VWVortex.com - K03 to K04-001 problem
    Results 1 to 4 of 4
    Thread: K03 to K04-001 problem
    1. 09-07-2019 11:36 AM #1
      Hi,
      I am in the process of converting ibiza cupra with AQX motor, k03 original turbo, to K004-001,
      For now it should fit, but i have wastegate with 2 vacuum lines, and on new one, I have only one,
      Where should i connect with another one?
      bdw, i cant replace the wg, because "new" one opens up more than old one
      Thanks in advance
      Sent from my SM-N960F using Tapatalk
    2. Remove Advertisements
      Advertisements
    3. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '17 R
      09-07-2019 03:25 PM #2
      Do you have the appropriate software? Injectors? Etc.
      Sent from my SM-N950U using Tapatalk
      :HOMEGROWN MOTORSPORTS..SingerVehicleDesign...1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    4. 09-07-2019 03:28 PM #3
      Yes,
      For now it is remaped from 150 to 180hp, guy that remaps told me i should get 10-15hp, because ecu has some default settings that will keep it running,
      And when i install turbo, and bigger IC, i will go to remap it again,
      Not going for bigger injectors, i am keeping it max with this stock injectors for now
    5. Remove Advertisements
      Advertisements
    6. Junior Member THEWIDOWSON's Avatar
      Nov 6th, 2018
      EMPIRE STATE
      MK4 GTI 1.8T 2DR Manual / B4 Audi Quattro
      09-08-2019 10:44 AM #4
      Typically the single line on the k04 runs from the middle of the n75 down onto the wastegate actuator. Correct me if im wrong but doesn't the second line on your factory turbo run to the combi valve? Because if it does you should just be able to plug it.
      Some people get a mortgage. I buy gti parts.
