VWVortex.com - EARLY cabby parts (1980)
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: EARLY cabby parts (1980)
    1. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      06-17-2019 09:14 AM #1
      Parted out a 1980 Also just a lotta spare stuff. To much to list & couldn't get pics to load so PM me so I can e-mail you pictures.
      KILLER DEALS ON PARTS PICKED UP!
      NO FRONT FENDERS HOOD OR GRILLE
      BODY
      NEW Rocker panel $40
      NEW R/F strut tower repair panel x 2, $20 each
      2 outside Mirror sets:
      1 Pair non painted in REAL nice shape & function well. Glass looks pretty good. $50 for the pair
      1 pair not painted glass blemished but work well. $25 for the pair
      EARLY RH or LH Tail light assy. w/bulb boards. Really nice shape. $30 ea.
      EARLY non painted GTI fender flares $PENDING
      Small early side marker lights, rear $8.00 ea. $14 for 2 w/ harness/ bulb holder
      early Rabbit Fuel inj. badge for trunk $10
      NEW Bag of side trim clips w/seals $15.00
      1 Front t/signal lens, Ft Bumper mounted $10
      Early Tag light lenses $3 ea. 2 for $5
      Early door handle shields REAL nice.$35
      HARADA KL-16F Antenna new in bag $35 FIRM
      Outer door handles Don't have keys for them $25 new $15 used
      Top Boot. Real nice shape. $70 firm
      NEW Black convertible top W/headliner, cable and padding! $inquire$
      INTERIOR
      Two pod woodgrain speedo/tach dash setups One REAL nice & has very clean markings along w/reman speedo w/o miles & trip odo $200
      Window cranks $8 pr. or $5 ea.
      Inner Door Handle assy. Many different style $10 to $20 per set
      5 spd. shift knob Real nice $10
      Door speakers $35
      Trunk Carpet $25
      Early MK1 steering wheel. Black & pretty nice other than 1 small wear spot at top. $35
      LH door upper sill molding. NO CRACKS & clean. $30
      Inner Arm Rests, 2 dr. MINT condition $inquire Some singles mint real nice $15 ea
      EARLY Ashtray assy. Black & pretty clean Can sell with or w/out bezel with gig lighter. With $35 w/out $10
      ENGINE
      1.7 short block $100
      1.8 GTI head $150
      1.8 GTI thin lip air box & controller complete $100
      Pacesetter ceramicoat header w/ exh. attachment used for less than 500 miles $275 (new over $500)
      Volvo Turbo airbox, lower $50PENDING
      SCIROCCO lower air box CIS. REAL NICE w/larger inlet. Nice upgrade $40
      Cam splash shield $10
      2.0 Aluminum V/C (upgrade) w/ bracket for MK1 EARLY throttle cable $40PENDING
      Techtonics Adjustable Cam Gear Nice used $45PENDING
      MK2 throttle body. (Upgrade for all MK1 & basically the same as the Neuspeed upgrade) $40
      Early MK1 distributor. Was originally points(!) but now has a Pertonics set up in it. Comes w/Hi voltage coil $40
      SUSPENSION
      NEW Bilstien struts with Eibach springs kit.(listed for $565 new) $400 + shipping
      Bilstein numbers are as follows:
      34-001370 front
      24-015141 rear
      Eibach springs
      8501101VA
      8510002HA
      These are complete w/bushings.
      GTI sway bars Front & rear. (gotta check on size) Sell for $60 for the setPENDING
      I will list more with prices as I go thru the totes that have it the parts PER FORUM RULES
      Also I AM negotiable & can send out pictures of anything IF you PM me an e-mail address
      I Live in the N.Va area & am available most evenings & weekends I CANNOT ship large items (doors, rockers etc) & prefer pick up. Sorry for that hassle.
      Saved by His grace...........
    2. Remove Advertisements
      Advertisements
    3. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      07-24-2019 10:52 AM #2
      Back from the dead. Hospital stays are a bummer
    4. 07-24-2019 02:54 PM #3
      Any chance you have the tube from the throttle body to mass air flow?
    5. Remove Advertisements
      Advertisements
    6. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      07-26-2019 08:58 AM #4
      Bump
    7. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      07-26-2019 08:59 AM #5
      Unfortunately was no good. Also appears yours is a different style.....FYI I know the rubber boot ends are available aftermarket
    8. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      07-29-2019 06:59 AM #6
      I will be adding to the above list as I go thru things so.....
    9. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      07-31-2019 08:37 AM #7
      Parts added
    10. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      08-09-2019 01:36 PM #8
      Added More bump
    11. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      08-12-2019 01:14 PM #9
      Up
    12. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      08-16-2019 10:17 AM #10
      RISING & all PM answered
    13. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      08-21-2019 01:07 PM #11
      Bumper
    14. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      08-23-2019 08:38 AM #12
      Up again
    15. 08-25-2019 05:48 PM #13
      Quote Originally Posted by All VWs View Post
      Up again
      pm
    16. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      08-26-2019 09:50 AM #14
      replied
    17. Member sehaare's Avatar
      Aug 4th, 2003
      Palatine, IL. But I'll NEVER call Chicagoland home.
      2013 TDI Sportwagen, 81 Rabbit Convertible, 92 Cabby (Daughter's), 98 SUV, 2011 Legacy
      08-26-2019 10:38 AM #15
      PM sent
      Enjoy every sandwich - Warren Zevon
    18. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      08-27-2019 09:01 AM #16
      PM replied & pics sent
    19. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      08-28-2019 08:04 AM #17
      All PMs Replied
    20. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      09-03-2019 08:19 AM #18
      Offers are good...…...
    21. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      09-06-2019 07:30 AM #19
      All PMs replied...…...MAKE OFFERS
    22. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      09-11-2019 08:10 AM #20
      Lotta lookers...………...MAKE OFFER !!!!
      YOU PICK UP? CHEAPER & GOOD DEALS TO BE HAD
    23. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      09-17-2019 09:12 AM #21
      Silver Mirrors sold
    24. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      09-22-2019 06:38 PM #22
      PMs replied
    25. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      09-30-2019 11:01 AM #23
      Still a lot left...……..
    26. Member All VWs's Avatar
      Aug 4th, 2015
      N.Va
      Now searching.....
      10-02-2019 08:03 AM #24
      Keep it up
    27. Member Mr.Nobody's Avatar
      Dec 17th, 2008
      Edmonds,WA
      91' Jetta 8v's of fury, 91' Triple black Cabriolet
      10-03-2019 10:46 AM #25
      I am looking for the plastic cap the covers the heater core in footwell for a non ac car.
      http://pnwfahren.com/
      My car http://forums.pnwfahren.com/showthre...ver-MKII-Jetta
      Quote Originally Posted by J.Knipl View Post
      In Africa a boy kills a lion to prove he is a man. All we have is the heater core replacement. Once you've done it you have crossed over.
