VWVortex.com - ** GruvenParts.com: Swaybar End Links, Intake Links, and More for Golf/GTI VI! **
    Results 1 to 5 of 5
    Thread: ** GruvenParts.com: Swaybar End Links, Intake Links, and More for Golf/GTI VI! **
    1. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      06-28-2019 12:55 PM #1
      GruvenParts Billet MK5 MK6 B7 R32/TT Adjustable Front Swaybar Endlinks !
      GruvenParts.com is happy to release these Billet Front Adjustable Swaybar End Link sets to replace OEM P/N's 1K0-411-315R, 1K0-411-315B, 1K0-411-315D, 1K0-411-315J, 1K0-411-315K, 1K0-411-315N, 1K0-411 315P (1K0411315R, 1K0411315B, 1K0411315D, 1K0411315J, 1K0411315K, 1K0411315N, 1K0411315P) for the Audi A3/S3/RS3 (8P and 8V)TT/TTS/TTRS (8J) MK2 and VW MK5 R32, Golf/Jetta MK5/MK6, Passat B7, Eos MKV/MKVI, and Tiguan 1 and 2.
      We start with a center body made from 303 Stainless Steel hex bar to replace the flimsy non-adjustable OEM spaghetti links. We then add super strong 6,000 lbs radial load capacity THK sealed ball joints with a proprietary PEEK liner on either end to provide many years of noise free operation. The THK ball joints have a built in dust boot to seal out the elements and do not require any maintenance. These linkages will not deflect under the hardest track corners and will provide the most accurate handling.
      These THK ends are NOT SIMPLY SPHERICAL ENDS. These are tuned specifically for high vibrations found in swaybar end links using a proprietary PEEK liner not found in lessor ball joints.
      All center sections are powder coated with a thick layer of either Gloss Black or Bilstein Jazz Blue - please choose during check out. Our design allows simple and quick adjustment on the car. Simply loosen the jam nuts at either end and spin the center body portion to lengthen or shorten, then retighten the jam nuts. This adjustable design will provide +/- 1 inch of adjustment on the car, which is enough to handle all lowered (or raised) set ups. You want the stabilizer bar end links to be as vertical as possible, perpendicular to the swaybar itself to avoid any loading in the fwd/aft direction.
      Applications :
      This product comes as a set of 2 adjustable end links and replaces OEM P/N's 1K0-411-315R, 1K0-411-315B, 1K0-411-315D, 1K0-411-315J, 1K0-411-315K, 1K0-411-315N, 1K0-411 315P (1K0411315R, 1K0411315B, 1K0411315D, 1K0411315J, 1K0411315K, 1K0411315N, 1K0411315P)
      Audi TT/TTS/TTRS (8J) MK2
      VW MK5 R32
      VW Golf/Jetta MK5/MK6
      VW Passat B7
      VW Eos MKV/MKVI
      VW Tiguan 1 and 2.
      PLEASE CHECK YOUR OEM P/N BEFORE ORDERING TO ENSURE CORRECT FITMENT.
    3. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      07-10-2019 02:29 PM #2
      Happy Hump Day Everyone!
      Make sure to stop by our website at GruvenParts.com to purchase any of our GOLF/GTI VI products, as well as our multitude of other Volkswagen, Audi, and GM car parts.
      Contact Us!
      [email protected]
      404-556-6663
    4. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      07-18-2019 03:47 PM #3
      VW/Audi 1.8T/2.0T Billet Intake Links !
      GruvenParts.com is proud to announce the release of these billet intake drive unit linkage arms for the VW/Audi 1.8T and 2.0T engines!.
      Ours are Guaranteed for Life! - Would VW / Audi say that about theirs ??!
      This GruvenParts.com billet linkage arm replaces the plastic intake manifold linkage arm found on p/n 06J-133-201-AS (06J133201AS) manifold, as well as manifold part numbers 06J-133-201-AL, 06J-133-201-G (06J133201AL, and 06J133201G).
      As you already know if you are reading this, the OEM linkage arm is made from cheap plastic and becomes very brittle in the engine heat. The linkage arm socket often pops off of the ball on the manifold, rendering the variable intake manifold useless. This in turn causes a check engine light to illuminate as well as poor driveability, reduced power, and reduced fuel economy. Of course VW/Audi will not sell you *JUST* this part, you have to buy and install an entire new intake manifold to replace the cheap plastic linkage arm (with another cheap plastic linkage arm). While the manifold is pricey, the installation of the manifold and the entire manifold gasket set is where it will really cost you – most dealers and shops charge about $1,200 to remove/replace the intake manifold!
      We think having to pay over $1,200 to replace a poorly designed plastic part on your intake manifold is ridiculous (and that’s putting it nicely).
      GruvenParts.com is now producing these linkage arms the way VW/Audi should have: from a solid chunk of 6061-T651 Aircraft Grade Aluminum on a 4 axis CNC milling center. Ours come with a special Delrin insert installed into the machined socket to precisely mate with the ball on the intake manifold. This provides excellent lubrication and unmatched strength. Did we mention Ours are Guaranteed for Life!
      This part can be installed with the manifold on the engine. Unclip the 2 actuator halves and remove the long spring and rubber diaphragm within the actuator. Unclip the useless plastic linkage arm from the manifold ball (if it hasn’t done that on its own already). Reinstall the rubber diaphragm onto our billet link arm, slide it thru the actuator, then firmly snap it onto the ball. Replace the spring and snap the actuator halves together. This should take 10 minutes, and you can do this yourself – no need for $1,000 in labor to replace a whole manifold!
      You asked us for it and we listened. Another great billet replacement part to rid your VW/Audi of the weak plastic parts!
      Applications:
      Volkswagen : Beetle, EOS, CC, Golf and Jetta V and VI, Passat B6, and Tiguan 1 and 2 with the 1.8T or 2.0T engine w/ intake manifold p/n 06J-133-201-AS (06J133201AS), 06J-133-201-AL (06J133201AL), or 06J-133-201-G (06J133201G).
      Audi :
      A3, TT, TT Coupe, TT Roadster 2007-2012 with the 1.8T or 2.0T engine w/ intake manifold p/n 06J-133-201-AS (06J133201AS), 06J-133-201-AL (06J133201AL), or 06J-133-201-G (06J133201G).
    5. Remove Advertisements
    6. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      08-07-2019 02:09 PM #4
      Applications :
      VW MK5 R32
      VW Passat B7
      VW Eos MKV/MKVI
      VW Tiguan 1 and 2.
    7. 10-10-2019 11:42 AM #5
      Applications :
      VW MK5 R32
      VW Passat B7
      VW Eos MKV/MKVI
      VW Tiguan 1 and 2.
