VWVortex.com - Mr. Miyagi's 1995 URS6 build - Project Wax On
    The Car Lounge
    Page 9 of 10 FirstFirst ... 5678910 LastLast
    Results 201 to 225 of 228
    Thread: Mr. Miyagi's 1995 URS6 build - Project Wax On
    1. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-04-2020 12:43 PM #201
      Correction -- the "lever" thing was just him changing the actuators manually under the dash to change defrost/front vent blower directions (electric motor must be dead?)
      180k on the block and 60k on the head on this engine. If the thermostat and heater core do not resolve the problem then I will take the heater core out and look at it/replace it. If this does not resolve the problem then I am putting in the newer engine.
    2. Remove Advertisements
      Advertisements
    3. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-07-2020 10:53 AM #203
      The front fell off.
      https://womp.dev/2020/09/04/urs6-cooling-system-repair/
      Also verified the turbo do spin nice and smooth. Now I need to verify the turbo is getting coolant and oil.
    4. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      09-07-2020 11:48 AM #204
      I’ve said it before, but...you are a brave soldier for taking on a project of this magnitude. I also hate all of the people who have hacked up this car before you.
    5. Member Jettaboy1884's Avatar
      Jan 20th, 2004
      North, NJ
      '97 A4 12v & '17 Honda Fit Base - 6-speed
      09-07-2020 08:35 PM #205
      Quote Originally Posted by Mr Miyagi View Post
      The front fell off.
      Ah, that happened to my B5 as well. It's amazing how accidents like that seem to just happen with Audis.
    6. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-08-2020 04:24 PM #206
      What do you think -- remove the scale from the front bash bar, paint it black, or leave it?
    7. Member Stromaluski's Avatar
      Jun 15th, 2005
      Greenville, SC
      '67 Deluxe Bus, '80 Rabbit Truck, '92 Corrado, '01 S8, '13 CC
      09-09-2020 09:03 AM #207
      The front fell off.
      I hope that's not very typical.
    8. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-11-2020 07:08 PM #208
      Progress:
      Rad came in..
      womp
      painted this thing
      bought this thing which was supposed to be in good shape wi clips but it has no clips and is in bad shape and I am out $115!
    9. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-11-2020 07:17 PM #209
      Painted some other things:
    10. Member
      May 9th, 2002
      Grapevine, TX
      01 Passat 4MO Wagon, 6sp manual and 1.8T swap. 05 Golf 2.0
      09-11-2020 09:18 PM #210
      So... I flushed some stuff.
      Whatever this residue is inside the thermostat... it was powdery.
      So yeah... waiting on the thermostat housing bolts to get here then I can get the thermostat re-installed.
      Also waiting on the heater core valve replacement to get here from Lithuania (again). There is a majorly weird valve thing going on with the heater core, and I also noted that there is DEFINITELY not hot air blowing from the AC. The previous owner mentioned something about a lever under the dash that he had to turn in order to get hot air? I'll need to investigate that more. It is looking more and more likely that i'll be replacing the heater core on this thing.
      Hopefully you are replacing that housing with the T-stat. You can see the degraded edge, it will leak. The 2.8 had the same problem when they switched over to plastic.
      2019 Tiguan SE 4Mo Orange, temporarily stock. 2001 Passat 4Mo wagon, 1.8T/6sp swapped, Konis, coilover sleeves, A6Q H+R Race springs.
      2005 Golf GLS, 2.Slow, Auto, GTI suspension, sways.
      2001.5 Passat GLX V6, stock. (son#1), 2000 Passat GLS V6 fwd Tip wagon, stock (son#2)
    11. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-12-2020 03:16 PM #211
      Quote Originally Posted by PZ View Post
      I uhhhh... yeah! I was totally not going to re-use it. Nope.
      Order's in:
      New starter
      New therm housing
      -- update later today to come. I need to figure out a way to create a coolant loop without the radiator in place to do one last flush.
    12. Member Fastvolks's Avatar
      Apr 30th, 2003
      Somewhere Bananas
      MK7.5 GTI • Audi B7 S4
      09-12-2020 04:35 PM #212
      It's nice to still see threads like this! Nice work .
    13. Member
      Mar 24th, 2001
      Beaverton, OR
      1991 BRG Miata 2008 Mercedes GL320 CDI 2002 Protege5
      09-12-2020 05:14 PM #213
      During my investigation of the water hoses, I found out that there is a massive buildup of calcium or some other sort of earthen dilemma that was surround the external part of the pipe it attaches to, as well as inside of it.
      I'm a little late to the party here, but, is it possible that muck in your engine/cooling system is actually Bars Leak fix? I personally hate that stuff, but lots of old folks love to use it.
