VWVortex.com - B1 16V Build, or something slightly different
    Results 1 to 9 of 9
    Thread: B1 16V Build, or something slightly different
      Aug 5th, 2002
      WA State
      TT225, 76 Dasher, 2014 Golf
      05-21-2020 02:14 PM #1
      Figured it was time to share my build here. As of this writing, the motor is still being assembled, and the car itself is far from done. It's literally an empty shell. I will update this thread with a link to the car build.
      This car has been a project since 1998. It has had many years of being on the back burner.
      Lot's of builds have been posted here, and mine won't be groundbreaking or awe inspiring I'm sure, but it will have some slightly different things done that aren't super common.
      This 9A 16V with PL head is going into a 1976 VW Dasher. Many of you reading this are saying "what's a Dasher?" Well, it's the first generation of Passat, and was called Passat MK1/B1 in the rest of the world. Same car as the Audi Fox, or Audi 80 in the rest of the world.
      Because the engine is going into a Dasher, there are some unique challenges to get the motor to fit, several of which I have not even discovered first hand, but suspect will be interesting as they come up.
      One of the really obvious issues is that the B1 platform is Longitudinal. The motor goes North/South like a RWD car. Yet is still FWD. A marvel of packaging considering the nose doesn't look like it would fit an engine in front of the front wheels.
      With the motor being longitudinal, the hood slope is the biggest problem. I did a mock-up with the Scirocco intake installed, and the hood was 1 inch high in the front. So, I bought a European Audi 80 16V intake, which has oval shaped runners, matching their shape to the intake head ports. This allowed the hood to basically lay flat, but no room for squish when the hood is shut. I was going to have to use different motor mounts, and take a section out of the subframe. Or cut into the hood.
      The Audi based cars of the era had a subframe that goes under the oil pan. You can't just drop the engine out the bottom. The lower A-arms attach to the subframe, so you can imagine I didn't want to lower the subframe. Not ideal.
      So, through the years, I decided to change direction completely.
      I'm now going with twin Weber DCOE carbs.
      I've had the head done and waiting for several years. It was ported and valves reshaped by Steve Hannaford or Progressive Automotive, University Place, WA. He was very familiar with the differences between the 1.8 and 2.0 head.
      The full rotating assembly was balanced by DG Machine, Auburn WA. Clutch, flywheel, rods, pistons, crank, harmonic balancer. I did not do the IM shaft.
      They also installed new Intermediate Shaft bushings, and decked the block - just a skim.
      Flywheel was lightened by a different machinist many years ago.
      So, now you're up to date with where I'm at.
      Ok. Pictures!
    3. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      05-21-2020 02:38 PM #2
      Sounds interesting. I had a silver Dasher for a very brief period back in the day Actually, bought it to flip it at the time. I was a odd duck for sure
      Aug 5th, 2002
      WA State
      05-21-2020 02:41 PM #3
      Showing off a somewhat "unicorn" part. This is an alternator bracket from a Quantum Turbo Diesel. As you can see, it mounts to the "back" side of the motor, or what I call passenger side, or hot side. VERY rare part, and it frees up room on the "front" side of the motor for the carbs and radiator. Will be a nice clean engine bay without looking at the eyesore of an alternator.
      The block was prepped on the outside and in the water jacket with Rustoleum rust remover (phosphoric acid).
      Works excellent.
      Block now painted low gloss black.
      I'm pointing out a boss that is drilled but not tapped on the 9A block. I need that spot for the B1 motor mount that goes there. The motor mount I'm using is a standard Dasher mount. That mount was designed for a car with 78 hp. I noticed that the Audi 80 with the 2.0 uses a similar mount, but with an added strut. I didn't feel like paying for one of those to be shipped here, so I built my own strut. The Audi mount would have used the hole that is tapped to the left of my finger. But that makes for a very skinny narrow mount without the strut. I like the Dasher one better, because statically, it's stronger. (as in if I have to take the strut off for some reason while working on the car, it still has triangulated support).
    5. Remove Advertisements
      Aug 5th, 2002
      WA State
      05-21-2020 03:17 PM #4
      Obligatory internal parts shots.
      This was a low mileage block. It was very much in tolerance, in fact had the original cross hatching in the cylinders.
      I did have it re-honed. Just a de-glazing.
      Journals were all very good shape. So this is a standard bearing and ring size rebuild. Plastigage showed perfect tolerance, as well as ring gap.
