VWVortex.com - 1.8t 20v big turbo kit(longitudinal)
    Results 1 to 1 of 1
    Thread: 1.8t 20v big turbo kit(longitudinal)
    1. 03-07-2019 11:24 PM #1
      https://atlanta.craigslist.org/nat/p...835243492.html
      1.8t 20v big turbo kit was going into a B6 A4.
      Longitudinal bottom mount
      $2200 OBO
      Was in the process of collecting everything to build the motor for my audi, but i sold it before I collected everything, so here it is:
      Comp turbo 5558 billet wheel, ball bearings. Hot side ceramic coated.
      With oil, and coolant lines.
      Precision wastegate(will edit with size)
      Exhaust manifold bottom mount(also ceramic coated)
      Down pipe
      Integrated engineering 144x19 H beam rods.(new, only one rod opened, they’re individually bagged)
      Walbro gsl392 255lph(new)
      TRE performance 8OLB bosch injectors
      ARP head studs(used)
      ARP wg hardware(new, opened)
      Grant rings(new)
      Topline main bearings(new)
      Mahle rod bearings(new)
      Random ecu(dont know ANYTHING about this ecu, just throwing that in for free)
      AWP head(used, planned on rebuilding)
      Pictures in the link below
      Update: 3/8/19
      Will part out in the following ways:
      Turbo, manifold, wastegate, downpipe(I’ll throw in all the feedlines i have for it) - $1700
      Turbo, wastegate - $1500
      Manifold, downpipe - $300
      Rings, rod bearings, main bearings and studs - $350
      Injectors - $100
      Fuel pump - $75
      Ecu (will throw in for free if you buy the turbo “package”) - $20
      Head(will throw in for free if you buy the turbo “package”) - $75
    2. Remove Advertisements
      Advertisements
    Similar Threads
    1. FS: Built 1.8t / Longitudinal Big Turbo Kit
      By R30TT in forum Midwest Parts
      Last Post: 05-25-2015, 09:01 AM
    2. Replies: 11
      Last Post: 04-25-2003, 06:44 PM
    3. Replies: 7
      Last Post: 11-06-2002, 05:51 PM
    4. BIG TURBO KIT FOR 337
      By _20VT in forum GTI 337/20th Anniversary/Jetta GLI Forum
      Last Post: 09-11-2002, 12:59 PM
