Had the intake already installed with no issues, i put on the apr catch can system (super tight install as far as the hoses) and i got a brake/gas pedal vibration. Has to be the hose giving me a vibration transfer since they are pressed up against the brake fluid bottle. I removed the bracket for the 02 sensor connectors and that “helped” i just dont know what to do about the hoses against the brake fluid bottle. Anyone come up with an idea? There supplied hose are stiff as hell and the angle you need to connect it almost makes you question if the connector will break free or break in general.