      More likely the plastic arm for the HVAC blend door has broken.
      Losing is just a winning streak in the wrong direction -David
      1991 BRG SR20 Miata build log
      Watch a headhunter find his own job - 9 month process
    14. Member
      Apr 23rd, 2020
      Midwest
      77 Porsche 911S, 95 Audi S6 Avant RS2, 04 Beetle Turbo S, 00 Honda Insight, Boats, Sleds, Bikes, etc
      09-12-2020 05:56 PM #214
      Eh, the servos can just fail too. I've had to replace 2 of them in my car... they just stop working. Currently don't have defrost... so.. probably another servo.
    15. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-12-2020 07:08 PM #215
      Quote Originally Posted by Diamond Dave View Post
      Quote Originally Posted by ADDvanced View Post
      I didn't end up pulling the heater core -- I "flushed it" manually by hooking up a hose. We'll find out if I blew it out and need to replace the whole thing anyways since I put a lot of pressure through it. I have one on order anyways. This is something I'll look into some other time.
    16. Member Harold's Avatar
      Jul 31st, 2000
      New Hampshire
      2018 Golf R, '96 993
      09-12-2020 10:46 PM #216
      No billet aluminum thermo housing upgrade? https://shop.efiexpress.com/products...mostat_Housing
      Factory metal housing ( used on an older car, NLA) : 035 121 112A Audi tradition shop has it for 32 Euros. ( plus ship ) https://shops.audi.com/en_GB/web/tra...-035121121a-10
      2018 Golf R , '96 993
      past:2004 Passat 4Mo, 1.8T, stick
      '96 Audi S6, forced to sell, F. U. nh emissions
      '87 VW Quantum syncro wagon, got me into quattro,
      '85 GTI, 17 yrs , 280k miles, '75 Nova (first car)
    17. Member Stromaluski's Avatar
      Jun 15th, 2005
      Greenville, SC
      09-13-2020 10:40 AM #217
      Quote Originally Posted by Harold View Post
      Will Audi Tradition ship to the US? Last I heard, they wouldn't.
    18. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-13-2020 04:20 PM #218
      Quote Originally Posted by Stromaluski View Post
      Yep, no shipping from Audi Tradition to USA unfortunately. I could get a proxy in the UK to buy it then ship it, but shipping from UK is spensive as I am on the other side of the world.
      Nope. Replacement for $13, no real reason to get the billet one as the OEM one is glass-reinforced plastic. I looked at it, but decided I am not trying to spend $100 just for the billet upgrade if I am going to be selling the car within a year or two anyways.
    19. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-13-2020 04:29 PM #219
      Update:
      Still no hvac valve for the heater core (from Lithuania) but that doesn't matter much, the car will run without it.
      Plans for the day include attempting to remove the broken stem of the MFTS sensor and putting in the new one without destroying the threads, the putting everything mostly back together (sans-thermostat) as I wait for the thermostat housing. Coming on the 18th. I need to sand down the grille because I am a terrible painter and left some paint runs on it. Boo.
      Random guy on Facebook ghosted me and I never received the airbox, so I am buying another one and a new front Audi emblem.
      By the way, I go through paint very quickly, and the sky is currently orange from smoke.
    20. Member
      Feb 1st, 2012
      MI
      2005 Acura TSX
      09-14-2020 08:22 AM #220
      OP, does that intercooler have thermocouples to measure inlet and outlet temperature?
    21. Geriatric Member Chapel's Avatar
      Jun 23rd, 1999
      Boston
      12 XC70 T6 | 09 Silverado
      09-14-2020 03:37 PM #221
      I still have people who say "I can't believe you sold that UrS6"
      then I read this thread and think
      "**** those guys"
    22. Member Jettaboy1884's Avatar
      Jan 20th, 2004
      North, NJ
      09-14-2020 05:19 PM #222
    23. Member aging_fleet's Avatar
      Jun 22nd, 2004
      Columbus Ohio
      '06 Toyota Land Cruiser
      09-14-2020 10:09 PM #223
      Quote Originally Posted by Chapel View Post
      "**** those guys"
      Couldn't agree more.
    24. Member turbo_nine's Avatar
      Jul 6th, 2000
      the kidney people wouldn't take it
      09-15-2020 11:22 PM #224
      "**** those guys"
      I do this to myself, thinking about my old 200Q 20v wagon.
      Can't believe I'd let go of something so cool and rare!
      Can't believe I kept it on the road at all, either.
      call it potatography
    25. Member Mr Miyagi's Avatar
      Aug 21st, 2010
      Spokane
      09-16-2020 07:38 PM #225
      Sneak Peek
