VWVortex.com - Help identifying vacuum pump check valve
    Results 1 to 1 of 1
    Thread: Help identifying vacuum pump check valve
    1. 07-24-2019 12:04 AM #1
      I have a Tiguan 2.0 TSI.
      Is this the vacuum pump check valve? It's on the large pipe that goes from the vacuum pump to brake booster:
      https://1drv.ms/u/s!AvEMMGITq3yVh9kbrwXu0-dh7havkA
      Or this? It's on the small pipe that goes from vacuum pump to somewhere at front of engine:
      https://1drv.ms/u/s!AvEMMGITq3yVh9kc5e7VRy4eMU5OBg
      EDIT: After further scouring the parts catalogue I think the bottom is the N75 valve. Is the top photo the check valve?
      There's also this right on the pump port:
      https://1drv.ms/u/s!AvEMMGITq3yVh9kLqiO_p0ohBV2epA
    2. Remove Advertisements
      Advertisements
