VWVortex.com - 6th Gear WOT/Near-WOT Slipping/Sputtering?
    Results 1 to 24 of 24
    Thread: 6th Gear WOT/Near-WOT Slipping/Sputtering?
    1. Junior Member
      Jan 20th, 2014
      Tampa, FL
      2016 Golf R
      02-10-2019 12:55 AM #1
      Hi all. I'm hoping someone can enlighten me with an issue I'm experiencing. It is easily repeatable on the highway and only seems to occur in 6th gear at WOT or near-WOT. If it wasn't for the lack of a flashing CEL and the fact it doesn't feel as "aggressive", I'd suspect a misfire, but you can really hear the turbo sputtering and there are "bumps" in power when it happens, if that makes any sense - almost as if the turbo is cutting off for fractions of a second over and over until you let off the gas/decrease the aggressiveness of the acceleration. In any other gear, it pulls strong and smooth without issue. The issue is noticeable enough to where my wife (who is by no means a car person) can detect the sensation and inquire as to what's happening.
      I've tried searching for similar issues but I can't seem to pinpoint the answer, or even someone who describes this exact problem. I realize it's generally not advisable to floor it in 6th, but I'm talking speeds of 75+ and considerable RPM (3K+), so I don't suspect it should be different than flooring it in any other gear at safe/appropriate engine speeds.
      Could this be, in fact, a spark plug/coilpack issue, or more likely a turbo issue, given the description? I'd be happy to provide further details - not sure if I'm covering everything. Thanks to anyone who chimes in; maybe this post can help someone with the same issue.
      The car is a 2016 6-speed manual with an aftermarket Sachs clutch kit, running APR's Stage 1 high-torque tune (I believe) - if that's of any interest.
      Thanks!
    2. Remove Advertisements
      Advertisements
      May 27th, 2012
      Chicago North Shore
      2016 base R LGM 6MT
      02-10-2019 07:39 AM #2
      Your aftermarket Sachs clutch is slipping.
    4. 02-10-2019 08:25 AM #3
      Quote Originally Posted by emanteno View Post
      This ^
    5. Remove Advertisements
      Advertisements
    6. Member Jlove8128's Avatar
      Feb 22nd, 2007
      Philly Burbs
      2011 4 door manual GTI
      02-10-2019 08:28 AM #4
      This. What you described is exactly what my MK6 did in higher gears when the stock clutch finally started to go.
    7. Junior Member
      Jan 20th, 2014
      Tampa, FL
      2016 Golf R
      02-10-2019 10:05 AM #5
      Wow, I admit I'm a little surprised to hear this. I don't really ever launch the car, but if I want to move quickly from a stop, I never experience any issues. Like I said, it pulls just fine and the clutch seems to grab well in pretty much any gear except 6th WOT. Does anyone know if the car would log something like a slipping clutch in its error code/faults database?
    8. Member Diggs24's Avatar
      Sep 24th, 2015
      2015 GTI; 2003 Saab 9-3 SS
      02-10-2019 10:09 AM #6
      You should never go WOT in 6th. You ruined it.
      ED Moose ECU tune / ED DSG Stage 2 tune / Tomioka IHX475 Turbo / IE Intercooler / MAP cat+res Downpipe / Autotech HPFP / Precision Raceworks 450 LPFP
    9. Member Jlove8128's Avatar
      Feb 22nd, 2007
      Philly Burbs
      02-10-2019 10:11 AM #7
      Quote Originally Posted by Diggs24 View Post
      Lol
    10. Member Jlove8128's Avatar
      Feb 22nd, 2007
      Philly Burbs
      02-10-2019 10:13 AM #8
      Quote Originally Posted by MaDMvD View Post
      What is TQ limit for the clutch? Was it just a drop in? It usually starts in higher gears like 5/6.
    11. Member MiamiBourne's Avatar
      Jan 9th, 2010
      Brooklyn, NY
      16 Golf R Oryx 6spd
      02-10-2019 10:44 AM #9
      Not sure if that's the reason but...well it's not good to lug the engine and that's probably putting the most load in any situation which will burn out the clutch more quickly than anything
      Thanks!
      Going WOT in 6th gear (edit: at low rpm) or any of the higher gears is bad for the engine and the clutch. Search 'lugging the engine' and you will see why. That may have cause it your issue if it's the clutch slipping.
      Instagram: @miamibournes_golfr
      Golf R Build
      United Motorsport Tuned @28psi 6MT (Launch Control & No Lift Shift)
    12. Member Jlove8128's Avatar
      Feb 22nd, 2007
      Philly Burbs
      02-10-2019 11:01 AM #10
      Quote Originally Posted by MiamiBourne View Post
      Going WOT in 6th gear or any of the higher gears is bad for the engine and the clutch. Search 'lugging the engine' and you will see why. That may have cause it your issue if it's the clutch slipping.
      Lugging the engine and going WOT are two different things. WOT at a low rpm in higher gear “lugging” yes bad. WOT running through the gears not bad necessarily.
    13. Member MiamiBourne's Avatar
      Jan 9th, 2010
      Brooklyn, NY
      16 Golf R Oryx 6spd
      02-10-2019 11:05 AM #11
      Quote Originally Posted by Jlove8128 View Post
      Yes, my bad. I meant to add at low rpm in the higher gearing.
      Golf R Build
    14. Member
      Sep 18th, 2018
      NW CT
      2018 Golf R 6MT
      02-10-2019 12:14 PM #12
      Seem like SB Stage 3 Daily with a pulley is the best set up for a daily/tuned situation?
