VWVortex.com - Project: 1 whole car out of 2
    Results 1 to 7 of 7
    Thread: Project: 1 whole car out of 2
    1. Junior Member
      May 24th, 2015
      Apex, NC
      1987 vw cabriolet 5spd
      06-11-2019 03:30 PM #1
      So recently suffered some frame damage to my perfectly running 87 cabriolet. Basically a mountain jumped out of in front of me. The passenger side is all bent in on the bottom, the cross frame under the seat is all wrinkled and the top will no longer close.
      I set out to find a donor cabriolet with a good body on it and I found one. It is an 86 and the PO said it didn't run, something fuel injection, and didn't shift right, possible syncronizer issue and the top was in terrible shape. Well I have a perfectly good running drive train and a good top.
      So here is the start of making 1 great cabby out of 2! I will be posting any updates here.
      Sent from my Pixel 2 XL using Tapatalk
      Jun 28th, 2006
      Elizabethtown, PA
      '82 Rabbit 'vert, '03 BMW 325i Touring
      06-11-2019 07:56 PM #2
      The thing that would worry me most about this project is that rusty rear cable channel on the white car. Take your time to deal with that and to be sure you thoroughly inspect the rest of the car for any other areas of rust before proceeding with the mechanical swap. Otherwise it should be pretty straight forward.
      Sent from my SAMSUNG-SM-G930A using Tapatalk
    4. Junior Member
      May 24th, 2015
      Apex, NC
      06-11-2019 11:03 PM #3
      That is also my concern YJSAABMAN. I was originally gonna cut out a section from the red car and weld it in place on the white car but after more thought, I think I'll attempt to fix it with fresh material. I can always go that former route if I botch the whole patching thing.
    5. Remove Advertisements
    6. Junior Member
      May 24th, 2015
      Apex, NC
      06-12-2019 08:15 AM #4
      Got the top off an rear seats out. Need to vacuum all the leaves out if this thing. Maybe pressure wash the inside. I will have to remove the carpets if I decide to do that.
      Got an initial look at the rusty corners, I think it's manageable. They must have installed the top all wrong or something to cause the corners to rust. Any other ideas why it would get rust there? Those spots are the only rust spots in the whole car!
    7. Junior Member
      May 24th, 2015
      Apex, NC
      06-12-2019 10:14 PM #5
      All seats out and vacuumed.
      I also did a quick grind to see more of the rust damage. Definitely not as bad as I thought. Still gonna be quite a bit of work.
    8. Junior Member
      May 24th, 2015
      Apex, NC
      Yesterday 11:36 AM #6
      Test fitting my new 5 point harness racing seat!
      Jun 28th, 2006
      Elizabethtown, PA
      Yesterday 01:14 PM #7
      Quote Originally Posted by Echdaviem View Post
      Get that center of gravity low! Lol!
