VWVortex.com - Mk1 lowering/stance issues
    Results 1 to 9 of 9
    Thread: Mk1 lowering/stance issues
    1. n00b
      May 12th, 2019
      Vancouver
      83 mk1 GTI
      05-12-2019 05:47 PM #1
      I have recently installed coil overs and camber plates on my mk1. I have OZ racing Supertourismo 16x7 wheels, 37 offset. I can’t seem to get the car anywhere near low enough ( top of tire about 2cm below fender currently ) without hitting the bump stops and ending up with a horrible ride. Is it safe to cut some of the bump stop out to go lower and still have some shock travel?
    2. Remove Advertisements
      Advertisements
    3. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '17 R
      05-12-2019 05:54 PM #2
      Stance, already disqualified for any help
      Sent from my SM-N950U using Tapatalk
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    4. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      05-12-2019 06:00 PM #3
      Secondly, ride height doesn't correlate directly into handling/steering/grip. 16" wheels are big wheels for mk1 race car. What tires? What brakes? What class? SCCA,NASA? Struts in front, shocks in rear and iit would be called travel. What "coils"?
      Sounds more like a street car with a dangerous cage that wants to be a scene car to get attention. Educated guesses here. Bump stops have a purpose, if it's a race car, you're looking for performance far more than comfort. So remove 50%of the bump stops, but you shouldn't be tucking and have vertical control arms of you're looking for function.
      Care to rephrase your cars purpose and your intentions?
      What vegeta said.
    5. Remove Advertisements
      Advertisements
    6. Member jiffyjetta's Avatar
      Mar 13th, 2010
      Oregon
      MK7 Golf Sportwagen, MK6 GLI
      05-12-2019 06:47 PM #4
      https://s-pautomotive.com/product/mk...with-bearings/
      You need drop plates and raised strut mounts. I ran them on my mk1 so I could properly fit 175/50/13 with no fender gap. It actually rode well considering how low it was. Mainly because I didn't have to crank the coilovers all the way down.
      Don't cut your bump stops and crank the them all the way down, it will ride like **** and blow the strut out.
      Tuned mk6 2.0t CBFA 6 speed ECU for sale. Launch control set @ 3800 & 8psi, immobilizer delete, cat delete, air pump delete. $300 shipped.
    7. 05-12-2019 07:29 PM #5
      Could you cut the bump stops? Yes. Should you? If you do, you run the risk of allowing the suspension to compress too much when you hit a bump. Damage usually occurs.
      Sadly, VW did not allow that much suspension travel so when you start reducing it, there is even less. Changing the strut mounts will allow you to lower the car and still have some travel.
    8. n00b
      May 12th, 2019
      Vancouver
      83 mk1 GTI
      05-12-2019 08:37 PM #6
      Full disclosure I purchased this car already converted into a “race car” and yes it does get a lot of attention, thanks. I changed out the Bilstein struts with lowering springs to coil overs for looks alone. I understand that I’m not going to get track performance and that’s not what I’m trying to accomplish. I want a slightly lower ride height with safe and reliable performance for daily driving. Cheers
      Aug 29th, 2012
      Ridgecrest, CA
      84 Rabbit GTI
      05-12-2019 09:12 PM #7
      Raised strut mounts are the way to go with coil overs if you want a somewhat enjoyable ride with the stance you’re trying to achieve.
    10. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      05-12-2019 09:37 PM #8
      Buy real suspension, height adjustment separate from travel.
      What vegeta said.
    11. Member rabbitnothopper's Avatar
      Oct 19th, 2009
      WASHINGTON
      RIP81. 78 VW Rabbit 1.5L EH 4speed 020 GC->GP, 82 Rabbit Pickup 1.6D
      05-13-2019 06:39 AM #9
      every suspsension ordered includes a free flatbrim hat
    Similar Threads
    1. Lowered MKIV issue.
      By Mindflux in forum Suspension Tuning
      Last Post: 06-02-2003, 09:47 PM
