VWVortex.com - HPFP repair kit: What the heck are these?
    Results 1 to 5 of 5
    Thread: HPFP repair kit: What the heck are these?
    1. Semi-n00b bobbytomorow's Avatar
      Jun 13th, 2018
      Vancouver
      2006 Audi A3
      09-01-2019 11:04 PM #1
      When I bought my A3 awhile back I shortly after found out about the cam follower issue, I checked mine and sure enough it was worn through. I replaced the follower then, about 10,000km ago but noticed that the plunger tip was worn a bit (cam lobe looked fine however) and I've since had no problems whatsoever as far as codes or issues with the fuel pump since replacing the cam follower.
      Anyway that brings me to now and I saw on ebay a HPFP repair kid that comes with a new plunger tip so I ordered it at only approx $10. It has arrived along with a new cam follower as well and I want to go and replace both items BUT the repair kit did not include instructions nor are the sellers of any help to me (from china).
      • Maybe someone can tell me what these two things are that were included I can't figure it out?
      • Also the plunger tip looks like it came in 2 pieces is that normal?
      • Thirdly, any idea how difficult it will be to change out the plunger tip?
      Picture of the kit and a picture of the pump tip for reference
    2. Remove Advertisements
      Advertisements
    3. Member Eye Candy White's Avatar
      Nov 8th, 2006
      Cincinnati, OH
      07 GTI : 18 Atlas
      09-05-2019 10:46 AM #3
      Knowing that HPFP's are the one of few things that can submarine this motor, maybe it's just me, but I wouldn't use ebay parts here (or really anywhere on my car).
      Just my $0.02.
      I think there are other re-build kits out there, though the one I was thinking of doesn't appear to be in business anymore.
    4. Remove Advertisements
      Advertisements
    5. Member ROH ECHT's Avatar
      Dec 9th, 2010
      auf Oregon asphalt
      `07 gti K04'd
      09-09-2019 10:37 PM #4
      I have never seen those two crescent pieces when disassembling the hpfp. So...???
      The oem tip is two pieces...this is explained in the vid another provided...above ↑.
      Usually, a bit of wiggling will push the center button enough outward and away from the piston so it can be removed from the button end of the piston. If not, with the piston removed from the pump, set the free end of the piston on a solid surface in a vertical position and grasp the button ring and apply force downward toward the solid surface. This may push upward on the center button so that it can be removed from the piston.
      K04 PLAY...`07 GTI/GIAC K04 & DSG Tunes/AWE DV/AUTOTECH HPFP/TORQBYTE PM3/TTRS LPFP/S3 INJ's&fmic/RS4 fprv/FORGE fmTc, WGA & T-B HOSE/TECH.TUNING TB/BSH Eng.&Trans MOUNT's/NSP BOOST GAGE/AP Lite-PULLEY/NEUS. P-FLO&BOOST PIPES/13.2"BBK/BILSTEIN B8 DAMPERS/W.A.L.K./H&R SS SPRINGS+F&R ARB's/TSW 8X18 NURB's...ZOOM DIS! 2007 Volkswagen GTI : 12.823 @ 112.050 MPH
    6. Junior Member
      Sep 20th, 2011
      Toronto, Canada
      89 Golf,mk3 95 golf 2.0L
      09-15-2019 08:18 AM #5
      I almost bought this. i msged the seller on ebay and its like they have no idea
      If you figure it out i sure would like to know I have the same issue with mine .. still works but urgh I should fix it.
