VWVortex.com - Why, oh why, can we not find a DMF clutch that handles Stage 3
    Results 1 to 14 of 14
    Thread: Why, oh why, can we not find a DMF clutch that handles Stage 3
    1. 05-18-2019 03:29 PM #1
      For the mechanics amongst us this has bothered me for quite a while: Why is it that when our upgraded clutch options all are of the SMF variety and carry with them the attendant NVH issues?
      I mean, you don't ever hear about chatter or gear lash in a 911 turbo which means that the OEM clutch is a DMF rated to 500+ hp. Or they use some SMF variant that possesses magical dampening characteristics.
      Consider this an opportunity for education, and thanks
      Quote Originally Posted by gwmermel! View Post
      Sorry for being an idiot. Send your sympathy to my wife......
      2017 LSG/ DG short shifter/ Raceseng knob/ Stratified Cobb tune/ MSS track springs/ DKM Twin Disc/ CTS Intake,IC,DP/ Revo engine/tranny mounts/ hp-lp fp/ Eqt Vortex turbo.
    2. Remove Advertisements
      Advertisements
      Dec 4th, 2016
      Marietta GA
      16 VW Golf R MT
      05-18-2019 04:59 PM #2
      https://www.hstuning.com/rsr-hybrid-...k7-golf-r.html
      '16 Golf R MT, DP, BCS Exhaust, Unitronic Stage 2, JB4
    4. 05-18-2019 06:25 PM #3
      Quote Originally Posted by rodacollier View Post
      I would have gone with the RSR hybrid. But they themselves have a disclaimer about going with either the DKM or Sachs stage 3 if going part stage 2. Which means I wouldn't even trust it at stage 2
      Sent from my Pixel 3 XL using Tapatalk
    5. Remove Advertisements
      Advertisements
    6. Member
      Dec 4th, 2016
      Marietta GA
      16 VW Golf R MT
      05-18-2019 07:02 PM #5
      Can you put a link to where you are reading this ? I only see a drag note.
      The hybrid clutch says “
      We recommend this clutch for all high output MQB cars, and FSI / TSI cars that have turbo upgrades.”
      https://www.hstuning.com/rsr-hybrid-...ategory_id=243
    7. 05-18-2019 07:25 PM #6
      SPEC makes a few and Sachs has a 4 puck, the custom built SPEC one for HPA is what I have my eye on.
    8. Junior Member
      Jan 21st, 2018
      Detroit, MI
      2017 Golf R
      05-18-2019 07:40 PM #7
      Quote Originally Posted by o1turbo20v View Post
      I came from a platform where SPEC had a 100% failure rate, and they claimed installation error. (springs and rivets fall out)
      Don't walk, but run from spec.
      2017 Golf R Lapiz Blue MT6
    9. 05-19-2019 01:07 AM #8
      Sachs also has a 6 puck doesn't it? And aren't those SMF with chatter etc?
    10. 05-19-2019 01:25 AM #9
      Interesting. The warning used to apply to upgraded turbos. When I was planning Stage 2 and choosing my clutch last fall the Hybrid was high on my list. But when I talked to them about it I was told to go Sachs or DKM ie, the language that now is limited to just drag use.
      The RSR Hybrid was pretty new back then and was developed because they had a bunch of failures on the original RSR that were installed in Stage 2 cars. Maybe they have removed the cautionary language because it's held up to their continued testing?
    11. 05-19-2019 09:22 AM #10
      No, Both Sachs and spec make ones for use with the stock DMF. The Sachs 4 puck has the highest TQ rating, Sachs also makes a standard clutch disc rated at or around 415ftlbs. spec come in a variety of TQ capacities, where as the spec/HPA is only available in a stage 3.
      Oct 14th, 2014
      Fort Wayne, IN, USA
      1996 BMW M3; 2015 Golf R; 2018 Audi Q5
      05-19-2019 11:27 AM #11
      It's not just a question of the clutch disk itself, but also of the clamping force provided by the pressure plate. As a DSG owner I've had no reason to research this for my R, but on my M3 track car I have an uprated friction disk, plus a Sachs Racing pressure plate that offers a higher clamping force. Of course the clutch pedal effort gets increased commensurately, but you soon get used to that.
      Neil
    13. 05-19-2019 12:17 PM #12
      Thanks for the info. Seems the 4 puck can be used with either a DMF or an SMF. I had only known about the SMF option.
      However as I read people's experience with it there are still issues (noises, engagement, etc) that you just don't hear about in those Turbo S's etc. The guy over at the BMW forum (https://www.e90post.com/forums/showthread.php?t=753877) removed his 4 puck after 2 years because it was too fatiguing to use as his daily driver.....
      I suppose another way to put it:
      What clutch is standard in a manual Porsche, and how does the design compare to our options?
    14. Member lcubed's Avatar
      Mar 4th, 2015
      2016 LSG R 6MT/DCC/NAV
      05-19-2019 02:27 PM #13
      it seems that particular setup was modified for more clamping force over the 'stock' 4 puck setup by the installer and
      was used for drag racing. seems overkill for street driving.
    15. Member
      Jan 5th, 2012
      Nova Scotia
      '16 Golf R, '01 VRT Jetta 4-Motion, '86 VRT Coupe
      05-24-2019 02:38 PM #14
      Clutch Masters makes clutches for the DMF.
      I have the FX350 and plan to go Stage 3, they also have the FX400 available if you want a little more.
      http://www.clutchmasters.com/fx350-17450-hdff-r/
      http://www.clutchmasters.com/fx400-17450-hdb6-r/
      http://www.clutchmasters.com/fx400-17450-hdbl-r/
    Similar Threads
    1. oil pressure gauge DIY/why can i not find one
      By bluntman220 in forum Golf III & Jetta III
      Last Post: 03-16-2009, 11:03 PM
    2. oil pressure gauge DIY/why can i not find one
      By bluntman220 in forum 2.0 Liter Engine Forum
      Last Post: 03-16-2009, 07:47 PM
    3. Why can I not find any downpipes?
      By nidex in forum A4, S4, RS4 (B5)
      Last Post: 08-31-2006, 03:28 PM
    4. Why oh why, Ford? Why oh why...
      By theskippur in forum The Car Lounge
      Last Post: 04-01-2006, 09:27 PM
    5. Why can I not find a slammed MKIV with 16's on it?
      By Wilbur the pig in forum Golf IV & Jetta IV
      Last Post: 12-08-2005, 02:54 PM
