VWVortex.com - Ethanol free gas
    Results 1 to 20 of 20
    Thread: Ethanol free gas
    1. 10-29-2019 01:53 PM #1
      Has anyone tried ethanol free gas in their tank? Been thinking about giving it a shot. We have a feed store near the house with gas for tractors and stuff but all the time I see sport cars there filling up.
    2. Remove Advertisements
      Advertisements
    3. Junior Member
      Mar 29th, 2011
      WA
      2018 Tiguan SE 4Motion, 2007 Jetta 2.5, 1999 Jetta
      10-29-2019 01:55 PM #2
      I ran a tank of ethanol free 89 oct and saw no appreciable difference in fuel economy. It was $1/gal more expensive though, I did notice that. I think the engineers as VW tuned these engines assuming that we were going to use standard 87 oct with 10% ethanol blended in.
    4. Member
      May 8th, 2012
      New York City
      Passat 08 jetta 01 jetta 98 240sx
      10-29-2019 02:05 PM #3
      I dont think ethanol free is supposed to get you better fuel economy but the opposite including more power and better throttle response
      Sent from my SM-G950U using Tapatalk
      DO YOU SPEAK DAS AUTO?
    5. Remove Advertisements
      Advertisements
    6. Member
      Oct 4th, 2011
      Beaverton, OR
      1999.5 VW Jetta GLS VR6
      10-29-2019 03:00 PM #4
      I've only put 92 octane E0 in my car, I'm over 18k miles. I drive aggressively and average 27 combined mileage, about 32 with the Tig loaded up with the family on the highway.
      When real tunes come out it will matter more, but there is also a chance it will have less carbon buildup on the valves... Nothing conclusive.
      Sent from my ONEPLUS A6013 using Tapatalk
    7. Junior Member
      Mar 29th, 2011
      WA
      10-29-2019 04:27 PM #5
      Quote Originally Posted by EVANGELIONHD View Post
      Ethanol has significantly lower energy density than gasoline, the higher the blend of ethanol the lower your fuel economy will be. The fuel economy difference between E0 and E10 should be about 4% all else being equal.
      The corrosion concerns people have regarding ethanol don’t really apply to modern vehicles as manufacturers design them to be both exposed to and resistant to ethanol. Now a classic car or a piece of equipment may be another story.
      https://www.fueleconomy.gov/feg/ethanol.shtml
    8. Junior Member
      Mar 29th, 2011
      WA
      10-29-2019 04:31 PM #6
      Quote Originally Posted by zackdawley View Post
      Tunes that require another fuel usually demand a higher octane rating. (See knock resistance)
      The easiest way to boost octane is to increase the amount of ethanol (aka alcohol) in the fuel. If you’re running a tune and/or running any kind of race fuel chances are there is MORE ethanol in it than any standard pump gas.
      Aug 16th, 2016
      AZ
      2019 Tiguan, 2016 Jetta Sport, 2011 Golf TDI (gone), 2013 Passat TDI (gone)
      10-29-2019 07:50 PM #7
      As stated, Ethanol increases the octane of the fuel it is mixed with. Octane raises the temperature at which combustion occurs and this is important in a high compression engine. Ethanol also contains less potential energy than gasoline blended without it, so it will reduce gas mileage. Using ethanol free gas will result in increased gas mileage for those engines that can tolerate it, but not enough to offset the increased price being asked. This is because Ethanol is a cheap way to raise octane. Now, if you can run a lower octane fuel that is not 25 - 30% more expensive, go for it!
    10. Member haunted reality's Avatar
      Apr 18th, 2001
      Southwest Michigan
      '19 VW Tiguan SE, '15 Ford F-150
      10-29-2019 11:01 PM #8
      What's the verdict on 93 vs. 87? I know it can run 87, but I've been running 93. I was afraid of buildup issues, is that even a rational fear for this engine? Or am I wasting money?
      Sent from my SM-G973U using Tapatalk
    11. Member JSWTDI09's Avatar
      Feb 22nd, 2009
      Las Vegas, NV
      2018 VW Tiguan SE
      10-30-2019 12:41 AM #9
      Quote Originally Posted by haunted reality View Post
      IMHO, you are wasting money. Our engine was designed for 87 and it runs efficiently with 87 octane. The only good reason for running 93 octane gasoline is if you have a tune that demands it. The stock "tune" is perfectly happy with regular unleaded gas.
      Have Fun!
      Don
      2009 Jetta SportWagen TDI 6M (gone but not forgotten)
      2018 VW Tiguan SE - Pure White with NO sunroof (I live in the desert), but I did get fog lights.
    12. Junior Member
      Mar 29th, 2011
      WA
      10-30-2019 01:40 AM #10
      Totally agree with Don, just use 87 but buy it from a Top Tier branded station. The only way to prevent buildup is to use gasoline with PEA as part of the detergent additive package.
    13. Member
      Oct 4th, 2011
      Beaverton, OR
      10-30-2019 03:05 AM #11
      Just to be clear, no detergent in your gas will do a bit of good against carbon could buildup on the valves of a direct injection engine...
      Also ethanol is only "cheap" because you're paying taxes to subsidize corn
    14. Junior Member
      Mar 29th, 2011
      WA
      10-30-2019 03:16 AM #12
      The intake valves I agree will not be touched as the fuel stream does not touch them. However, the prevention of varnish buildup on (and inside) the injectors will be helped by using a high quality fuel.
      Yeah the ethanol mandate is one of the dumber policies this country has put in place. We put more energy into the process of growing, harvesting, refining, and distributing than we get out from the usable fuel!
