VWVortex.com - N205 valve removal, won't budge - am I doing something wrong?
    Results 1 to 5 of 5
    Thread: N205 valve removal, won't budge - am I doing something wrong?
    1. Member 20voffury's Avatar
      Jan 28th, 2006
      Seattle, WA
      98 GTI VR6, 2009 GTI
      08-13-2019 07:15 PM #1
      So I just stepped into the 2.0T world from VR6's - I'm trying to change the N205 valve and am having zero luck. I've done extensive searching and everyone makes it sounds easy. I've got the soleniod or whatever out of the way, the indentations for the valve are right there.
      I have the equivalent of the VW T10352 tool, got it on the valve. I know it's reverse threaded (righty-loosey) but when I go to crank down (pretty damn hard too) the entire engine rotates like I'm turning the crankshaft.
      What''s up with that?? It's only supposed to be 25Nm of torque. Am I missing a crucial step?
      Thanks ahead of time.
      09 GTI TSI (which is the EA888 right?) DSG
      right foot = gas, left foot = brake. rally baby
    3. 08-14-2019 11:05 AM #2
      Yes EA888. I just removed mine the other day without the tool. Took a large flat screwdriver and put the edge in the left side hole. Smack the screwdriver to shock the bolts lose. Obviously pushing the bolt counterclockwise. Once it pops lose I was able to turn it out by hand.
    4. Member 20voffury's Avatar
      Jan 28th, 2006
      Seattle, WA
      08-14-2019 02:11 PM #3
      Ok, I was wondering if needed to do some kind of shock to break the seal or whatever. I'll give that a try. It didn't chip/crack the part itself? We are talking this guy right?
    5. Remove Advertisements
    6. 08-14-2019 06:59 PM #4
      Yep that's it. Since you have the tool you might try an impact gun on it.
      Aug 15th, 2018
      Los Angeles, CA, USA
      08-15-2019 05:21 PM #5
      Maybe you can use a counterhold on the crank shft so the engine doesn't turn. I had to do that when I took off the water pump belt pulley bolt.
      https://www.uspmotorsports.com/Crank...Hold-Tool.html