    15. Member Diggs24's Avatar
      Sep 24th, 2015
      02-10-2019 01:25 PM #13
      Let’s think this through logically. When would you ever be in 6th but not low rpm? Like 150ish? So...almost never.
    16. Member Jlove8128's Avatar
      Feb 22nd, 2007
      Philly Burbs
      02-10-2019 01:34 PM #14
      That’s the problem 85% of our country is of low intelligence. You can’t apply logic when this is the case. I bet you would be surprised how many people go to 6th gear at 40 and floor it rather than down shift when they need to accelerate.
      OP not saying your part of the 85%.
    17. Junior Member
      Jan 20th, 2014
      Tampa, FL
      2016 Golf R
      02-10-2019 03:23 PM #15
      Thanks again for all the responses. For the record, I never "lug" the engine - in 6th gear or otherwise. This problem happens past the 3-3.5K+ RPM range, so if it is a slipping clutch, it's not likely to have been caused by lugging the engine. I *believe* the kit the prior owner installed was the following: https://www.ecstuning.com/b-sachs-pe...089.000126~sa/. I remember him saying it should be good well past stage 2 and preferring a single mass over dual mass flywheel.
      EDIT: Link updated for correct clutch kit.
    18. 02-10-2019 05:06 PM #16
      If it's that Sachs kit, it's a sintered racing clutch, and engagement from a stop would be really on/off and hard to engage smoothly.
    19. Junior Member
      Jan 20th, 2014
      Tampa, FL
      2016 Golf R
      02-10-2019 06:46 PM #17
      Quote Originally Posted by dopo View Post
      I updated the link with the correct Sachs kit: https://www.ecstuning.com/b-sachs-pe...089.000126~sa/
      Here is the Sachs box I was given, with the stock clutch inside:
    20. 02-10-2019 08:47 PM #18
      I think at 80mph the 2016 mt's sit at around 3k rpm? That is a perfectly reasonable rpm to accelerate from, regardless of gear. If the clutch isn't holding in that circumstance, then it's simply too weak for the power output. Get a stronger clutch with some decent overhead I guess.
      It's kind of ridiculous that people here are talking like it's normal to expect to have to treat a clutch like it's made of glass, or that you're "lugging" the engine at 3k rpm.
      Clutch options for this gen are somewhat disappointing.
      Sent from my Pixel 2 using Tapatalk
    21. Junior Member
      Jan 20th, 2014
      Tampa, FL
      2016 Golf R
      02-10-2019 09:07 PM #19
      Quote Originally Posted by McJaggleToes View Post
      I agree on all fronts. I suppose I'm still in denial that popular opinion seems to be a slipping clutch. Assuming it is the culprit, it's otherwise perfect/holds all other gears and never smells burnt, so I guess I'll just take it easy on 6th.
    22. Member clempot911's Avatar
      Aug 8th, 2017
      NY
      '17 Golf R
      02-10-2019 09:12 PM #20
      What is the tach doing when all this is going on? If the clutch is slipping you should see the rpms climb with no (or little) speed change.
    23. 02-10-2019 09:14 PM #21
      I'd be curious to know if the issue persists on warmer days.
    24. Member
      Feb 10th, 2015
      Los Angeles
      R
      02-10-2019 09:33 PM #22
      I agree. DSG here so no skin in the game but is there no puck options unless you go completely custom? I had a 4 puck button sprung in my STi and that thing just grabbed. Had a very stiff travel so had to keep it in neutral a lot but in the end, was worth it every time you banged into the next gear.
    25. Member Ub3rN3rd's Avatar
      Feb 3rd, 2004
      Phoenix
      2003 VW GTI 1.8T, 2017 VW Golf R MT
      02-10-2019 10:37 PM #23
      Clutch slipping. Regardless what you think it is. I had southbend Stage 2 endurance clutch same symptoms. Perfect on gears 1-4 holds great however WOT on 5-6 would get sputtering just described. I was shocked and I didn’t want to believe that it was my clutch but few more miles down the road 4th gear would start randomly giving me the same issue.
      2003 GTI 1.8T Nimbus Grey GIAC Tuned
      2017 GOLF R Deep Black Pearl United Motorsports Tuned
    26. Member TIGSEL's Avatar
      Dec 22nd, 2011
      The other side
      16 VW Golf R MT /// 12 VW Tiguan SEL 4Motion
      02-11-2019 03:17 AM #24
      I wonder if it was installed correctly.
      Quote Originally Posted by Frank Reynolds View Post
      I lubed it up really well. I got it in eventually but it was nothing like how they show in the video. Usually the case, but I'm friggin sore still!
    Similar Threads
    1. Transmission Slipping: 6th gear
      By payday in forum Phaeton
      Last Post: 10-04-2014, 10:19 AM
    2. Replies: 13
      Last Post: 12-29-2013, 09:44 AM
    3. RPM's continue to rise under WOT near redline
      By YukonCornelius in forum Golf IV R32
      Last Post: 11-20-2007, 09:00 AM
    4. WOT Pull then car sputters/dies
      By BORA1point8T in forum 1.8T Engine Forum
      Last Post: 07-23-2007, 05:17 PM
    5. 6th gear WOT question
      By Spax MC in forum 2.0T FSI, TSI, and TFSI (EA113) Engine Forum
      Last Post: 02-22-2007, 02:35 AM