      All new parts, but of course the pistons and rods are original.
      6 piece main bearings
      Oil Squirters
      New Main OEM bolts, ARP rod bolts.
      Aug 5th, 2002
      WA State
      05-21-2020 03:52 PM #5
      The oil pump was checked for lash and end play. Dead center of tolerance. So I'm reusing it.
      It is however a bit scarred up where the vanes go around (the bore surface). It is a LOT worse in pictures than in real size, so I'll give it a shot.
      I'm never one to leave well enough alone, so I've decided to clean some things up while it's apart.
      Just a smoothing of the passages. For the pump and the oil filter housing as well as the port in the block the oil goes back in from the filter housing.
      Will it add horsepower? I won't claim that. Will it hurt? Of course not.
      Will I lay awake at night wondering if I left .5 hp on the table? Nope.
      And for those wondering why the filter housing looks weird, it's at an angle to make way for the clutch cable of a "B" car.
      This particular one came from an 80's Audi if I recall. It has a much larger filter flange, allowing the big filter or the original small one, and also the bosses are already drilled for oil pressure and temp sensors, unlike the 70's Dasher one.
      Pump Before...
      Pump After...
      Oil Filter Mount Before...
      The threaded tube has been radiused on the ends also...
      Oil Filter Mount After, plus a couple spots not pictured...
      Port the oil enters the block from the filter...
      (Note to self - or anyone else thinking of doing this. I should have paid better attention to gasket matching like I usually do. The top area of this port should just be left alone, the oil filter housing is an oval slot, and the top matches the hole in the block perfectly. Just port the bottom of the hole. Oh well, not an issue.)
      Aug 5th, 2002
      WA State
      05-21-2020 04:34 PM #6
      I know a lot of people have had issues with leaking sensors on the oil filter housing.
      From the factory, they are not always "turned" flat for a good sealing surface.
      My housing is a good example of this. From the factory, 2 of the surfaces were nice and flat with spun machine marks.
      One of the sealing surfaces was NOT treated from the factory. I imagine it had been a leaker. The theory is backed up by the fact that THAT particular sensor had 2 copper washers on it, and the 2 good surfaces only had 1 washer each.
      I dressed them all, but in particular the one that looked to have an original as-cast finish.
      Here's the original look.
      The port at the 9 o'clock position is "as-cast", and was the one with 2 washers.
      The 12 o'clock and 3 o'clock where machined surfaces.
      After prepping it.
      The tool I used. Just any bolt with a flat bottom under the head, and also with a shaft that will not harm the threads of the housing. An old Fuel bolt was perfect, with its smooth shaft to not scar the threads.
      I placed a ring of sandpaper under the bolt, then chucked up a socket in my hand drill and spun it a couple times. I put a nut inside the socket so I could put pressure on the bolt with sandpaper without bottoming out the socket.
      The results after a cleanup with a Dremel mini wire wheel and a slight touch of aluminum polish.
      Aug 5th, 2002
      WA State
      05-21-2020 07:00 PM #7
      Naturally I wanted to use the VW Windage tray with the great rubber built in gasket.
      It takes a bit of modification to use one on a longitudinal car, and even more modding with the very special oil pan I'm using.
      This pan is from an B1 Audi 80 GT. Another unicorn part. Hard to find even a picture of one.
      Bought on German eBay many years ago.
      Mods to the tray. Those familiar with the tray will note the missing material because of the way the B1 sump raises up at the rear to make way for the subframe. Also the oval hole to the left of the pic, making way for one of the many internal oil channels in this pan.
      Pan was a bit rough when I got it.
      All cleaned up.
    10. Member sdezego's Avatar
      Apr 23rd, 2004
      05-26-2020 02:02 PM #8
      Aug 5th, 2002
      WA State
      05-29-2020 01:20 PM #9
      This build has had and will continue to have challenges. One of the issues I'm having right now is figuring out the belt.
      My special alternator bracket basically puts the alternator right in line with the water pump and crank.
      If I use the existing double pulley that came with the 9A, I can run a short V belt directly to the Water Pump but will have no tensioner. I'll have to remove the pulley to put the belt on or off. Being that it's a V belt, I don't see an issue with that. We'll see. I'm thinking I'll be needing some help on finding the right offset pulleys to make all this work.
      https://forums.vwvortex.com/showthre...th-QTD-bracket
