VWVortex.com - Are you replacing your drain plug every oil change?
    The Car Lounge
    Page 2 of 3 FirstFirst 123 LastLast
    Results 26 to 50 of 56
    Thread: Are you replacing your drain plug every oil change?
    1. Member 4.OMG's Avatar
      Dec 20th, 2004
      SE MI
      It varies.
      05-22-2020 10:30 AM #26
      Quote Originally Posted by Pizza Cat View Post
      ...because it’s 3 dollars. 3 dollars every 6-12 months isn’t affecting squat in my budget.
      The point isn't the cost, it's that it's completely unnecessary and illogical. A lug nuts cost about the same amount-would you replace those every time you take them off just because they're cheap?
      Edit: To be clear, I'm not singling you or anyone else out, I'm just curious about this is as a matter of car-guy-consumer behavior.
      Now this was a superior machine. Ten grand worth of gimmicks and high-priced special effects. The rear windows lit up with a touch like frogs in a dynamite pond. The dashboard was full of esoteric lights and dials and meters that I would never understand.
    2. Remove Advertisements
      Advertisements
    3. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Somewhere North of Lyon Mountain.
      SR71 C30 t53a/b/b
      05-22-2020 10:33 AM #27
      Quote Originally Posted by 4.OMG View Post
      I do enjoy new lug nuts every now and then.
      Quote Originally Posted by Tavarish
      The car's best safety feature includes ejecting you in the moment of impact and wishing you the best of luck.
    4. Member dr_spock's Avatar
      Feb 16th, 1999
      1998 New Beetle. 2019 GSW
      05-22-2020 10:34 AM #28
      Isn't it a good idea to replace the plastic drain plugs on engines with 21st century plastic oil pans?
      I never did on my old VW 2.0L NA engine and it didn't leak out the oil pan. It leaked elsewhere though...
    5. Millennial Pizza Cat's Avatar
      Dec 2nd, 2006
      Near McBanagon
      North American German crap and German German crap
      05-22-2020 10:36 AM #29
      Quote Originally Posted by Cabin Pics View Post
      Okay Mr. Rich Republicans.
      Where’s that monocle Pooh bear meme when you need it.
      SS registry owner-emeritus
      Quote Originally Posted by Vee-Dubber-GLI View Post
      NATORabbitCat5PizzaSand
    6. Member
      Oct 18th, 2017
      Saskatchewan
      2012 Cayman | 2019 R | 2015 Golf
      05-22-2020 10:48 AM #30
      On our MK7 VW's with the plastic pan and plastic plug with a rubber o-ring I replace them every oil change, the same as they do at the dealer if you use them for service. I'm not sure if they even sell the o-ring separately?
      On my Cayman I've replaced the aluminum drain plug once out of 3 oil changes, but I replace the crush washer every time. I gather the reason to replace these is because they are aluminum and could fatigue and crack after a while.
    7. Member 91gti20v's Avatar
      Jul 18th, 2001
      Orlando, Fl
      '73 Camaro Z/28, '86 3.2 Carrera, '15 Touareg TDI & '05 LGT Wagon
      05-22-2020 10:53 AM #31
      Subaru - Never replace the plug, only the crush washer
      Porsche - Same, replace sump and oil tank crush washers
      Touareg - Soft alloy drain plug recommended for replacement (along with crush washer) every oil change. Have done one oil change thus far and did replace it. It also uses an allen key/socket, so I will likely continue to replace every oil change. Cheap insurance in case the soft alloy allen rounds off a bit and I can't torque properly going back in.
      1986 3.2 Carrera Mini-build thread:
      https://forums.vwvortex.com/showthrea...-build-thread/
      1973 Pro-Touring Camaro build thread:
      https://forums.vwvortex.com/showthrea...8-build-thread
      May 10th, 2010
      Parts Unknown
      2016 Tiguan SE 4Motion
      05-22-2020 11:14 AM #32
      My old Toyotas, replace crush washer each time.
      Mk4 no, then started to extract
      B6: fumoto valve with nipple
      Tiguan: no. Reuse the steel bolt with washer
      Sent from my moto x4 using Tapatalk
      APR Stage 1/DDM Tuning Ultra HID 5500K/Neuspeed P-flo/AEM Dryflow BruteForce filter
    9. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      northwest corner, WA
      duramax, tdi westy, dieselgate tdi, and an mg
      05-22-2020 11:22 AM #33
      Quote Originally Posted by @McMike View Post
      Never replaced a plug.*
      Never replaced a washer.
      I have one sump plug with an o-ring, but have only changed that one once in 8-10 oil changes.
      *I have changed a plug once because the hex head was starting to strip, but it had nothing to do with a fluid change.
      same
      though i do occasionally swap orings but its pretty rare.
    10. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      RS3, JKU
      05-22-2020 11:28 AM #34
      Don't replace the plug itself unless it starts to feel a bit janky going in/out. Replace the washer every second or third time, when I remember. The Jeep has a Fumoto.
    11. Member Harold's Avatar
      Jul 31st, 2000
      New Hampshire
      2018 Golf R, '96 993
      05-22-2020 11:39 AM #35
      I think the whole replace bolt deal is due to 12 pt socket use and / or quickie lube joints rounding off the corners. My old Passat, I just replaced the washer, although I have flipped over the washer and re-used once or twice over the years I had her. My current Golf R has a plastic plug with a rubber gasket, I will replace every time. Porsche , new washers re-use bolts.
