Can anyone out there confirm what clutch will work with a mk4 02J mounted to a mk2 1.8l 8v? I think a mk4 228mm clutch/single mass flywheel should bolt right up to the crankshaft. I think the six bolt pattern is the same for mk2 and mk4 crankshafts. Would like to do the trans swap before I do the 07k engine swap later this year. Thanks for any detail anyone can provide. jh
