VWVortex.com - Chirping sound coming from engine
    Results 1 to 4 of 4
    Thread: Chirping sound coming from engine
    1. 11-19-2019 01:40 PM #1
      Anyone know what this sound is? Belt? 2017 GTI PP 6spd 23k miles.
      Video exceeds file size...
      Sounds like a little bird chirping. Only happens at idle. First, I thought the sound was isolated to cold starts but I'm starting to hear it after the engines warmed up.
    2. Remove Advertisements
      Advertisements
    3. 11-19-2019 01:46 PM #2
      Maybe wastegate rattle. An audio clip or video would come in handy.
      Enviado desde mi S41 mediante Tapatalk
    4. Member
      Aug 15th, 2018
      Los Angeles, CA, USA
      11-19-2019 03:33 PM #3
      I experience something very similar when my 1.9 TDI timing belt tensioner bearing was going out. At first, it was only when cold. But the gradually, the sound got more persistant even when warm.
      I would check all the belts and bearings. That includes all timing belts (if you have a belt), alternator, a/c, and any other roller bearings in the path. If you're lucky, it's just the belt. But most likely, it is the one of the bearings.
      I believe you can just take off the serpentine belt (NOT timing belt) and start the engine. If the noise goes away, then you can isolate the sound to all the components related to the serpentine belt. That's how I diagnosed my 1.9 TDI engine.
    5. Remove Advertisements
      Advertisements
    6. Member
      Dec 1st, 2009
      2017 Audi SQ5, 2017 Corvette Grand Sport 7MT, 2010 Audi S4 6MT. 2015 Audi Q3 Quattro
      11-20-2019 01:37 PM #4
      The waterpump bearing of the 2.0T sometimes makes a chirping noise.
      https://forums.vwvortex.com/showthre...SI-Water-Pumps
