**Prices Lowered AGAIN on 1/25/2020**
Hi Vortex -
**Please email partoutMD@gmail.com for pic requests/price quotes, this will be the quickest response channel**
We are parting out a 2001 Jetta 1.8T Wolfsburg BigTurbo Build / Project Car. Everything from the car is available, and some items will be sold in packages/kits due to their unique and custom design. This is a complete and entire part-out, we can provide nearly every bolt/bracket or part from the car. Please request any items not listed/pictured. We also have MANY pictures of all parts and can send via email.
Cash or Paypal/Venmo accepted. All parts are located in Wheaton IL (Western Chicago Suburb) Shipping available for non-large items. Will consider discounted pricing if you are looking at multiple items and can pick up parts. Shipping will be ground & insured.
Basic Info on Car:
- 2001 VW Jetta Wolfie, 1.8t AWW / 5spd 02J
-Tornado Red Ext. / Black Interior
- Chassis/Body - 110k mi Motor: 15k mi
- Exterior 7/10 - No Rust!!!! NO FLAKING! Tornado Red Paint in Great shape
Engine/Trans Parts & Extras / Mods / Related Parts
- OEM Dogbone with upgraded insert : $15
- SW EGT gauge (no weld on fitting incl.) : $15
Suspension & Chassis:
- 1.8t Front Knuckle Assemblies : $15each
- Front Subframe :$30
- OEM Rear Beam with Bearings/Hubs: $20
- ABS Module/Controller :$20
- Brake Booster and Master Cylinder (Resevoir SOLD):$20 for the combo
- Pedal Assembly, Clutch Pedal :$20
- Steering Column w/ adjustment Lever, Key, and Gauge Cluster : $50!!!!
Exterior - Body & Structure
- Door Hardware/Strikers: $15
- Hood Hinges :$20
- Front Upper Grille (red w/ emblem and hood pull in-tect) :$40
- FR, RR, RL, Rubber Door Seals :$20 Each
- Front Door Felt Seals: $20 Each
- Rain Tray Cowl Cover,and Inspection :$20
- Wiper Motor :$20
- Wiper Arms :$10 Each
- Trunk Lid Seal :$20
- Euro Tail lights with gaskets& bulbs : $40
- Sunroof Assembly & Motor :$40
- Front bumper guides :$10
- Rear bumper guides :$30
- Rear Bumper crash/rebar :$20
- Fuel Door Hatch (TR) :$20
- Rear Wheel Liners (no damage) :$10 each
- Rad Tray/Carrier (no broken tabs, includes hood latch) :$20
Interior
- Dashboard (black) :$40
- FR, FL, RR, RL Door Panels (black/Black, Cloth) :$20 Each
- Heated Seat Switches :$10 each
- Hazard Switch :$10
- ASR Switch :$10
- Relay's - $10ea.
- E-Brake Lever (black and Black): $15
- Rear view mirror and base (Grey):$10
- Panels (Kick and Dash Side Cover) :$5ea
- Front Seat Belt & Tensioners :$10 Each
- Airbag/SRS Module :$10
- Side Impact Sensors:$15each
- Lower B Pillar Trim (both sides) :$10 Each
- Knee Bolster (metal and trim) :$5 Each
- Kickpanels (L&R - under SW):SOLD
- Steering Column Covers :SOLD
- Glovebox (fully functional) :$30
- Dash Bar and brackets (metal) :$25
- Heatecore Assy, and HVAC shrouds :$30
- OEM amplifier mounting tray, Misc Stuff :$5each
- Hood Latch & Pull w/ cable: $10
- Trunk Liner & Hardware w/ Latch :$35
Electrical:
- Chassis Harness (complete includes fusebox) :$100
- Misc plugs/connectors (inquire)
- Dash airbag (passenger) :$20
- Battery relocation cables :$20
- HVAC Controls:$15
- Tweeters :$15 each
- Comfort Control Module (CCM) :$30
- fuel door motor :$30
- Fan Control Module:$10
- Roof Antenna Base: $25
- S2000 threadable antenna :$10
- SW ClockSpring :$50
- OEM Battery Fuse Station w/ fuses :$10
- TurnSIgnal Stalk :$25
- OEM Euroswitch (not Pictured):$15
- OEM Horns : $5ea
Engine: $900 SOLD (Longblock, no fueling)
- 1.8T with IntegratedEngineering Rods, rebuilt head, and re-ringed OE pistons
Transmission - SOLD
Turbo Kit: $1,400 ~350-425 fwhp capable~
- SS Custom Tubular Top-Mount Manifold (T3 Flanged, ExtWG) , AMS cast 4-1 collector
- GT28RS Turbo, with .63 A/R Exh Housing
- Custom Oil Feed, Return, and Coolant feed/return Lines (-4,-6 & -10 AN fittings)
- Custom 2" Intercooler Piping with GReddy Core. Integrated 1.8T MAP Flange
- Forge DV/BOV (atmospheric) and Silicone TB Hose.
