VWVortex.com - 1.8t swap to an MK1 using factory ECU - N249 valve stay or go?
    Results 1 to 6 of 6
    Thread: 1.8t swap to an MK1 using factory ECU - N249 valve stay or go?
    1. Member mullantf's Avatar
      Apr 4th, 2002
      Central CT
      1980 VW Scirocco
      05-18-2020 09:20 AM #1
      As part of my swap, I'm going to have the ECU flashed to eliminate post cat O2 sensor, secondary air injection, N80 monitoring (still want the function but not the monitoring).
      What about the N249, the ECU control for the bypass valve? Stay or go? I read that it limits boost spikes by given the bypass valve a bit of a head start on throttle lift off, versus waiting the extra half second for vacuum to build in the manifold. Worth having?
      What else should I eliminate?
    3. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '17 R, '19 Q7
      05-18-2020 12:34 PM #2
      Search. This topic had been covered thousands of times in the last 20 years. No lie.
      Built my in 2008 without asking a single question online. 250k miles later @486whp.
      Sent from my SM-N975U using Tapatalk
      :HOMEGROWN MOTORSPORTS..SingerVehicleDesign...1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    4. Member hushdc's Avatar
      Jul 18th, 2006
      Woodburn, Oregon
      84 1.8t Jetta, 86,91cabby, MK2 GTI,B3,B4,B5 Passat, Mk4 GTI, TT 225Q
      05-19-2020 12:27 PM #3
      Quote Originally Posted by Vegeta Gti View Post
      Search. This topic had been covered thousands of times in the last 20 years.No lie.
      Truth. Vegeta is right. I just finished up my MK1 1.8t swap a week ago without asking a single question. I gathered all my info here on the vortex, google and else where. Every single question about this swap was answered by simply searching.
    5. Remove Advertisements
    6. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      05-20-2020 12:49 AM #4
      Quote Originally Posted by hushdc View Post
      What vegeta said.
    7. Member mullantf's Avatar
      Apr 4th, 2002
      Central CT
      1980 VW Scirocco
      05-20-2020 08:49 AM #5
      I did find lots of posts where folks said they eliminated it as part of a swap, but it was only mentioned in passing. Other threads that were not swap related went into significant detail and seemed to conclude that it provided a useful function.
      Hence my question. I'm not looking for a "just get of it" easy answer, but rather some incite as to *why* people decided to remove or leave it. It's obviously quick and easy to remove, but has anyone actually thought about it first?
    8. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      05-21-2020 03:49 PM #6
      The data you're seeing, that is helpful, is a decade old. Things have progressed.
      What vegeta said.
