VWVortex.com - How often do you add oil in the engine? .
    Results 1 to 4 of 4
    Thread: How often do you add oil in the engine? .
      Jan 4th, 2007
      MA
      2004 Jetta GLS 1.8T
      09-02-2019 02:44 PM #1
      I noticed I have to add 12oz of oil every 1250 miles. I don't have any oil leak at all. Valve cover seal and chain tensioner seal was replaced. The only thing I can think of is the valve stem seal. Turbo is new by the way and exhaust gaskets.
      I might have to replace the valve stem seal when the valve cover seal leaks again.
    2. Remove Advertisements
      Advertisements
    3. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '17 R
      09-02-2019 10:08 PM #2
      240k...11 years...486whp. Never have to add oil.
      Sent from my SM-N950U using Tapatalk
      :HOMEGROWN MOTORSPORTS..SingerVehicleDesign...1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    4. Member
      Nov 16th, 2006
      Atlanta, GA
      '99.5 A4 Avant
      09-06-2019 03:44 PM #3
      That doesn’t sound extremely bad. That’s about 3k miles per quart. I wouldn’t worry too much unless it gets worse.
    5. Remove Advertisements
      Advertisements
    6. Member
      Jan 4th, 2007
      MA
      2004 Jetta GLS 1.8T
      09-06-2019 04:02 PM #4
      Quote Originally Posted by pkfinn View Post
      Thank you. I'm keeping track so I know if it gets worse at some point.
      Head gasket or valve stem seal are still the original since it was new or zero miles. Its now 194000 miles.
