VWVortex.com - Golf R August 2018 build air intake
    Results 1 to 5 of 5
    Thread: Golf R August 2018 build air intake
    1. Semi-n00b
      Feb 12th, 2019
      South Australia
      2018 VW Golf R
      02-15-2019 08:15 PM #1
      Correct me if I'm wrong and please comment.
      It seems to me that air from both the engine compartment and from the fresh open-air side goes into the intake. Poke around with your fingers, including from underneath to confirm. As engine-side air is hot, I wouldn't have thought it was wanted.
      Is there a valve that chooses where the air comes from?
      VWVortex.com
    3. 02-15-2019 11:56 PM #2
      I can confirm it does on my '15 as well and there's a lot of different opinions as to why that is so I won't offer an opinion on it.
      I know this fits the non facelift mk7s but make sure to confirm it also works for the 7.5s if you do decide to get one.
      https://www.ebay.com/p/Genuine-VW-Go...49/23025440049
    4. Semi-n00b
      Feb 12th, 2019
      South Australia
      2018 VW Golf R
      02-16-2019 03:01 AM #3
      Quote Originally Posted by funnelweb View Post
      Depending on the explanation I'm thinking of heat-shielding the duct, filter box & anything else in the flow path up to the turbo to reduce radiant heat. The benefit will be minimal I know but such tweaks are additive over the long term.
    5. Semi-n00b
      Feb 12th, 2019
      South Australia
      2018 VW Golf R
      02-16-2019 03:21 AM #4
      I have googled and found that the way it is designed is to ensure air gets through if there is a blockage due to snow. As we never get enough snow to worry about in South Australia, maybe it would help a little to use what is described as a "Rear Air Intake Trim Plate"
    6. Semi-n00b
      Feb 12th, 2019
      South Australia
      2018 VW Golf R
      02-16-2019 03:31 AM #5
      Maybe, the hole on the underside is to allow bugs to drop through before they clog the air filter?
