It's not a matter of if....it's you WILL need to do it. It will probably solve about 10 posts on this page alone.
Dirty hoe
Clean bitch
Also, a chemical scrape will not last as long as a walnut media blast. This is actually my second cleaning. The chemical scrape....done first, only lasted 45,000 miles
Good pictures, and we were lucky because my wife's GTI didn't need it until 160k miles. Next VW we own I will invest in the equipment and do it myself. Not worth paying someone what the going rate is when it's really pretty easy. Do you have a full write-up? I think a lot of people would like to see a step by step or at least major step by major step. I bet it drives and idles 1000x better!
I have recently used the chemical method via CRC GDI Intake Valve Cleaner. I'm sure it doesn't clean it as well as the physical method, but it's only $20 and it has fixed 98% the rough cold idling/misfire in the morning. That is the only symptom I have after 77K miles.
I plan on doing it with ever oil change from now on. If you do it often enough, it will get as clean as the physical method. There's a guy on Youtube "nates interactive" who tests out many intake cleaners on GDI engines. His intake valves are now super clean compared to when he started.
If you use a carbon cleaning chemical a few times a year, it will last a lot longer.
Methanol injection and high rpm driving will also help keep it clean.
Here's one at my shop with 60k for the first cleaning. No misfires yet, the customer did it as maintenance.
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
