VWVortex.com - DSG in cold weather
    Results 1 to 19 of 19
    Thread: DSG in cold weather
    1. Junior Member MK7RIDER's Avatar
      Oct 4th, 2018
      Smithtown,NY
      2017 VW Oettinger GOLF R
      12-19-2019 10:47 AM #1
      Is it necessary to let the car warm up for 10 min because of the DSG?
      I heard that somewhere. I usually give it like 3 or 4 min and slowly cruise through my neighborhood before i have to get up to speed.
    2. Remove Advertisements
      Advertisements
      Apr 16th, 2015
      Hanover, NH
      2016 Golf R, DCC, DSG, Blue
      12-19-2019 10:54 AM #2
      Quote Originally Posted by MK7RIDER View Post
      Treat the Golf R like any other car. Be gentle on it until the oil reaches up to optimal temp which I believe some testing revealed is like 130F for optimal viscosity (I'm usure someone will correct me). The Golf and VWAG's DSG transmissions are in millions of cars from Russia to South Africa even police in nordic countries have DSGs and they hop in and go. no babying it but it's an expensive part so drive normally for the first few minutes.
      definitely don't idle the car for long. if it's truly cold out, a battery tender will help the battery last longer to keep CCAs up.
    4. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '17 R
      12-19-2019 10:58 AM #3
      Read your owner's manual... it's in the dash....
      Sent from my SM-N950U using Tapatalk
      :HOMEGROWN MOTORSPORTS..SingerVehicleDesign...1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    5. Remove Advertisements
      Advertisements
    6. Junior Member MK7RIDER's Avatar
      Oct 4th, 2018
      Smithtown,NY
      12-19-2019 11:06 AM #4
      Quote Originally Posted by Vegeta Gti View Post
      Sometimes manual is too generic. Much easier to ask y'all. Isn't that what this forum is here for to ask questions... vortex police
    7. Member Harold's Avatar
      Jul 31st, 2000
      New Hampshire
      2018 Golf R, '96 993
      12-19-2019 11:14 AM #5
      I looked around my dash, it is nowhere to be found. I did find it in my glovebox.
      Owners manual online, you need your VIN : https://www.vwserviceandparts.com/di...owners-manual/
      2018 Golf R , '96 993
      past:2004 Passat 4Mo, 1.8T, stick
      '96 Audi S6, forced to sell, F. U. nh emissions
      '87 VW Quantum syncro wagon, got me into quattro,
      '85 GTI, 17 yrs , 280k miles, '75 Nova (first car)
    8. 12-19-2019 11:28 AM #6
      I think it's more like 100f. With the obd11, I put oil temp displayed in dash. Max it reaches is like 103.
      I used to get on the gas after engine temp was warm but it's surprising how much longer the oil takes to warm. Something like 3 mins driving vs 10 mins.
    9. 12-19-2019 11:36 AM #7
      I am fortunate enough to have my vehicle parked in a heated garage, but none the less, I usually start it up and within 10 seconds I’m backing out of the garage and I drive it like any other car, even in cold temps (10F-30F), usually the first 20seconds I take it a bit slower than normal. Never had any issues among the 3 R’s I’ve owned.
    10. Member
      Jul 22nd, 2011
      Wisconsin
      12-19-2019 11:51 AM #8
      If it's outside let the car idle till it does the auto kickdown then go ahead and drive normal. When it's super cold out the dsg is always a bit clunky in 1st in parking lots untill you get it warm.
      Sent from my Pixel 2 XL using Tapatalk
    11. Member
      Aug 22nd, 2016
      Toronto
      2017 R
      12-19-2019 12:37 PM #9
      Just launch it out of the parking spot that'll get it up to temp quickly.
    12. 12-19-2019 01:47 PM #10
      Quote Originally Posted by Ecsta View Post
      I find it also helps to fully disable traction/stability control first.
      Sent from my LM-G820 using Tapatalk
    13. Junior Member MK7RIDER's Avatar
      Oct 4th, 2018
      Smithtown,NY
      12-19-2019 04:15 PM #11
      Quote Originally Posted by thomasr View Post
      Interesting...
      Thanks for dropping in.
    14. 12-19-2019 05:20 PM #12
      Quote Originally Posted by rellybelly View Post
      That's a pretty neat hack, especially for winter driving. I found the following in the master coding thread. Does it look about right?
      Oil Temperature Display in Cluster
      Displays the engine oil temperature in the cluster.
      Select Control unit 17
      Control unit long coding
      Byte 10
      Bit 01 Activate
    15. 12-19-2019 10:09 PM #13
      I find that my oil temp doesn’t even display until 120-130f. This is through performance monitor and in the dash from the OBDeleven mod.
    16. 12-19-2019 10:11 PM #14
      Byte 10
      Bit 01 Activate
      No manual coding, just ran through the default apps, something like 'display oil temps'
    17. Junior Member
      Apr 8th, 2016
      ****sville, Alberta
      2018 Golf R
      12-19-2019 11:15 PM #15
      I wouldn’t worry about your DSG too much. Unless extremely cold (talking -30 or less C) I wouldn’t idle for more than a minute or so. That’s usually enough.
      If extremely cold, I let the car idle for 2-3 minutes to get the juices flowing. When it was extremely cold last winter, I did hear some whine in first gear only at low speeds. That went away after a few minutes of driving.
      Wysłane z iPhone za pomocą Tapatalk
      2014 Jetta Comfortline | RCD-510 | LED Interior | APR Stage 1 | CTS BOV |
      VCDS Owner in Edmonton, Alberta
    18. Junior Member virpacalis's Avatar
      Jun 29th, 2017
      near Philly
      2017 limestone grey R
      12-20-2019 12:04 AM #16
      I'm a boomer so I don't know anything. I drive immediately upon a cold start and keep the revs below 4K until the oil temps are 180 degrees or higher. I don't got WOT much, but only after oil temps are 200+. My cars and DSG seem to tolerate this nonsense okay.
      Valentine 1, AWE resonated DP, Unitronic IC & ECU & TCU tunes, P Zeros & Dunlop Winter Sports, WeatherTech for slop, Torklift 2" hitch mount for biking and fishing
    19. Member
      Apr 27th, 2015
      Toronto, Ontario
      2016 Golf R - 2007 Focus ZX3
      12-21-2019 11:41 AM #17
      For this reason I wish the Golf had a block heater.
      Living here in Canada I just let it i'd while i get my phones bluetooth connected and whatnot, and get on the road after 30seconds to a minute.
      I just keep the RPM's below 3000 until I see 50ºC for the oil temp.
    20. Member koala's Avatar
      Aug 25th, 2009
      Calgary, AB
      MKVII Golf R, 991.1 911 C2S
      12-21-2019 01:53 PM #18
      Quote Originally Posted by Spinal View Post
      Try to keep it below 4k rpm until oil temp is fully up to operating (85C+)
      MKVII Golf R (DSG), 991.1 911 C2S (7 MT)
    21. Member MoparFreak69's Avatar
      Sep 7th, 2014
      Boise ID
      Mk4 R32, ‘19 Golf R DSG, ‘79 Datto 620
      12-21-2019 06:17 PM #19
      I start it up, let the idle settle and drive. It takes a few minutes to get through my neighborhood so i take it easy through there and then just drive normal. I save the asshat driving for after work when it’s usually above freezing.
