VWVortex.com - I accidentally bought a car today. E30 content
    The Car Lounge
    Page 6 of 6 FirstFirst ... 23456
    Results 126 to 148 of 148
    Thread: I accidentally bought a car today. E30 content
    1. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      A Rabbit with a snail.
      01-17-2020 03:25 PM #126
      Quote Originally Posted by hushypushy View Post
      Oooh, those are supposed to be very nice.
      Are your wheels 15x7? I know you said you already ordered rubber, but 195/50/15 DZ102's are on clearance at Tire Rack: https://www.tirerack.com/tires/tires...omCompare1=yes
      On my side, I ditched the lovely PS4S for some cheaper, stickier rubber: Kumho V720. Love 'em so far. Loud as hell but great dry grip. Super stiff sidewalls. Cold/wet grip lags behind the PS4S but whatever.
      15x6, so they are gonna be a bit pinched. And Art is one of the people that recommended the Conti’s. I am worried that the Direzza on the rabbit are gonna be loud. Only other experience with 200tw tires are RE71s, and they are loud.
      -Jon
      ig:badrabbithabit Formerly known as: monoaural
    2. Remove Advertisements
      Advertisements
    3. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      01-18-2020 05:26 PM #127
      So, tires and BBS RAs installed! I am glad I didn’t go narrower, they look so tiny under the car. Tapatalk decided my spending 10 bucks 5 years ago is no longer good enough for VIP status, so I have to post each photo in its own post. So here is a picture of the super clean dash:
      -Jon
    4. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      01-18-2020 05:27 PM #128
      -Jon
    5. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      01-18-2020 05:29 PM #129
      I usually avoid spacers, but with the ride height and offset are not working together. I may have to make some measurements.
      -Jon
    6. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      01-18-2020 05:30 PM #130
      -Jon
    7. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      01-18-2020 05:33 PM #131
      And the total with selling the old wheels and new tires is 2,887.26.
      -Jon
    8. Planters (fasciitis) peanuts. Dang dogg Sold Over Sticker's Avatar
      Nov 29th, 2009
      LS3 Malibu, Mid Engined Camry
      01-18-2020 05:40 PM #132
      Yeah those rears need to come out a hair. Had the same issue with my E9. Way too tucked.
      Car's looking great! That dash is amazing.
      Driving While Awesome Podcast. Give it a listen. #TeamAkane. Donate to help a wonderful family kick cancers ass
      Quote Originally Posted by Phillie Phanatic
      SoS - please shoot a message when Brendan & His Retarded Sycophants has another gig. I’ll be there, front row.
      Nov 8th, 2002
      Whitefish, MT
      17 JKU 08 Tundra 91 318iC 89 325i 80 D150 SWB 76 Rabbit
      01-18-2020 05:50 PM #133
      Pics of mine for comparison (not whoring...).
      Ronal LS 15x7 et20
      Euroweave
    10. Member hushypushy's Avatar
      Jul 1st, 2009
      Silicon Valley
      BRZ
      01-18-2020 05:53 PM #134
      Quote Originally Posted by Bad Rabbit Habit View Post
      Is this an illusion or is there a crapload of toe-in?
      Are you planning to do a camber/toe correction kit? Like this:
      https://www.bimmerworld.com/Suspensi...-Z3-318ti.html
      https://www.akgmotorsport.com/produc...3-e28-e34-e32/
      They are NOT cheap though
    11. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      01-18-2020 06:30 PM #135
      Quote Originally Posted by PoorHouse View Post
      Ronal LS 15x7 et20
      Euroweave
      These are 15x6 et35. Mk2 GLI fitment. I like how those ronals fit, I am gonna go play with a wheel fitment calculator, and see what it will take to get it close.
      Edit:
      Apparently it would need a 27.7mm spacer to match that fitment. 20mm may be safe for rubbing and whatnot.
      According to the alignment done by the previous owner, the rear is in spec. They were not able to get the front camber into spec, but it’s around 2 degrees, so I am not losing sleep over that. The front end feels a little floaty on center, at least with the old wheel/tires. May be worth getting another alignment.
      -Jon
    12. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      02-14-2020 10:44 AM #136
      I stopped work on the bmw to get the Rabbit rally ready. Well this happened:
      Just swapped in a motor to replace the one that was knocking, changed some timing stuff, detonated, and now it has no compression.
      So, that means the backup car is now first string.
      Ordered more parts. Flywheel bolts and clutch alignment tool. 2,967.1
      I wish I would have ordered them sooner, I could be doing the manual swap this three day weekend.
      Any recommendations for extra parts to have for a road trip? It’s grumpy to start after sitting for a week, so I am thinking having a fuel pump isn’t a bad idea. Also, it has a slightly rough idle, so I am gonna grab some new spark plugs.
