VWVortex.com - Are you replacing your drain plug every oil change?
    The Car Lounge
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 56
    Thread: Are you replacing your drain plug every oil change?
    1. 05-21-2020 11:17 PM #1
      I changed the oil in my Yukon for the first time last night, and I noticed that the drain plug bolt is actually sealed with a rubber gasket, rather than a copper crush washer like I was used to. It got me thinking, should I be replacing that gasket every change, like the crush washer of yore? Should I be replacing the whole bolt as well? Super cheap piece of mind at like $3.00 for the bolt and gasket, but I am curious if this is still something that is part of a regular oil change.
    2. Remove Advertisements
      Advertisements
    3. 05-21-2020 11:29 PM #2
      Quote Originally Posted by shimps1 View Post
      When I was using factory parts, in which the bolt came with a captive washer, I replaced it every time. I replaced it with an aftermarket bolt that has a magnet, and now I use a new copper washer every time.
    4. Member dwagner88's Avatar
      Jan 13th, 2011
      Chattanooga, TN
      2020 Civic Type R, 2014 Mazda CX-5 GT, 2018 Chevrolet Silverado 5.3 (work)
      05-21-2020 11:31 PM #3
      Nope. I never replaced the washer either. To date, Iíve never had any leaks.
      Past: 1998 Accord V6 LX, 2007 Mazdaspeed 3 (KIA 2-24-11), 2009 Mazdaspeed 3 (KIA 9-19-11), 2003 Jetta GLS 2.slow (good riddance), 2010 VW GTI, 2011 Toyota Camry, 2006 NC Miata
    5. I need new ones NeverEnoughCars's Avatar
      Aug 2nd, 2013
      Below the glide path to KAUS
      Dodge, Toyota, VW, Ford
      05-21-2020 11:36 PM #4
      Pedantry: winning arguments through exasperation since 1651. An Old World Tradition!
      "Now i am become death the destroyer of worlds."-bhagavad gita
      ďOnly those who will risk going too far can possibly find out how far one can go.Ē -T.S. Eliot
    6. 05-21-2020 11:40 PM #5
      Replacing washers and bolts and gaskets, how 20th Century...
      www.fumotooildrainvalve.com
      On the first oil change I personally do on all my vehicles, I order and slap on one of these bad boys, it makes life sooooo simple...
    7. Senior Member Mazda 3s's Avatar
      Nov 12th, 2003
      Garner, NC
      2017 Audi A4 Quattro Prestige, 2017 Subaru Outback 2.5i Limited
      05-21-2020 11:41 PM #6
      I use an oil extractor, so I donít even mess with the drain plug, and donít even need to get underneath.
      "Of course that's just my opinion; I could be wrong."
      Quote Originally Posted by The Igneous Faction
      Have you ever popped the hood on a powerstroke E350?
      Quote Originally Posted by WhistlerYOW
      No, I got good grades in school
    8. 05-22-2020 12:19 AM #7
      17 Jetta 1.4T bought at 40 miles almost 4 years ago. Now at almost 100k havenít changed the plug not even once. No leaks to this date.
    9. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Somewhere North of Lyon Mountain.
      SR71 C30 t53a/b/b
      05-22-2020 01:03 AM #8
      Oil extractor from the top in less than 5 minutes.
      Quote Originally Posted by Tavarish
      The car's best safety feature includes ejecting you in the moment of impact and wishing you the best of luck.
    10. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      05-22-2020 06:55 AM #9
      Copper or aluminum crush washer, every time.
      Audi/VW original steep washer, never. They actually say replace the bolt if the steel washer is damaged but then list the copper/aluminum washers as replacement.
      Oring on a plug no only if damaged or leaking
      Washer with oring, every time.
    11. Member Karl_1340's Avatar
      Sep 1st, 2017
      Ottawa
      2018 ATS 2.0T 6 speed manual, 2014 RDX, 1989 VW Cabriolet
      05-22-2020 07:54 AM #10
      Quote Originally Posted by dwagner88 View Post
      me also. Never had a leak, or drip from the pan bolt.
      Aug 13th, 2006
      Earth.....Sometimes
      05-22-2020 07:58 AM #11
      Ford has replaced the standard drain plug bolt with a stupid plastic contraption so I replaced this.........
      ..........with this..........
    13. Geriatric Member @McMike's Avatar
      Oct 9th, 2002
      Northern part of the Virginia
      German Vans, British cars, and a motorbike.
      05-22-2020 08:48 AM #12
      Never replaced a plug.*
      Never replaced a washer.
      I have one sump plug with an o-ring, but have only changed that one once in 8-10 oil changes.
      *I have changed a plug once because the hex head was starting to strip, but it had nothing to do with a fluid change.
