VWVortex.com - Noise Damper/inlet air valve
    Results 1 to 6 of 6
    Thread: Noise Damper/inlet air valve
    1. 03-23-2020 09:03 AM #1
      Hello guys. Can someone help me how do I find this part on ebay or somewhere else because Im strugling to find it, everywhere it says for corrado or vr6 golf, but my Golf have different specs its a 1.6 petrol engine AEK 101hp its almost the same as ABA 2.0 US model, but mine its underpowered. I need this part cause its hising sound, or any cheap suggestion pls
      Sent from my SM-G920V using Tapatalk
    2. Remove Advertisements
      Advertisements
    3. Member 7GIRLS3CUPS's Avatar
      Aug 11th, 2016
      [253]
      44 cylinders, 19.9 liters
      03-23-2020 01:16 PM #2
      Due to the high cost of that, when you can find it, most people will seal it up where it leaks to delete it. I go the delete route with my OBD1 cars.
      "For the sake of making this easier, let's just agree that I know everything and am correct."
      2016 security breach victim #129,248. Formerly karlorado
      IG @chipan_dougleville
    4. 03-23-2020 02:10 PM #3
      I sealed that once, but it seems leak air again. Yes my golf its obd1 1995 how can I delete that?
    5. Remove Advertisements
      Advertisements
    6. Member
      May 28th, 2011
      98 Jetta TDI MK3
      03-23-2020 03:29 PM #4
      all this is, is basically a pass though muffler so to say. get some hose barbs, put on either end of hoses, threaded fittings to connect with 2 90*s
      you can make one of these easily.
    7. 03-23-2020 03:33 PM #5
      My dad once did a hose thing, when this damper blew in two pieces and I kept it with a green plastic hose just to bypass, it is a hardened plastic. Inside of these "dampers" was like a soft sponge. In junkyards they tell 40 € for a piece like that so its nosense to buy a new??
    8. Member 7GIRLS3CUPS's Avatar
      Aug 11th, 2016
      [253]
      03-23-2020 04:23 PM #6
      Quote Originally Posted by Gerald-Mk3- View Post
      Search 'ISV reroute'
