VWVortex.com - Traction Control Button Retrofit Kit
    Results 1 to 7 of 7
    Thread: Traction Control Button Retrofit Kit
    1. 05-22-2020 08:24 AM #1
      I will be purchasing the "Traction Control Button Retrofit Kit - With Keyless Start" for my Jetta and I know it needs to be coded. I know someone with a VAGCOM but does anyone know the coding for this kit?
    3. Member Tanderson2491's Avatar
      Jun 23rd, 2015
      Connecticut
      2012 GLI
      05-22-2020 08:23 PM #2
      Quote Originally Posted by goodboi69 View Post
      The kit should tell you what coding needs to be changed.
      Fuelly | 2012 GLI M/T | APR Stage 2 | SouthBend Stage 2 Daily | Forge Short Shift / Side Shift | CTS Turbo Intake | GFB DV+ | AWE Tuning Touring Turbo-back | Unibrace UB | CTS Turbo Catch Can | NeuSpeed TOP | ECS Throttle Pipe | ECS Pendulum Mount w/ BFI Stg 2 Insert | I have VCDS if you need it!
    4. 05-22-2020 10:45 PM #3
      Quote Originally Posted by Tanderson2491 View Post
      I will shoot ECS an email before purchasing then. Thank you.
    5. Remove Advertisements
    6. Member jiffyjetta's Avatar
      Mar 13th, 2010
      Oregon
      MK7 Golf Sportwagen, MK6 GLI
      05-23-2020 04:20 PM #4
      https://www.goapr.com/support/esp-defeat.html
      this is what I used on my Gli
      Tuned mk6 2.0t CBFA 6 speed ECU for sale. Launch control set @ 3800 & 8psi, immobilizer delete, cat delete, air pump delete. $300 shipped.
    7. Member Tanderson2491's Avatar
      Jun 23rd, 2015
      Connecticut
      2012 GLI
      05-24-2020 10:56 AM #5
      Just look at the install instructions. It's right in there.
      http://bd8ba3c866c8cbc330ab-7b26c6f3...stallation.pdf
    8. Member mrgreek2002's Avatar
      Sep 30th, 2002
      Toronto, Canada
      MKVII Jetta & MKVI Jetta & MKIV Golf
      05-24-2020 12:20 PM #6
      What year, trim level, and engine does the OP have?! Based off of that intel, we should be able to tell if you need programming or not.
    9. 05-29-2020 09:14 AM #7
      Thank you. I didn't think to look there.
