VWVortex.com - N80 Purge Valve/2002 MK1 Audi TT 225
    Results 1 to 2 of 2
    Thread: N80 Purge Valve/2002 MK1 Audi TT 225
    1. Junior Member
      Oct 25th, 2013
      Hoboken, NJ
      08 VW Jetta SE, 2002 TT ALMS Edition
      09-22-2019 01:50 PM #1
      Does anyone have any pictures or description of where it is located? Is it under the plastic panel near coolant overflow?
      Have codes 17884 Evap Leak Pump: Insufficient Vacuum, 17544 Fuel Trim: Bank 1 (system too lean).
      Thnx, RS
    3. Member lite1979's Avatar
      Sep 8th, 2005
      North Buffalo
      2001 Audi TT 225 QC
      09-23-2019 12:28 PM #2
      https://forums.vwvortex.com/showthre...otten-this-yet
      Basically, remove your front right fender liner and check the vacuum connections, then check your wiring. My wiring was a little corroded, so I cleaned it up and the code eventually went away. Six months later the code came back, and I replaced the gas cap. I don't remember how I hosted pics back then, and I don't know if they're even on that old phone anymore, but it wasn't hard to get to the LDP.
      You can remove blood stains with hydrogen peroxide.
