VWVortex.com - How to make 195hp-210hp on a N/A VR???
    Results 1 to 8 of 8
    Thread: How to make 195hp-210hp on a N/A VR???
    1. 03-29-2020 03:17 AM #1
      Hello guys i have a 97 jetta for daily use and i want to knowwhat i really need to have so i can make 195 to 210 keeping it in daily use,can i do itonly with bolts and what would those bolts be?i would like to do 14.00 in the 1/4 at100,what do i really need to make it as invasive as posible?i have idea ofsome little things like clone 2.9,268 cams,intake,port the exhaust manifolds,mk4 gasket,chip(wich chip do you recommended?) (wich diff 368 or394?) what other things can recommend me?I WILL THANK YOU IN THE SOUL,thanks guys.
    3. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      03-29-2020 08:16 AM #2
      Took me forever to find this
      https://forums.vwvortex.com/showthre...topics/2835110
      That was shortly after I started running my mk3. Simple setup into the high 13s. Made 185-187whp like that.
      I tracked that car from that point down to a 12.833 and if you search "allmotor" in this forum and/or the mk3 forum you will find details.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project [email protected] and falling
    4. 04-04-2020 02:45 PM #3
      - CAI (a TRUE CAI)
      - Ported exhaust manifolds
      - Full exhaust 2.5 - 3"
      - Cams (268 Schrick would be my choice)
      - Schrick manifold (not completely necessary but does help with low end torque)
      - MK4 headgasket
      - Tune (UM would be my choice)
      - Lightweight pulleys and flywheel (not much here for HP but helps engine rev much quicker)
      With all that I still think you would be a bit shy depending on how "fresh" your engine is....
    5. Remove Advertisements
      Jan 11th, 2003
      Puerto Rico
      MK3 GTi VR6
      04-21-2020 03:21 PM #4
      I did this CAI a long time ago, the black part is from a Honda Prelude cai "3 and the chrome part is an adapter 3" to 3.5" that I found on ebay
      I try to replicate the turn2 model which is now a rare piece.
      So for those who do not have CAI here an idea
    7. Member BumblebVR6's Avatar
      Nov 21st, 2001
      Houston, TX
      98 GTI VR6 / 05 A4(B6)
      05-19-2020 02:47 PM #5
      Quote Originally Posted by gto0188 View Post
      - CAI (a TRUE CAI)
      - MK4 headgasket
      Don't forget ported/polished head & lower intake manifold, & valve springs/ti retainers, & B5 1.8T intake air temp sensor. With those & everything you listed above (minus Schrick intake manifold), I made 185whp on a bottom end w/ close to 300k miles. I'm sure it would have been closer to 200 with fresh rings.
    8. Junior Member
      May 16th, 2017
      Harford County, MD
      All Motor 12v
      06-30-2020 02:50 PM #6
      Quote Originally Posted by BumblebVR6 View Post
      cold air intake, DRC 268's, GIAC chip, ps delete, 2.9 intake i made 205 hp. pretty easy setup. SAME long block, just bolt ons and different fuel, i just made 223 hp, 206 tq on a stock long block with cams.
    9. Member corradoboy18's Avatar
      May 1st, 2003
      Sanford
      2006 GLI 6spd 1981 Caddy Diesel
      07-11-2020 03:23 AM #7
      What does the different intake air temp sensor do?
      Sent from my Pixel 3 using Tapatalk
      "If there's a fork in the Road...take it." Yogi Berra
      VWs long gone in my life (from 1st-last): "92 Corrado, 67 Bug, "91 GTI 8v, '90 Corrado G60, '71 Bug, '93 Corrado (Pristine), '88 Scirocco 16v, and an '81 Golf 1.7L 3spd auto 4dr. All are gone, all are missed
    10. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      07-11-2020 07:56 AM #8
      Reacts faster to air temp changes and less prome to heat soak
      -Paul
