Posted by Cabin Pics View Post
      This.
      I've used Sonax before and still consider it to be good, however lately I've just been using soap & water. I've noticed some degradation of previous wheel finishes but that was probably due to brake dust and not the Sonax. Then again, I never let the dust cake on there for months at a time.
      I say go with Sonax and rinse with warm water if you can, then apply wax, then you should be good to go with just soap and water (preferably warm).