      2018 Golf R , '96 993
      past:2004 Passat 4Mo, 1.8T, stick
      '96 Audi S6, forced to sell, F. U. nh emissions
      '87 VW Quantum syncro wagon, got me into quattro,
      '85 GTI, 17 yrs , 280k miles, '75 Nova (first car)
    12. Member joeyfrost's Avatar
      Feb 26th, 2017
      Greater NYC
      MK6 Golf R
      05-22-2020 12:05 PM #36
      First, no matter the car I refer to the factory manual and I would suggest you see what they put in there for your vehicle.
      Personally, I’ve opted for a quick release hook up where you change the plug to one that allows for faster oil changes later. Ive attached a photo for reference..once replaced with the plug and new washer you technically never have to remove and replace it ever again. Just uncap, have a hose with the male quick connector attached, insert and twist. Oil comes out without a mess in a few minutes and you cap it back up hand tight. Dont even need pliers.
      MK6 R
      MKVI Golf R
      Stage 2+
      IG: Charlotte.Mk6R
    13. Member Pnuu's Avatar
      Jul 27th, 2005
      WA
      GX, Taco, Tiguan, bikes
      05-22-2020 12:19 PM #37
      No, just the washer.
    14. Member
      May 10th, 2010
      Parts Unknown
      05-22-2020 12:20 PM #38
      Quote Originally Posted by joeyfrost View Post
      MK6 R
      Looks like a similar concept to the (discontinued) FRAM SureDrain system
    15. You can't look at my avatar for just a second, can you? Just Another Sweater's Avatar
      Aug 11th, 2002
      Southwest Ohio
      GTI Sport 6M
      05-22-2020 02:44 PM #39
      Since my car has a plastic drain screw, it's recommended that it be replaced every second oil change.
      It would take some abuse for the screw to wear out, I just don't trust the o ring to last indefinitely.
      Also uses an oil extractor.
      Edit: Back when my cars had oil pan drain bolts I never replaced them. I did replace the crush washer whenever the bolt was removed.
    16. Member pontiac's Avatar
      Aug 3rd, 2009
      Nova Scotia
      Civic/Civic Si/Civic Allroad
      05-22-2020 03:26 PM #40
      Oil change? Peasants..I replace the entire engine every 10k..the peace of mind is worth the paltry few thousand bucks.
    17. Member DubbinGT's Avatar
      Jan 11th, 2009
      BMW 335i | Jetta S
      05-22-2020 03:32 PM #41
      I just replace the washer. Whenever I get some filters I also get the washers to go along with it. But if I dont have washer, no big deal and I reuse the existing one. Have never had any issues.
    18. Member adrew's Avatar
      Aug 14th, 2003
      Texas
      '12 Yaris, '17 Corolla
      05-22-2020 03:59 PM #42
      I buy this every couple of years
      Improving the signal-to-noise ratio
    19. 05-22-2020 04:09 PM #43
      Quote Originally Posted by BsickPassat View Post
      Stahlbus. It's neat, but $45 is a lot of money to save a little bit of mess and maybe 45 seconds of wrenching twice a year.
    20. 05-22-2020 05:10 PM #44
      Fumoto.
      don't replace anything, just drain and close it up.
    21. Member joeyfrost's Avatar
      Feb 26th, 2017
      Greater NYC
      MK6 Golf R
      05-22-2020 05:27 PM #45
      Quote Originally Posted by The Kilted Yaksman View Post
      Yes from stahlbus, but considering spending on a bolt/washer every oil change per the manual is a bit ridiculous. I also change my oil much more frequently due to the tune and mods. For me, it made more sense for a one time 45$ vs 4$ every oil change. I change my oil about 3-4 times a year, but lets say someone did spring and fall at 2 times a year....thats 8$ in a bolt and washer. 5-6 oil changes later and youre at 40-48$. To each his own, but one of the best 45$ i ever spent.
      MK6 R
      MKVI Golf R
      Stage 2+
      IG: Charlotte.Mk6R
    22. Geriatric Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STi & '16 .:R
      05-22-2020 08:32 PM #46
      I just buy the oil service kit from ShopDAP for the MK7, it comes with the new drain plug.
      iain
    23. You can't look at my avatar for just a second, can you? Just Another Sweater's Avatar
      Aug 11th, 2002
      Southwest Ohio
      GTI Sport 6M
      05-22-2020 08:34 PM #47
      Skip the Schwaben tool and just use a flat head screwdriver.
      I bought the tool before knowing it was a waste of money.
    24. Member MGQ's Avatar
      Apr 16th, 2002
      The City (:-l)
      Fusion Hybrid
      05-22-2020 10:52 PM #48
      Quote Originally Posted by shimps1 View Post
      Only the the dealer knows for sure....
      In five years I've opened the hood 3 times. twice to refill the washer fluid.
      This is only temporary, unless it works. - Red Green
    25. Member Senior Member's Avatar
      Jul 1st, 2016
      Original Join Date 2001 Central NJ
      OG 2001 Jetta 1.8t
      05-22-2020 11:04 PM #49
      Should I be replacing the whole bolt as well? Super cheap piece of mind at like $3.00 for the bolt and gasket, but I am curious if this is still something that is part of a regular oil change.
      I change it between tuneups
    26. Member devianb's Avatar
      Feb 6th, 2008
      1988 Trans Am
      05-23-2020 02:52 AM #50
      I used to change the crush washer after every oil change because it would leak if I reused it. I have been using the metal with rubber inner washer. I reuse until I notice a tear or separation of the rubber from the metal. So far I have gone through six oil changes without any leaks. As far as the drain bolt goes I reuse every time. Not changing that unless I strip or cross thread it.