      -Jon
    13. How do I resize a picture? Cabin Pics's Avatar
      Mar 20th, 2008
      In The Woods
      2004 E46, 2019 Q7
      02-14-2020 03:11 PM #137
      Fuel pump
      Plugs
      Alternator/generator (?)
      Those are the three things you cannot live without, and on an old ass car they're easy to fix and can absolutely ruin your weekend if you don't have one available. None of them take up too much space, so I'd plan on securing them in the trunk.
      I was going to throw in a starter, but since it's a manual and you'll be surrounded my large weak men, you should have no issue getting it push started.
      Maybe a wheel hub/bearing assembly? That can also ruin your weekend.
      Keep brake cleaner and grease with you, too.
      Instagram - efrie004
      Quote Originally Posted by cockerpunk View Post
      maybe its just me, but i wouldnt put anything in the circle of "unrealistic" when it comes to sex.
    14. Member
      Nov 8th, 2002
      Whitefish, MT
      02-14-2020 04:03 PM #138
      Replace the fuel pump now. My car had the original and it was disgusting.
      Bring an extra crank position sensor.
    15. Planters (fasciitis) peanuts. Dang dogg Sold Over Sticker's Avatar
      Nov 29th, 2009
      02-14-2020 04:52 PM #139
      Sucks about the Rabbit. It's always a treat seeing that thing boogey.
      But rally e30. I like it.
    16. How do I resize a picture? Cabin Pics's Avatar
      Mar 20th, 2008
      In The Woods
      2004 E46, 2019 Q7
      02-14-2020 04:57 PM #140
      Quote Originally Posted by Sold Over Sticker View Post
      OP, I know you've got plenty of time, so go ahead and make sure you get some livery on there ASAP.
    17. Member whalemingo's Avatar
      Jan 30th, 2011
      at a blacksite
      02-14-2020 04:58 PM #141
      I'm still upset you have not accepted my friend request on the digital book of faces. Also what motor do you have in the bunny? I still have **** tons of aba parts including a set of JE pistons, rings and wristpins for a motor that I was going to build. BUt I was going to do a 16v conversion so the pistons raise the compression by a point.
      All Hail Andy?
    18. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      E39 M5 | 987.2 | GTI
      02-14-2020 05:42 PM #142
      I'd add a fuel pump relay. I know those tended to die on E39s and always kept a spare one in the trunk.
    19. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      02-14-2020 08:22 PM #143
      Quote Originally Posted by Cabin Pics View Post
      Always park pointing downhill .
      I am kinda thinking that I will just buy a cheap autozone one, and return it if I don’t need it. The crank position sensor is a good call, I had one die on my eta.
      I got to admit, I am kinda bummed this one is lowered, I could have put some knobbies on it.
      Painters tape livery a al Drew and the Vololvo would be awesome. But I think I will keep it low key, to avoid imperial entanglements.
      Quote Originally Posted by whalemingo View Post
      I have an ABA in the rabbit. Am I gonna just clean out your storage of incomplete projects? Higher compression would be troublesome.
      -Jon
    20. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      02-14-2020 08:28 PM #144
      I do own these wheels, and have Direzza ZIIIs for them... moredoor Warsteiner tribute?
      -Jon
    21. How do I resize a picture? Cabin Pics's Avatar
      Mar 20th, 2008
      In The Woods
      2004 E46, 2019 Q7
      02-14-2020 10:32 PM #145
      Andy wants it this way.
    22. Turtles walk slowly, but get angry fast! Smooremin's Avatar
      Jan 10th, 2006
      Chicago, Il
      16v I4, Twin Turbo Charged V6, Gas drinking V8, High revving V10
      02-14-2020 10:41 PM #146
      Asking OT for relationship advice makes about as much sense as asking TCL what car to buy.
      Quote Originally Posted by ChillOutPossum View Post
      About 5 oclock I realized I needed to go to Costco for some white people stuff.
    23. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      Yesterday 06:35 PM #147
      Broke 3k on the COO: 3,045.13. Braking performance was not super inspiring, so I attempted to bed in the pads. 5 stops from 60 is all pads had before they stopped stopping. Not gonna rally on that. So, ordered a set of Hawk HPS for the the front. Had today off, spent some time prepping for the manual swap. Rebuilt the shifter. I have no idea how someone could do that in the car. It looks like there is no slop in linkage, and the z3 shifter feels pretty good. The left/right movement is a bit tight, and there isn’t a strong centering spring. Definitely see how a money shift could happen.
      -Jon
    24. How do I resize a picture? Cabin Pics's Avatar
      Mar 20th, 2008
      In The Woods
      2004 E46, 2019 Q7
      Yesterday 07:12 PM #148
      This is TCL. No one here money shifts. Each shift is precise and placed exactly where it's supposed to be.
      Glad you're making progress.