    14. Senior Member 6cylVWguy's Avatar
      Jun 14th, 2000
      PA
      Blog Entries
      4
      '18 Jeep SRT; '11 M3 ZCP; '94 SLC
      05-22-2020 08:57 AM #13
      Only replace what's given to me in the oil change kits I get for the various cars. Usually that includes a crush washer, but not the drain plug.
    15. 05-22-2020 09:17 AM #14
      I always change the crush washer. My wife's old exploder had an integrated gasket but I could dig it out and replace it with an O ring. I feel like every change probably not necessary but certainly every other its worth the money.
    16. 05-22-2020 09:25 AM #15
      Nope, never.
      I replaced the copper crush washer on my motorcycle's drain plug, but only because the filter comes with it from Honda.
    17. Member col.mustard's Avatar
      Jul 16th, 2008
      Charlotte, NC
      mk6 CW GTI, Mitsu Outlander Sport, sold - mk4 futura GTI
      05-22-2020 09:51 AM #16
      replace the drain plug: what? replace the drain plug? the bolt? why? no. never. (*unless you stripped it or cross-threaded it)
      replace the washer: I replaced the washer with the 1st oil change in each car, but don't do it regularly. I've prob replaced the washers twice in 10 years... "why fix what ain't broke?"
      praise the lowered
      °save manuel!
      Originally Posted by George Bluth >>
      It's so obnoxious when VW Golf/Jetta owners comment
    18. Geriatric Member @McMike's Avatar
      Oct 9th, 2002
      05-22-2020 09:57 AM #17
      Quote Originally Posted by Chazwozza View Post
      Nope, never.
      I had a Honda that I reused the crush washer on the drain plug after changing coolant right before a road trip. Had to top off every 70 miles. Ooops.
    19. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      05-22-2020 09:58 AM #18
      Quote Originally Posted by col.mustard View Post
      The steel washer that came on the plug on the mk6 in your sig is considered permanent and reusable. If it becomes damaged (rare) VW says to replace the whole plug. But then also does spec a part number for an aluminum replacement washer.
      Edit.. wait mk6 went to the half steel pan.. so that would be a replace every time copper, the mk4 you had would have been the steel and mk5s.
    20. Millennial Pizza Cat's Avatar
      Dec 2nd, 2006
      Near McBanagon
      North American German crap and German German crap
      05-22-2020 10:00 AM #19
      I do replace the plug and crush washer each time.
      I also fully acknowledge that itís unnecessary, though. But for 2-3 bucks, itís such an insignificant amount of money to not do it in my mind.
      SS registry owner-emeritus
      Quote Originally Posted by Vee-Dubber-GLI View Post
      NATORabbitCat5PizzaSand
    21. Member 4.OMG's Avatar
      Dec 20th, 2004
      SE MI
      It varies.
      05-22-2020 10:09 AM #20
      I've replaced exactly two drain plugs in my life, both of which were on the same pan and both of which were rounded off, probably from some quick lube "tech" thinking every fastener on a 'Murican car must have an SAE head and not metric.
      I'm genuinely curious why someone would pay even $3 to replace a drain plug that isn't damaged.
      Now this was a superior machine. Ten grand worth of gimmicks and high-priced special effects. The rear windows lit up with a touch like frogs in a dynamite pond. The dashboard was full of esoteric lights and dials and meters that I would never understand.
    22. How do I resize a picture? Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      2004 E46, 2019 Q7
      05-22-2020 10:09 AM #21
      The oil change kits I order from FCP have new copper crush washer in them, so I replace that.
      Never the plug.
      Instagram - efrie004
      Quote Originally Posted by cockerpunk View Post
      maybe its just me, but i wouldnt put anything in the circle of "unrealistic" when it comes to sex.
    23. Member GTijoejoe's Avatar
      Oct 5th, 2001
      '06 Evo Mr, '18 Accord Sport
      05-22-2020 10:18 AM #22
      Quote Originally Posted by Cabin Pics View Post
      Never the plug.
      that's about it
      2.0T+034efi+meth = 300+whp = RIP
      Quote Originally Posted by Ryukein View Post
      Everyone always praises function over form until the form is something that they don't like
    24. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      05-22-2020 10:20 AM #23
      Seems like a good time to also point out:
      Steel pan steel or copper crush washer
      Aluminum pan steel or aluminum crush washer.
    25. Millennial Pizza Cat's Avatar
      Dec 2nd, 2006
      Near McBanagon
      05-22-2020 10:22 AM #24
      Quote Originally Posted by 4.OMG View Post
      ...because itís 3 dollars. 3 dollars every 6-12 months isnít affecting squat in my budget.
    26. How do I resize a picture? Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      2004 E46, 2019 Q7
      05-22-2020 10:24 AM #25
      Quote Originally Posted by Pizza Cat View Post
      Okay Mr. Rich Republicans.
