VWVortex.com - ** GruvenParts.com: Front Swaybar End Links, Adjustable Rear Tie Rods, and More for your Vehicle! **
    Results 1 to 5 of 5
    Thread: ** GruvenParts.com: Front Swaybar End Links, Adjustable Rear Tie Rods, and More for your Vehicle! **
    1. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      06-28-2019 01:56 PM #1
      GruvenParts Billet MK5 MK6 B7 R32/TT Adjustable Front Swaybar Endlinks !
      GruvenParts.com is happy to release these Billet Front Adjustable Swaybar End Link sets to replace OEM P/N's 1K0-411-315R, 1K0-411-315B, 1K0-411-315D, 1K0-411-315J, 1K0-411-315K, 1K0-411-315N, 1K0-411 315P (1K0411315R, 1K0411315B, 1K0411315D, 1K0411315J, 1K0411315K, 1K0411315N, 1K0411315P) for the Audi A3/S3/RS3 (8P and 8V)TT/TTS/TTRS (8J) MK2 and VW MK5 R32, Golf/Jetta MK5/MK6, Passat B7, Eos MKV/MKVI, and Tiguan 1 and 2.
      We start with a center body made from 303 Stainless Steel hex bar to replace the flimsy non-adjustable OEM spaghetti links. We then add super strong 6,000 lbs radial load capacity THK sealed ball joints with a proprietary PEEK liner on either end to provide many years of noise free operation. The THK ball joints have a built in dust boot to seal out the elements and do not require any maintenance. These linkages will not deflect under the hardest track corners and will provide the most accurate handling.
      These THK ends are NOT SIMPLY SPHERICAL ENDS. These are tuned specifically for high vibrations found in swaybar end links using a proprietary PEEK liner not found in lessor ball joints.
      All center sections are powder coated with a thick layer of either Gloss Black or Bilstein Jazz Blue - please choose during check out. Our design allows simple and quick adjustment on the car. Simply loosen the jam nuts at either end and spin the center body portion to lengthen or shorten, then retighten the jam nuts. This adjustable design will provide +/- 1 inch of adjustment on the car, which is enough to handle all lowered (or raised) set ups. You want the stabilizer bar end links to be as vertical as possible, perpendicular to the swaybar itself to avoid any loading in the fwd/aft direction.
      Applications :
      This product comes as a set of 2 adjustable end links and replaces OEM P/N's 1K0-411-315R, 1K0-411-315B, 1K0-411-315D, 1K0-411-315J, 1K0-411-315K, 1K0-411-315N, 1K0-411 315P (1K0411315R, 1K0411315B, 1K0411315D, 1K0411315J, 1K0411315K, 1K0411315N, 1K0411315P)
      Audi TT/TTS/TTRS (8J) MK2
      VW MK5 R32
      VW Golf/Jetta MK5/MK6
      VW Passat B7
      VW Eos MKV/MKVI
      VW Tiguan 1 and 2.
      PLEASE CHECK YOUR OEM P/N BEFORE ORDERING TO ENSURE CORRECT FITMENT.
    2. Remove Advertisements
      Advertisements
    3. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      07-10-2019 05:39 PM #2
      Happy Hump Day!
      If you're looking for premium-machined car parts for your vehicle, don't hesitate to visit GruvenParts.com to satisfy all your needs.
      Questions, Comments, Concerns?
      Contact Us
      [email protected]
      404-556-6663
    4. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      07-18-2019 04:51 PM #3
      BPY Engine Upper Rad Hose Billet 4Y Fitting!
      GruvenParts.com is happy to release our Billet Upper Radiator Hose 4Y Coolant Fittings for VW Golf/Jetta/Passat/EOS and Audi TT/A3 with BPY Engine -- P/N 1K0-121-087H (1K0121087H).
      The OEM plastic 4Y connector used in the upper radiator hose is prone to cracking and leaking which often results in a rapid loss of coolant which can permanently damage your motor.
