VWVortex.com - 8.5" wheel, rubbing @ stock height?
    Results 1 to 13 of 13
    Thread: 8.5" wheel, rubbing @ stock height?
    1. 06-09-2019 01:25 PM #1
      Considering new wheels and upsizing to 19/8.5". Would like to go wider without spacers. I am at Stock height.
      I do not want any issues with rubbing.
      Are there specific tire sizes that work for you?
      Quote Originally Posted by gwmermel! View Post
      Sorry for being an idiot. Send your sympathy to my wife......
      2017 LSG/ DG short shifter/ Raceseng knob/ Stratified Cobb tune/ MSS track springs/ DKM Twin Disc/ CTS Intake,IC,DP/ Revo engine/tranny mounts/ hp-lp fp/ Eqt Vortex turbo.
    2. Remove Advertisements
      Advertisements
      Aug 10th, 2016
      The Nation's Capital
      2017 Golf R
      06-09-2019 04:10 PM #2
      You'll be 100% fine with 19*8.5. Stick with an offset around 45.
      For tires, 235/35 is standard. 245/35 for a bit more meat. Either will be A-OK.
      Sent from my ONEPLUS A6003 using Tapatalk
      '17 Oryx R DSG | APR Stage 2 93 HT v2.6 | APR TCU | APR DP | APR Intake | APR IC w/ boost pipes | APR Exhaust w/ AWE remote | APR A01 Wheels 19x8.5 | Ed's Reps 7.5 tails
    4. 06-09-2019 07:45 PM #3
      Would 245/40 work as well?
      Looking for a little more sidewall if it'll fit.
      Thanks
    5. Remove Advertisements
      Advertisements
    6. Member
      Aug 10th, 2016
      2017 Golf R
      06-09-2019 07:59 PM #4
      Thanks
      245/40 will be too much tire for a 19" setup. If you want that much tire you're better off with an 18" setup using that size.
    7. Member ChosinChibana's Avatar
      Jun 30th, 2007
      Lansing, MI, USA
      2009 Mazda RX-8, 2014 Mazda3s (2.5L) hatchback
      06-09-2019 08:16 PM #5
      Quote Originally Posted by biglilsteve View Post
      Yep. Mine rubbed. I went back to the OEM tires.
      2018 Tornado Red 2018 DSG Golf R
      2014 Mazda3 hatchback (now my son's car)
      2013 Lincoln MKX (wife's car)
    8. Member 83gtifast's Avatar
      Jul 25th, 2006
      Edmonton, Alberta, Canada
      2019 Golf R - DBP
      06-09-2019 09:54 PM #6
      Would my stock wheels off of my 337 GTI be ok? They are BBS RC’s 225/40/18’s.
      Would width be an issue?
      I kinda want to just put em on and see what it looks like, lol.
      1983 MKI Rabbit GTI - Black
      2002 MKIV GTI 337 - Reflex Silver
      2019 MKVII Golf R - Deep Black Pearl
      Jan 5th, 2012
      Nova Scotia
      '16 Golf R, '01 VRT Jetta 4-Motion, '86 VRT Coupe
      06-10-2019 09:12 AM #7
      Quote Originally Posted by 83gtifast View Post
      Would be a different bolt pattern (5x100), would require an adapter.
    10. 06-11-2019 05:17 AM #8
      New 2019R, coming from muscle car world and loving the change!
      My question is will I rub moving to an 18x8.5 Titan7 T-55 wheel with DWS-06 245/40/18
      Thanks
    11. Member
      Aug 10th, 2016
      2017 Golf R
      06-11-2019 05:48 AM #9
      Quote Originally Posted by Greenmtn View Post
      Thanks
      No sir. That's a good spec.
      May 18th, 2002
      Tampa, FL
      '97 Jetta VR6, '04 TR R32, '16 Oryx R
      06-11-2019 10:31 AM #10
      Thanks
      you should have no issues. i'm running PS 4S 245/40/18on a 18 x 8 et 45 and lowered. no rubbing for me. I also did the fender liner screw mod as a precaution.
      Quote Originally Posted by PowerDubs View Post
      You can't see your engine bay while you drive, and popping your hood in a parking lot to show off parts is as stupid as listing them in your signature.. (not what the parts were intended for).
    13. 06-11-2019 02:35 PM #11
      Thoughts on a 7.5x18 rim vs an 8x18 for the 2019R
      Saw an older set of 18 Laguna GTI wheels that look very nice, just not sure what I am giving uo going down to a 7.5
      Name:
      LAGUNA Style
      Size
      18X7.5"
      Bolt Pattern
      5X112MM
      Offset
      45MM
      Color:
      MACHINE FACE W BLACK INSERTS
      Hub Bore Size:
      66.56MM
      Quantity:
      1 Set (4 Wheels)
      Condition:
      Brand New
      Part No:
      W640BMF1875.45
    14. Member
      Aug 10th, 2016
      2017 Golf R
      06-11-2019 09:22 PM #12
      Wouldn't go with a 7.5" wheel. 8" min in my opinion. Also would need hub centric rings since our hub is 57.1mm.
    15. Member
      May 27th, 2012
      Chicago North Shore
      2016 base R LGM 6MT
      06-12-2019 11:09 AM #13
      Thanks
      I'm running 18 x 8.5 ET45 wheels with Michelin Pilot Sport A/S 3 245/40x18, and had an extremely occasional rub when hitting sharp bumps
      at highway speeds. Some on this forum have mentioned that some Michelins run a bit bigger than other brands in the same size.
      As Skinnersvr6 mentioned, doing the fender screw mod solved my issue. You could put them on, see how it goes, and do the fender screw mod if
      necessary for your setup. Mine is at stock ride height.
