VWVortex.com - Weird clock problem
    Results 1 to 5 of 5
    Thread: Weird clock problem
    1. 04-14-2019 04:45 PM #1
      I had the battery out of the car for several months while I was rebuilding the turbo and replacing the timing chain in my 08 BPY 2.0T 6MT. Now that the car is back together, the dash clock randomly skips forward and back an hour. I don't see where any liquid got into the clock buttons on the dash. The date is off by about 3 months- just haven't reset it yet. Several times it is advanced an hour when I start the car. I'll correct the time, only to later find it behind be an hour. Really weird. Any ideas about what the cause might be?
      Sent from my SM-G965U using Tapatalk
    3. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      2008 Passat Wagon VR6 4motion, 2013 FIAT 500 Sport
      04-14-2019 08:50 PM #2
      Are you using the same key fob consistently? Each fob gets associated with certain options in the MFD settings menu, date and time being one of them. I discovered this when I turned on DST for the first time, only to find it set back when I used the fob that my wife usually uses.
      - Jeff
      B6 Passat 3.6 & 4motion Resource Thread
      Now: 2008 VW Passat 3.6 4motion Wagon, 2013 Fiat 500 Sport
      Then: 1987 Volvo 745GLE, 1989 Volvo 740GL, 1994 Volvo 940T, 1995 Infiniti G20, 2000 VW Passat 1.8T, 2001 VW Jetta Wolfsburg Ed (x2), 2004 VW Golf TDI, 2006 Jetta TDI
    4. 04-14-2019 11:54 PM #3
      Quote Originally Posted by jddaigle View Post
      That could be it. I'm swapping keys, just grabbing whatever is convenient as this is now me secondary/ daily driver car. I'll have to check the settings to see if there's a difference between keys.
    5. Remove Advertisements
    6. 04-15-2019 05:26 PM #4
      That was it, thanks. The clock doesn't switch until you start the engine, and the DST settings are specific per key. Fixed now, thanks
    7. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      Yesterday 05:50 PM #5
      Quote Originally Posted by Sandman333 View Post
      - Jeff
    Similar Threads
    1. weird steering problem
      By Chapel in forum Golf I & Jetta I
      Last Post: 10-16-2006, 02:32 AM
    2. Digital clock problem
      By webbman3 in forum Golf IV & Jetta IV
      Last Post: 10-31-2001, 10:04 PM
    3. Weird electrical problem! HELP!!!!!
      By BiH in forum Golf III & Jetta III
      Last Post: 10-31-2001, 02:47 PM
    4. Weird Idle Problems!! Audi 2 litre
      By Mr Tambourine Man in forum 2.0 Liter Engine Forum
      Last Post: 10-18-2001, 06:20 AM
    5. put on 11.3's on my A2...weird brake problem now..
      By VRpoweredA2 in forum Golf II & Jetta II
      Last Post: 10-12-2001, 03:13 PM
