VWVortex.com - Need help with hoses
    Results 1 to 7 of 7
    Thread: Need help with hoses
    1. 12-02-2019 10:56 AM #1
      I’m in the process of getting my 2.0t up and running. I’ve hit a brick wall on 4 items and need some help identifying where the connect to.
      1. Is the outlet just in front of the black air valve under the fuel pump. It looks like a water outlet with a snap in clip that secures it. It also has a small stem coming off the top. That connect a small hose. I can’t find where that connects.
      2. Is a small purge valve under the intake part#06H906283B. It’s connect to the intake on the very right corner. It has a silver tab where it looks like a vacuum hose attaches but I don’t see where the hose would be that connects there.
      3. Is a tube sticking out the side of the intake on the driver side. Every photo I’ve found nothing is hooked up there but I’m unsure
      I have photos of all 3 but don’t see a upload photo option
    2. Remove Advertisements
      Advertisements
      Jan 27th, 2013
      Austin, TX
      2010 CC 6Speed MT, 2019 Tiguan SEL
      12-02-2019 12:16 PM #2
      Quote Originally Posted by firebirdtony View Post
      Iím in the process of getting my 2.0t up and running. Iíve hit a brick wall on 4 items and need some help identifying where the connect to.
      1. Is the outlet just in front of the black air valve under the fuel pump. It looks like a water outlet with a snap in clip that secures it. It also has a small stem coming off the top. That connect a small hose. I canít find where that connects.
      2. Is a small purge valve under the intake part#06H906283B. Itís connect to the intake on the very right corner. It has a silver tab where it looks like a vacuum hose attaches but I donít see where the hose would be that connects there.
      3. Is a tube sticking out the side of the intake on the driver side. Every photo Iíve found nothing is hooked up there but Iím unsure
      I have photos of all 3 but donít see a upload photo option
      Just a quick response
      I cant picture things for the item 1 and 2. But for #3 nothing hooks up there. I know it feels like something should go there but leave it empty.
      post pictures for #1 and #2 if you can
    4. 12-02-2019 01:14 PM #3
      The site wonít let me share a photo of the other connects
    5. Remove Advertisements
      Advertisements
    6. Member
      Jan 27th, 2013
      Austin, TX
      12-02-2019 11:20 PM #4
      #1 Those things are empty, its misleading just like item #3
      Picture:
      #2 I have slightly different part number than what you listed. Mine is 037906283C (google it). Possibly differences between CBFA and CCTA engine. I have the CBFA engine. My valve has two small nipples going into it and cap on the other end.
      Here is the picture of the hoses.
      Good luck
    7. 12-03-2019 12:17 AM #5
      Quote Originally Posted by OEMplusCC View Post
      Picture:
      Good luck
      Wow mines a cbfa engine as well. So that whole fitting right under the fuel pump with the nipple and the big hole is just an empty space not a coolant line? It had orings on the back of it as if it was going to have fluid running through it. I couldnít find any hoses to connect to it so itís very misleading. I canít beli vw would do something like that. So basically all of my connections are complete. Thanks man. Iíve been all over that car in the cold for a week now trying to find the solution. Thanks so much , now I can start my car
      Dec 1st, 2009
      2017 Audi SQ5, 2017 Corvette Grand Sport 7MT, 2010 Audi S4 6MT. 2015 Audi Q3 Quattro
      12-04-2019 12:53 PM #6
      The thing below the High Pressure Fuel Pump is the Secondary Air Injection Valve. It should have a large hose that goes to the air-pump. The small nipple is not connected to anything.
    9. 12-04-2019 01:42 PM #7
      Quote Originally Posted by CC'ed View Post
      right, directly in front of the air injection valves a hose connect that has a small port sticking of the top. But nothing connects to them. I was unsure and couldn’t find a hose for it.
