VWVortex.com - HPFP and LPFP recommendations.....
    Results 1 to 9 of 9
    Thread: HPFP and LPFP recommendations.....
    1. 08-22-2019 02:49 PM #1
      Was planning on running E50 and was told I need to upgrade my HPFP and LPFP, what do the speed gurus recommend for running E50? Also what problems should I expect and what should I look out for?
    2. Remove Advertisements
      Advertisements
    3. 08-22-2019 03:21 PM #2
      Autotech HPFP and GIAC LP kit
    4. 08-22-2019 03:29 PM #3
      Quote Originally Posted by o1turbo20v View Post
      Are you currently running both?
    5. Remove Advertisements
      Advertisements
    6. Member wuZheng's Avatar
      May 14th, 2015
      Toronto, ON, Canada
      2016 VW Golf R
      08-22-2019 08:17 PM #4
      Quote Originally Posted by Dixon7R.5 View Post
      Agreed on Autotech HPFP, a bunch of guys here (geographically, Toronto) run the Precision Race Works LPFP. Could go either way, as long as its a pump that supports E85 and if you don't wanna dive too deep, is supported by the stock pump controller.
    7. Member Diggs24's Avatar
      Sep 24th, 2015
      2015 GTI; 2003 Saab 9-3 SS
      08-22-2019 08:59 PM #5
      What are your plans. e85? big turbo? which tuner?
      ED Moose E50 ECU tune / ED DSG Stage 2 tune / Tomioka IHX475 Turbo / IE IC / MAP cat+res DP / Autotech HPFP / PR 450 LPFP / Uni TIP / EQT TMD and Pipes / NT-05s on Asstins / Full Stealth Mode
    8. 08-23-2019 03:13 AM #6
      Quote Originally Posted by wuZheng View Post
      Will definitely look into them thanks.
      Quote Originally Posted by Diggs24 View Post
      E50 for now, maybe next year or in two years I may go big turbo, but that's down the road a bit.
      Getting tuned by 5150, if they actually reply back...lol
    9. Member Diggs24's Avatar
      Sep 24th, 2015
      08-23-2019 08:33 AM #7
      Then go 450 lpfp and mpi.
    10. 08-24-2019 03:32 PM #8
      what's MPI? Is that multiple port injection? Like Aux fuel? If I did that would I need the HpFP?
    11. Member Diggs24's Avatar
      Sep 24th, 2015
      08-24-2019 04:12 PM #9
      multi port injection
      yes
      yes
      no