      The GruvenParts.com billet 4Y Pipe is machined from Aircraft Grade 6061-T651 Aluminum, professionally TIG welded, and then pressure checked by our licensed welders. This one will permanently stop the nonsense caused by the VW/Audi cheap plastic coolant fitting.
      This billet 4Y Pipe is intended to replace the plastic 4Y fitting OEM P/N 1K0-121-087H (1K0121087H) found in the upper radiator hose of the BPY Engine Code VW's and Audis :
      VW EOS – 07-11
      VW Jetta – 05-10
      VW Golf – 06-12
      VW Passat – 06-08
      Audi A3 – 05-12
      Audi TT – 07-12
    5. Remove Advertisements
      Advertisements
    6. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      08-07-2019 02:35 PM #4
      2.0T FSI BPY Engine Billet Pulleys!
      GruvenParts.com is happy to announce our billet lightweight alternator and tensioner pulleys for the VW and Audi 2.0T FSI engines! Read at the end for the billet crank pulley that's coming soon!
      Lightweight Billet Aluminum 2.0T BPY Engine Alternator Pulley
      Ditch the super heavy 1 lb clutched alternator pulley on your 2.0T FSI in favor of this 125 gram billet aluminum version designed using high tech CAD software and crafted on one of our CNC's. Ours is precision CNC'd from 6061-T651 aluminum with a total runout of less than .001""! All this means a smoother and quiter engine that revs quicker off idle. Comes complete with high grade nut and thrust washer. Installs quick but please follow all Volkswagen/Audi installation instructions.
      This part replaces OEM P/N 022-903-119C (022903119C) clutch-style(one-way) alternator pulley as well as P/N 038-903-119B (038903119B) solid alternator pulley and fits VW Golf, GTI, Jetta, EOS, Passat and Audi A3, TT with 2.0T FSI BPY Engine code. Please check your OEM part number and check the part interchangeability note at the end of this page.
      Lightweight Billet Aluminum 2.0T BPY Engine Tensioner Pulley
      Plastic may have made the bean counters at VW happy, but it has no business as a tensioner pulley on your high strung VW/Audi 2.0T FSI motor. Ours is extremely light weight and contains a precision 20K RPM SKF bearing that will perform more quietly and far outlast the OEM plastic pulley. Installation is a breeze – simply release belt tension, remove the tensioner pulley bolt, and swap ours in. Note - the torx bolt loosens counterclockwise (normal, right hand bolt). Please follow all Volkswagen/Audi installation instructions for installation.
      This part replaces the pulley found the tensioner OEM P/N 06F-903-315 (06F903315) and fits VW Golf, GTI, Jetta, EOS, Passat and Audi A3, TT with 2.0T FSI BPY Engine code. Please check your OEM part number for verification before ordering!
      Alternator Pulley Part Number Interchange Information
      The GruvenParts.com billet lightweight 2.0T FSI BPY alternator pulley is designed to replace OEM P/N 022-903-119C (022903119C) clutch-style(one-way) alternator pulley as well as P/N 038-903-119B (038903119B). The following part numbers are also interchangeable :
      022903119C ; 021903026A; 021903119G; 022-903-119-A; 022903028A; 022903119A; 028903030; 028903030A; 028903119AL; 028903119AM; 038-903-119-A; 038-903-119-T; 038903023K; 038903023L; 038903023Q; 038903023QX; 038903023R; 038903023RX; 038903024A; 038903024B; 038903024C; 038903024D; 038903024E; 038903024F; 038903024G; 038903119A; 038903119S; 038903119T; 03G903119; 03G903119A; 045903023; 045903023B; 045903023F
      038903119B ; 028-903-119-2; 028903026H; 028903028C; 028903028CX; 028903028D; 030-903-119-D; 030903023H; 030903023J; 030903023L; 030903023LX; 030903119D; 036903024; 036903024A; 036903024AX; 036903024P; 036903026; 036903026A; 036903026B; 037903025E; 037903025EX; 037903025FX; 037903025J; 037903025K; 037903025Q; 037903025R; 037903026C; 06A903026; 06A903026A; 06A903026B; 06A903026C
      022903119C ; 021903026A; 021903119G; 022-903-119-A; 022903028A; 022903119A; 028903030; 028903030A; 028903119AL; 028903119AM; 038-903-119-A; 038-903-119-T; 038903023Q; 038903023QX; 038903023RX; 038903024A; 038903024C; 038903024D
      Billet Crank Pulley Pre-Buy
      GruvenParts is happy to announce the Pre-Buy for the 2.0T FSI billet lightweight crank pulleys! If you want 1, please email [email protected].