- Tial MVS (38mm) Wastegate with 1bar Spring and custom dump pipe.
- 3" Intake with cone filter
- 3" SS Downpipe, V-Band'd w/ 2 O2 bungs, brand new Wideband (Bosch) included
- 3" Midpipe USP/Magnaflow Race Exhaust. O2 ports here as well
- Unitronics 630cc BT File, 93oct - Emission deletes, IMMO Defeated, MAFless file. ($400)
- Siemens 630cc Injectors in Stock Fuel rail. (SOLD)
- 1.8T AWW Engine Harness, with repairs, and added resistors for no CEL (emission deletes) ($60)
- USP Coilpack Repair Kit (BNIB) :$55
- Walbro 255lph in-line fuel pump with relayed harness SOLD
- Raxles 02j "racing" axles : SOLD
- Metal Coolant Flange (bnib) : SOLD
- Moroso Coolant Recovery Tank with in-line Filler neck: $40
- Steering Column dual gauge pod: SOLD
- Greddy Profec II EBC setup :SOLD
- Custom vented catch can setup :$25
- ECS VR6 clutch and single-mass 14lb flywheel : $30
- VF Engineering Engine/Transmission Mounts (no cracks): SOLD
- Stock Shifter Assembly & Cables : SOLD
- H&R Street Perf Coilovers (Ride GREAT) : SOLD
- H&R 25mm Rear Sway Bar (No links) :SOLD
- Front LCA's with r32 bushings installed : SOLD
- 5x100 -> 5x120 Wheel Adapters (20mm): SOLD
- BMW 135 Mesh wheels 17x8, 5x120, w/ blizzaks (old) :$200
- FR, FL, RR, RL Doors : $100 each door ALL SOLD!
- Hood : SOLD
- Trunk Lid : SOLD
- Innovate LC-1 Wideband Gauge & Controller (Needs 6pin OEM O2 Sensor) - :SOLD
- NA Driver side mirror :$40
- Euro Spec Stubby PS Mirror :$50
- Front Valence, 4motion textured black : SOLD
- Front Bumper : SOLD
- Rear Bumper : SOLD
- Front Fenders:
- GLI Headlight Assemblies w/ fogs Sale Pending)
- Gas Pedal Assembly/Motor : SOLD
- VDO Boost / OIl Temp with Senders : SOLD
- Front Wolfie Seats (heated) : SOLD
- Jetta Vents (lit and garage style) :SOLD
- B5 Passat / Euro Amber sidemarkers : $10
Thanks for Viewing, email for any additional pics, questions or shipping Quotes!!
Hi Vortex -
Basic Info on Car:
- Hood Hinges :$20
- Wiper Motor :$20
Interior
- ASR Switch :$10
- Relay's - $10ea.
Electrical:
- HVAC Controls:$15
- OEM Horns : $5ea
----------------------------------------------------------------------------------------------- SOLD ITEMS -----------------------------------------------------------------------------------------------
Transmission - SOLD
- Hood : SOLD
- Trunk Lid : SOLD
- Front Fenders:
