VWVortex.com - How to corectly replace oil in gearbox ?
    Results 1 to 4 of 4
    Thread: How to corectly replace oil in gearbox ?
    1. 07-19-2019 06:30 AM #1
      Hello
      I want to replace oil in my ERT gearbox but how to corectly fill up gearbox ? I mean how much oil I should pour into it ? How to check gearbox oil level?
    2. Remove Advertisements
      Advertisements
      May 30th, 2015
      Fort Walton Beach, FL
      2005 mk4 Jetta 2.0L
      07-19-2019 08:11 AM #2
      There are two 17mm hex bolts. One on bottom. One facing the front of vehicle. The one facing front is the fill. It's full when it's starts to come out. Spec is 1.9 liters, but it only counts for gearbox. Depends how well it drains. Have 3 on hand.
      Sent from my SM-S727VL using Tapatalk
    4. Member A-Bugg's Avatar
      Oct 24th, 2000
      Ohio
      20AE GTI, 04Golf Wagon, MK2 golf
      07-19-2019 10:28 AM #3
      Also, remove the fill plug first. It would suck to get the drain out then find out you are unable to remove the fill plug.
    5. Remove Advertisements
      Advertisements
    6. Member
      Mar 20th, 2003
      NJ, USA, Earth
      02 Jetta 1.8T, 90 Corrado G60
      07-19-2019 11:05 AM #4
      Quote Originally Posted by A-Bugg View Post
      This makes the job super easy and not messy. Worth it.
      https://www.amsoil.com/shop/by-produ...tle-hand-pump/
