VWVortex.com - Fuel Pressure Codes? Before you start replacing hpfp, modules and sensors check your idle stabilization to verify your chains/guides/sprockets are good
    Results 1 to 4 of 4
    Thread: Fuel Pressure Codes? Before you start replacing hpfp, modules and sensors check your idle stabilization to verify your chains/guides/sprockets are good
    1. Member G60ING's Avatar
      Jun 27th, 2000
      Alexandria, VA
      2010 3.6 4-Motion CC, 1990 G60/TDI/R36 Corrado
      04-30-2019 11:18 AM #1
      I’m sick of seeing people trying to repair their fuel pressure codes by parts swapping the high pressure fuel pump, sensors, fuel pump module and so on when it’s really just a timing wear issue.
      So check vagcom measuring blocks 208 & 209. If out more than +/- 8* you need to pull the engine and or transmission and replace the chains & guides and should change sprockets and even the hpfp sprocket (it suffers wear on the lobe
      Here is what Ross-tech says to check: http://wiki.ross-tech.com/wiki/index...3/P1025/004133
      Now stop going to the junkyard and butchering the 3.6 harnesses to get hpfp and sensors out that won’t fix your timing chains & guides.
    3. 05-10-2019 08:26 AM #2
      If what's out by +/- 8*?
      Had some concerns about this last year. Especially the chain guide wear.
      I removed the valve cover to take a look, the top end looked fine at 90k
    4. Member G60ING's Avatar
      Jun 27th, 2000
      Alexandria, VA
      05-14-2019 07:27 AM #3
      Quote Originally Posted by Magnetchief174 View Post
      If you are out you need to replace the chains and guides.
    5. Remove Advertisements
    6. Member G60ING's Avatar
      Jun 27th, 2000
      Alexandria, VA
      05-14-2019 07:33 AM #4
    Similar Threads
    1. Replies: 9
      Last Post: 12-25-2004, 03:18 PM
    2. Replies: 4
      Last Post: 02-17-2004, 10:28 PM
    3. Replies: 39
      Last Post: 09-01-2002, 05:05 PM
    4. Before you started, MSF class yes/no???
      By master-p in forum Motorcycle and ATV
      Last Post: 07-24-2002, 02:47 AM
    5. Read the procedure BEFORE you start wrenching!!!
      By SidVicious in forum Golf I & Jetta I
      Last Post: 04-14-2002, 10:05 AM