    15. Junior Member jwvetere's Avatar
      May 12th, 2019
      Arlington VA
      2019 Tiguan SEL-P w/ 4Motion
      10-30-2019 12:44 PM #13
      As someone from SouthFL - near the water - you mostly fine ethanol-free gas at Marinas, and (rarely) gas stations near boat launches/near the water. From my understanding, ethanol-free fuel has less of a prepotency to convert their vapors to moisture (water) over time. Important for boats, which store a larger quantity of fuel, which may be more apt to sit for longer periods of time. Regular (ethanol included) gasoline's vapors will convert to water over time. Usually this is less of an issue with cars - who cycle through their fuel supply at a faster rate than a boat would. Speaking from experience, my dad's boat - which wasn't used very often but frequently had fuel issues when it was used - he narrowed the issue down to this fuel/moisture issue. When he started filing the boat with ethanol-free gasoline, his fuel problems went away. (He always kept his boat's fuel tanks full - as it was a reliable source of reserve fuel if there was a hurricane - and the gas stations run out of gas (a common FL problem).
      Current: 2019 VW Tiguan SEL-P (MQB) w/ 4Motion (5-pax)
      Formerly: 2004 Jeep Grand Cherokee w/ HO V8; 2012 Kia Optima SX; 2013 BMW 535i (loaded); 2016 BMW 435i w/ M-Sport (loaded)
      BWM will always have my ❤️
    16. Member haunted reality's Avatar
      Apr 18th, 2001
      Southwest Michigan
      10-30-2019 04:10 PM #14
      I am going to try 87 then on the next few tanks and see if I notice any difference. I am going to bet that I won't notice any difference other than being cheaper! I usually fill up with Shell most of the time which is a Top Tier Gas.
    17. Member
      Oct 4th, 2011
      Beaverton, OR
      10-31-2019 03:06 AM #15
      Ethanol absorbs/attracts water.
    18. 10-31-2019 11:56 PM #16
      I live in the heart of oil country in North Dakota. Ethanol-free 87 is only 20 cents more per gallon here. You can find it at virtually any gas station, along with ethanol free 91 octane. In the interest of full disclosure, yes, I'm employed in the oil & gas industry. Putting aside my obvious bias, if ethanol gasoline were not so heavily subsidized I think it would struggle to compete with pure gasoline if you consider that it would be more expensive due to the onerous, inefficient production method it's produced from. My other gripe about ethanol gas is -- as someone else mentioned, I believe -- that if it sits dormant for too long, it is much more susceptible to condensation buildup and water/fuel separation. If you have any collector vehicles or motorcycles like I do that sit for any extended periods of time, you should avoid it like the plague.
    19. Junior Member
      Jan 26th, 2013
      SW Minneapolis
      '17 GTI Autobahn PP, '67 Type 1, '13 Boss 302 Laguna Seca, '95 Porsche 993, Jeep Wrangler
      11-01-2019 01:34 PM #17
      I always use Ethanol-free gas- two reasons: 1) It's barely more expensive than regular Premium (VW recommends in a GTI), and 2) I've noticed a colossal performance difference. Pure gasoline has more energy than Ethanol, and that's just a fact (lower Octane however). Just recently I did a 250 mile trip out and back (i.e. negating wind effect) and at a steady 75 mph with CC activated for 80% of the trip, the dash indicated 43.7 mpg. That's quite a difference than with Ethanol (upper 30s). "Experts" say it's not possible; I'm just saying what I observe. In my former 911 Turbo it went from 11 - 12 mpg to 15 mpg, which is a massive improvement also. Ethanol is junk and I avoid it like bedbugs. Boo hoo, my GTI just got put into winter storage today (and with a full tank of E-free, let me add), also why I don't use Ethanol.
    20. Member
      Apr 21st, 2014
      NJ
      2016 GTI, Autobahn, PP, DCC, LP, DSG, CSG, Michelin Pilot Sport A/S3's, Unitronic Stage 1.5 and TCU
      11-01-2019 07:56 PM #18
      I wish ethanol free gasoline were available where I live in NJ. There are many good member posts on this thread so I won't repeat it all except to agree that we are stuck with ethanol in our gasoline supply due to political reasons and it's NOT GOOD for any engine. I have read with horror that the amount of ethanol in gasoline may be going up from 10% to 15% again only for political reasons. I would rather have the government give farmers a bigger subsidy and not ram ethanol down our throats. If ethanol were not mandated for most of the gasoline supply I believe that the price per gallon would be cheaper since there are many other ways to increase octane. I wish that the amount of stinky, highly polluting sulphur should be decreased and leave ethanol out. I have a tune and only use 93 octane Top Tier fuel but it has ethanol. I am envious of you guys that have E0 readily available and totally believe that mileage increases. We are paying twice for ethanol: at the pump and in mileage. Great thread!
    21. Junior Member jurotek's Avatar
      Sep 30th, 2015
      Northern Nevada
      2015 Golf Launch Edition 2 Door 5 speed MT
      11-01-2019 08:25 PM #19
      I've been using Pure Gas (E0) since I bought my 2015 VW 1.8 TSI 2 door Launch Edition. Maverik gas stations have it all over here in Nevada.
      Average MPG (Extended Period) fluctuates between 49.1 and 51.3
    22. 11-06-2019 07:49 PM #20
      At lunch today I filled up with 87 ethanol free. My butt Dyno didn't really feel a change, but my commute home I got 3 MPG better. Shockingly the price of the fuel was only 10 cents more then when I fill up at a Chevron or Shell. So with the increased MPG I should see a bit of a savings, but not a huge savings.
      Id probably be better off just waiting in the long line at Costco to fill up and save even more.
