VWVortex.com - Cut cats?
    The Car Lounge
    Results 1 to 17 of 17
    Thread: Cut cats?
    1. 12-02-2019 07:13 AM #1
      How do I check if catalytic converters were removed on vw phaeton?
    2. Remove Advertisements
      Advertisements
      Sep 3rd, 2013
      Düsseldorf
      997 GTS | BMW M2
      12-02-2019 07:31 AM #2
      one easy way would be to get a whiff of the exhaust while the car is running. I don't mean stick your face in the exhaust pipe. Standing within 2 feet of the rear of the car should tell you. Since the exhaust gases have quite a different smell, easily detected, without any cats in place.
    4. 12-02-2019 09:17 AM #3
      And with obd computer how to tell?
    5. Member fireside's Avatar
      Feb 23rd, 2008
      14 focus st
      12-02-2019 09:25 AM #4
      Quote Originally Posted by Fined View Post
      To add to that - just cold start it and stand outside. It will smell like a 60's muscle car (love that smell) and it will be fairly loud for a flagship luxury sedan.
    6. Member fireside's Avatar
      Feb 23rd, 2008
      14 focus st
      12-02-2019 09:26 AM #5
      Quote Originally Posted by vwfetus View Post
      There are (fairly easy) ways to fool these. I used to have a newer (2005) vehicle with deleted cats and I passed plug-in inspection/OBD2 every time, no problem. Luckily the shop never did a visual.
    7. 12-02-2019 12:05 PM #6
      You mean with a hammer?
    8. 12-02-2019 12:08 PM #7
      No hammer needed. No OBDII needed. Cold-start and stand behind the vehicle 30 seconds later. Without a catalyst, it will smell terribly of unburned hydrocarbons.
    9. Senior Member DonL's Avatar
      Feb 28th, 1999
      SE Michigan
      A blue oval and a bowtie. Domestic swill.
      12-02-2019 01:30 PM #8
      Oh, I dunno...
      Maybe with a
      I mean, if by, "cut," you mean gone, either they're there or they're not.
      Smooremin: "Dont worry. My corset really fills me out ."
      Sold Over Sticker: "The only difference between innuendo and flirting is the desired result. "
      KidL: "Dammit, Chippy! You're making bad choices!"
    10. Geriatric Member @McMike's Avatar
      Oct 9th, 2002
      Northern part of the Virginia
      German Vans, British cars, and a motorbike.
      12-02-2019 01:44 PM #9
      Quote Originally Posted by fireside View Post
      My old motorcycle had resistors installed in the O2 plugs so the ECU would think the O2s were healthy and present.
    11. Member Pnuu's Avatar
      Jul 27th, 2005
      WA
      GX, Taco, Tiguan, bikes
      12-02-2019 02:04 PM #10
      As others mentioned, eyeball check to confirm if they're still physically attached and nose check to confirm if they're working.
      The ECU can be fooled by O2 spacers, resistors, or a tune... And even if you see the cats in place, they could have been hollowed out...
      The only 100% absolute way to confirm would be to run the car on an exhaust gas analyzer to ensure that tailpipe emissions are where they should be. BUT... Ain't nobody got time fo' dat.
      Oct 22nd, 2007
      Syracuse, NY
      982, F22, E88, etc.
      12-02-2019 02:14 PM #11
      I don't even think you need to be that close. Sitting in traffic I can tell if the car in front of my has cats. It's literally noxious if they don't.
    13. Geriatric Member @McMike's Avatar
      Oct 9th, 2002
      12-02-2019 03:34 PM #12
      Hold on, you're not asking so you can steal a pair, are you?
    14. 12-03-2019 02:57 AM #13
      Thinking to buy phaeton...but don't trust Lithuanian scammers in kaunas
      https://autoplius.lt/skelbimai/volks...s-8663621.html
    15. Member Baltimoron's Avatar
      Oct 9th, 2001
      Trailer Park Heaven, MD
      2013 Conestoga Wagon & 2023 VigorousZX Campermobile
      12-03-2019 10:21 AM #14
      The sniff test is good but not foolproof. You'll need to park the car in a garage, close the door and start the car.
      Let the car idle for 15-20minutes while taking deep breaths to smell the exhaust. If you become sleepy then you'll know if the car has cats.
    16. Member
      Feb 1st, 2012
      MI
      2005 Acura TSX
      12-03-2019 10:26 AM #15
      Quote Originally Posted by Baltimoron View Post
      Username checks out.
    17. How do I resize a picture? Cabin Pics's Avatar
      Mar 20th, 2008
      In The Woods
      2004 E46, 2019 Q7
      12-03-2019 11:44 AM #16
      Is the car meowing?
      Instagram - efrie004
      Quote Originally Posted by cockerpunk View Post
      maybe its just me, but i wouldnt put anything in the circle of "unrealistic" when it comes to sex.
    18. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      12-03-2019 11:57 AM #17
      Quote Originally Posted by Cabin Pics View Post
      Is the car meowing?
      should be fine once it heals
