VWVortex.com - Please tell me the size of my buggy's engine
    Results 1 to 2 of 2
    Thread: Please tell me the size of my buggy's engine
    1. 03-13-2019 04:35 PM #1
      It has 9043 stamped on the pistons! Any help would be great as I want to know the CC and if the heads are stock?
      I pulled the motor apart and there is a 9043 on the piston and here are some pix. Can you tell me what I got please? Also I dont see any head gasket rings anywhere. Is this right? Not any on block or head? Where should it have them?
      https://ibb.co/hBSHS4J
      https://ibb.co/P5D2Rpp
      https://ibb.co/nk9stKh
      https://ibb.co/cxrb25w
      https://ibb.co/dgtbsFy
      https://ibb.co/DP2Jjs9
      https://ibb.co/BTjK1kg
      https://ibb.co/0DNGbdr
    2. Remove Advertisements
      Advertisements
    3. Member Jade Wombat's Avatar
      Oct 20th, 2004
      Houston, TX
      '66 Bus, '08 Volvo S80
      04-04-2019 01:08 PM #2
      It's not good to measure in inches since every reference is metric.
      Without knowing the crankshaft size it's not possible to know the actual engine size, but those pistons are definitely not stock. 3 1/2 inch pistons are probably 90.5mm. Look for an aftermarket model number on the cylinder heads then you should be able to tell what size the valves are.
      https://www.jbugs.com/category/vw-pi...ders-90mm.html
    Similar Threads
    1. Replies: 23
      Last Post: 07-05-2008, 02:57 AM
    2. Replies: 1
      Last Post: 02-23-2004, 01:09 PM
    3. Please tell me the size of the socket used on this bolt...
      By fopeano in forum Golf II & Jetta II
      Last Post: 03-29-2003, 06:08 PM
    4. can someone tell me the size of my brakes? please
      By Wade2Fast in forum Golf III & Jetta III
      Last Post: 08-04-2002, 11:53 AM
    5. Help Please, Can some Please tell me what size the speakers in our cars are?
      By APR310 in forum GTI 337/20th Anniversary/Jetta GLI Forum
      Last Post: 07-16-2002, 02:33 AM
