Can and 02M 6 speed case from a 4 cyl be swapped with the case of a 6 cyl case and keep the internals the same? Trying to see if the 6 cyl. Engine I’d like to swap in is a 6 bit the car is originally a 4 cyl AWD car. I’d like to keep the AWD but have the 6
I haven't done it but I believe you can swap the case half with the bell housing. Theres a early and late style 02m. Got to make sure those are the same between the 2 transs
The internals are the same though. I have swapped both gear stacks between the 2 different styles. One was from a 6cy and one from a 4cy. Iirc the shift shafts wouldn't swap though.
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
