VWVortex.com - ^^ GruvenParts.com: Get your Shift Repair Kits, Billet Crackpipes, and More for VR6!! ^^
    Results 1 to 4 of 4
    Thread: ^^ GruvenParts.com: Get your Shift Repair Kits, Billet Crackpipes, and More for VR6!! ^^
    1. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      06-28-2019 11:47 AM #1
      02A Billet Stainless Steel Short Shifter Bracket
      Replace the weak plastic link in your cable shift mechanism with this one made from Aerospace grade, hardened stainless steel. Reduces side/side shift throw by 35%! This part replaces OEM P/N 1J0-711-256 (1J0711256) an 1H0-711-260 (1H0711260) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6.
      Replaces OEM P/N 1J0-711-256 (1J0711256) and 1H0-711-260 (1H0711260).
      Stainless FWD/AFT Steel Shift Cable Repair Block
      GruvenParts.com is proud to release these solid stainless fwd/aft cable and side/side cable shift repair blocks for cable shift VW vehicles. These parts will quickly replace the weak forward end of the factory fwd/aft and side/side shift cables P/N 1H0711265 (1HO-711-265) where it connects to the transmission linkage. There is no need to source an entire shift cable mechanism (which is very hard to find, and also quite pricey) in the event of a broken fwd/aft or side/side shift cable. And if your cables are not yet broken, throw 1 of each of these in the glove box and be prepared for the inevitable!
      These repair blocks repair the FWD/AFT and SIDE/SIDE cables P/N 1H0711265 (1HO-711-265) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6. Please select the appropriate cable, as the blocks are different.
      Add some indestructible hardware to the factory cable shift mechanism where it needs it most! Buy these parts together and save!!
    2. Remove Advertisements
      Advertisements
    3. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      07-10-2019 02:10 PM #2
      Click Here for MK2/MK3/B3/B4 12V VR6 Cast Aluminum Thermostat Housing Assemblies!
      GruvenParts.com is now distributing these beautiful cast aluminum thermostat housing assemblies for all 12V VR6 engines found in Corrado, Eurovan, Golf/Jetta MK3 and Passat B3/B4 vehicles. This part replaces thermostat housing P/N 021-121-117A (021121117A), adapter P/N 021-121-133D (021121133D), and thermostat cover P/N 021-112-121A(021112121A). Pair this with our billet crack pipes shown below for additional savings and durability !
      This cast thermostat housing assembly includes the main thermostat housing with an integrated crackpipe adapter section and a cast aluminum thermostat cover. All new mounting fasteners, O-rings, and clips are included to complete your installation.
      This cast aluminum thermostat assembly will mate up with the GruvenParts.com billet crack pipes - buy them as a set and save $$ ! You can also choose to buy a new 80C or low temp 70C thermostat with thermostat O-ring.
      NOTE: VR6 housings are individually machined and cleaned of burrs and sharp metal edges from casting process. Your flange may differ slightly from the photos shown
      Product Fitment:
      Volkswagen Corrado VR6 12v
      Volkswagen Eurovan T4 VR6 12v
      Volkswagen Golf III VR6 12v
      Volkswagen Jetta III VR6 12v
      Volkswagen Passat B3 VR6 12v
      Volkswagen Passat B4 VR6 12v
      Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32!
      MACHINED FROM 6061-T651 ALUMINUM TO EXACTLY MATCH OEM PIPE DIMENSIONS - OURS DOES NOT COME WITH CHEAP THIN WALLED TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
      12V and 24V VR6 Coolant Pipes aka Crack Pipes
      GruvenParts.com was the 1st to build this part and it’s what started us off! We manufacture this pipe EXACTLY to match the OEM part shape so there is NEVER a fitment issue. Be careful when considering other billet pipes which do not match the exact shape of the OEM pipe. The fitment of this part is tricky and the shape MUST BE IDENTICAL to the OEM part to ensure correct alignment between the water pump and thermo housing.
      If you have a billet crack pipe in your VR6, chances are it was made by us. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! Our pipe has a modular design which allows you to plug the oil cooler feed line with a ¼ NPT plug if installing an external oil cooler. Ours can also be ordered with a chrome plated drain valve for quick and clean coolant flushes. The pipe can also be ordered with a brilliant chrome finish for those seeking the ultimate engine bay bling!
      If you dont want to do this job again, buy the LIFETIME WARRANTED GruvenParts.com billet CrackPipe !
      Make sure to see our website for the complete installation DIY
      The 12V version replaces OEM p/n 021-121-050C (021121050C) found in 12V VR6 : VW Corrado, Golf, Jetta, Passat, and Eurovan.
      The 24V version replaces OEM p/n 022-121-050 (022121050) found in 24V VR6 : VW R32, Golf, Jetta, Eurovan, EOS, Audi : 3.2L V6 TT and A3
    4. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      07-18-2019 03:18 PM #3
      Looking for parts for your Passat?
      Look no further!
      GruvenParts.com will tend to all your car part needs, whether it be for your Passat or for a wide selection of VW, Audi, and GM cars.
      Contact Us!
      [email protected]
    5. Remove Advertisements
      Advertisements
    6. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      08-07-2019 01:51 PM #4
      Billet 12V VR6 Drive Belt Pulleys - All 12V VR6
      GruvenParts.com offers a complete set of ultra sleek lightweight 12V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 12V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys ARE NORMAL DRIVE (NOT UNDER-DRIVE). These pulleys will not change the speed of the supercharger and will not void any supercharger warranties. Comes with new crank bolt !
      Buy them as a set and save!
      These pulleys replace the following OEM part numbers :
      Crank Pulley : 021-105-243 (021105243)
      Tensioner Pulley: 021-145-299 (021145299)
      Water Pump Pulley: 021-121-031A (021121031A)
      Alternator Pulley: 021-903-119 (021903119)
      Power Steering Pulley : 021-145-255 (021145255)
