https://www.facebook.com/marketplace/item/1957817271030987/
(My photo Service isn't working, so if you can't see the FB ad, let me know and I'll forward you pics directly)
Please READ ENTIRE ADVERT! I will do my best to explain.
1982 rabbit pickup, 1.7L EN gasser automatic and lot of extra MK1 parts.
I’ve had the car a few months and have been going through correcting P/O’s nightmare engine bay. Currently does not run, but as I continue to work that may change. (It may just need timing at this point.) This is my first pickup and my beer drinking Ogre shape doesn’t fit in the cab as easily as I thought I would.
Pros:
1982 rabbit pickup GASSER
Sitting on Snowflakes
Newer tires, no leaks
Fairly straight body
Good set of Bed rails
Tailgate(s)
Decent interior
Complete dash (only a few cracks)
No known leaks into the cab
Was last registered late 2016
Comes with Bill of sale
Good compression
A bunch of new parts:
-New air filter
-New Spark Plugs
-New ignition wires
-New distributor cap
-New distributor rotor
-New Fuel Filter and rings
-New injector seals/rings
-New vacuum lines in many spots
-New battery
Fuel distributor lines cleaned
Fuel injectors cleaned
Rear slider window
Has rear bumper with tow ball center.
Doors lock and is keyed same as ignition.
Cons:
Fat guys don't fit
Currently not running
2 small cancer spots
One tailgate hinge needs a weld (see pic)
Automatic
Will need to be towed
Comes with:
(2) tailgates total
Extra set of tailgate hinges
rear bumper w/tow ball center,
Extra solid back window glass,
5 speed transmission from GTi,
4 button steering wheel,
cabby center console with gauges AND tape holder,
cabby front bumper w/turn signals,
hood latch cable/handle,
(2) extra radiator/fan shrouds,
(3) bumper ends,
(2) headlights /buckets,
miscellaneous cis intake rubber/fuel lines.
Located in SAVANNAH GA. First with the money takes it home. No holds, FCFS. Price is pretty darn firm. I will not break up the lot of parts, sorry. I’m moving and the stuff has got to go. Dumb questions won’t be answered. I know what I got, rare, blah blah blah. It’s the holidays.. TREAT YO SELF
Pros:
Tailgate(s)
Decent interior
Good compression
-New air filter
-New Spark Plugs
-New ignition wires
-New battery
Rear slider window
Cons:
Fat guys don't fit
Automatic
Comes with:
(2) tailgates total
(3) bumper ends,