      2.0T FSI BPY Engine Billet Crank Pulley!
      This billet crank pulley will reduce the rotating mass by approximately 2.4 lbs (1133 grams) and makes an excellent addition to our other 2.0T FSI engine pulleys.
      The crank pulley is machined from aerospace grade 6061-T651 aluminum on one of our precision HAAS CNC mill lathes to a run out of less than .001"". The pulley includes the factory timing marks and exactly replicates the OEM pulley geometry (NOT under-drive).
      We will begin manufacturing these once we have 10 pre-orders, so get on the list now by ordering in advance.
      This part replaces OEM P/N 06F-105-243H (06F105243H), 06F-105-243J(06F105243J) VW and Audi Crank Pulleys and fits the following vehicles :
      Volkswagen EOS, Golf, GTI, Jetta, and Passat with the BPY Engine Code 2.0T FSI motor.
      Audi A3 and A4 with BPY Engine code 2.0T FSI motor.
      Pre-Release Notes -- Please Read Carefully
      This is a Pre-Release for the crank pulley (all others are in stock). Once we receive 10 paid orders, we will manufacture this part. The lead time to manufacture is 3 weeks once we receive the 10th order. If we do not ever get to 10 orders in a timely manner, we will refund all existing orders. You can check the status of the Pre-Order by calling or emailing us anytime.
    7. 09-06-2019 12:13 PM #5
      A4/S4, A6/S4, Passat, Boxster Stainless Slave Cylinder Bleeder Screws
      GruvenParts.com Introduces Stainless Bleeder Screws for Audi A4/S4, A6/S6, VW Passat and Porsche Boxster!
      Our 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw which Audi and VW provide on their clutch slave cylinder P/N 8E0-721-257F (8E0721257F), 8E0-721-257M (8E0721257M), 8E0-721-257A (8E0721257A), and 8E0-721-257B (8E0721257B).
      How many times have you gone to bleed the brakes on your Audi, Passat or Boxster only to round off the hex on the cheap plastic bleeder screw on your clutch slave cylinder? The problem is corrosive brake fluid actually melts the plastic bleeder screw and bonds it into the slave cylinder housing making it impossible to open. This problem makes it impossible to bleed your brakes properly and causes soft brake and clutch pedals. The only remedy until now has been to replace the entire slave cylinder unit, which is expensive, time consuming, and NOT FUN (to say the least!).
      GruvenParts.com has addressed this problem with our new 303 Aircraft Grade Stainless Steel Bleeder Screws. We machine these in house on state of the art HAAS CNC lathes and mills with custom screw machining capability to exactly match the OEM threads for a perfect fit. These come complete with preinstalled Viton O-rings for maximum life. The hex will never round off or become stuck in the slave cylinder body and you likely will never need to replace a slave cylinder again.
      This 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw found in clutch slave cylinders P/N P/N 8E0-721-257F (8E0721257F), 8E0-721-257M (8E0721257M), 8E0-721-257A (8E0721257A), and 8E0-721-257B (8E0721257B).
      This product fits the following vehicles :
      Audi A4/S4 1996 thru 2006 1.8T, 2.8L, 3.0L. 4.2L including Quattro
      Audi A6/S6 1995 thru 2005 2.7L, 2.7T, 2.8L, including Quattro and Allroad
      Volkswagen Passat 2000 thru 2005 1.8T, 2.8L including 4 Motion
      Porsche Boxster 1997 thru 2004
